Low light mirror,...style and placement
2manytoys
2manytoys is offline
PostPosted: Fri Jan 29, 2010 9:44 pm    Post subject: Low light mirror,...style and placement Reply with quote
What shape is the mirror and where does it go on the fenders? I have seen some up high and some near the body line.
Is there a good re-pop mirror or are they way off on shape?
thanks,
P-
Patrick Friel....2manytoys not enough time.
sputnick60
sputnick60 is offline
PostPosted: Fri Jan 29, 2010 10:46 pm    Post subject: Reply with quote
try looking at this sticky
http://www.thesamba.com/vw/forum/viewtopic.php?t=344617
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Scott@KGPR
Scott@KGPR is offline
PostPosted: Sat Jan 30, 2010 11:09 am    Post subject: Reply with quote
The Low Light Exterior Mirror was installed by the dealer in the USA through 1965. There where 3 (maybe 4) slightly different mirrors, all on a swan neck installed on the driver side only. I have an old dealer paper mounting template that I need to dig up and post. Roughly, placement is about an inch above the fender seam (concave one on the inside) and one stud is in front of the hinge sill (inside the fender) the the other behind. So yes, you need to remove that piece when installing the mirror.
[/img]
Scott Dempster
www.karmannghia.com
(AKA, "The Ghia Guy")
pbaptist
pbaptist is offline
PostPosted: Sat Jan 30, 2010 11:24 am    Post subject: Reply with quote
Dutch Karmann-Ghia and coachbuild lover.
1* Karmann Ghia Coupe (1966 Teak)
2* Karmann Ghia Convertible (1958, 1971)
4* Rometsch Lawrence (nr 534, 555, 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database
