spoon Samba Penetrator
Joined: September 08, 2005 Posts: 1458 Location: Monterey, CA
Posted: Tue Sep 13, 2005 11:10 pm Post subject: What are these? (PHOTO INCLUDED!) |
What are these? Those levers between the seats, with the little red rubbers on them. What is the left one for? What is the right one for?
Justin
VW Addict Samba Salesman
Posted: Tue Sep 13, 2005 11:14 pm Post subject: |
Heat.
Labels are great huh?
Left one, to turn it on.
Right one, to adjust the temp, pull it, it gets hotter, not noticably, but supposively. Car has to be nice and warmed up and running before you get any heat whatsoever.
Basically, ask anyone they are there for decoration. However, I got my '78 Westy given some good heat, never know! |
Josie_Aus Samba Member
Joined: September 13, 2005 Posts: 141 Location: Australia
They look like heater controls to me... one opens and closes the front heater vents, the other operates the rear heater vents, (the ones under the back seat)
(edit) oops, too slow! thats what they seem to do on my car anyway (aussie '72 notch) |
Posted: Tue Sep 13, 2005 11:18 pm Post subject: |
Ahh, thanks that's what I figured. But I have no idea where the heat is supposed to come from. I turn it on and mess with the temp... but honestly I cannot feel any air coming from anywhere. Where SHOULD the "heat" come from?
Justin |
Posted: Tue Sep 13, 2005 11:29 pm Post subject: |
Mine comes from vents just infront of the doors on the floor, and at the corners at the bottom of the windscreen..
Apparantly my car is meant to have levers under the dash on each side to adjust the level of heat going to these two areas, but theres no trace of them... maybe your car has them! |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Sep 14, 2005 3:19 am Post subject: |
ever peeked at an owner's manual?
http://www.thesamba.com/vw/archives/manuals/type3.php
did you pull on the lever to see what happens? Type 3's actually have amazing heating systems... worlds ahead of Type 1's... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Notcho Samba Member
Joined: August 26, 2005 Posts: 105 Location: San Antonio
Posted: Wed Sep 14, 2005 6:22 am Post subject: |
I thought they were seat ejectors
I've never used my heater.........didn't know it worked that well, cool.... _________________ '64 Notchback 'S' Sunroof
San Antonio Air Coolers |
ddare Samba Member
Joined: January 10, 2005 Posts: 583 Location: Cypress, CA
Posted: Wed Sep 14, 2005 7:00 am Post subject: |
Yeah they work pretty good, just gotta clean those areas out every now and then or the first time you use them in the winter you get stanked out. My car has to get nice and hot before I can really feel the heat (usually about 5 mins or so) but thats because I have several holes in my heater hoses |
SquareTone Samba Member
Joined: July 10, 2003 Posts: 1204 Location: Jenks, Oklahoma
Posted: Wed Sep 14, 2005 7:03 am Post subject: |
If your car is hooked up correctly (heater boxes haven't been replaced by J-tubes or headers, heater elbows are connected to the fan shroud, hoses from the heater boxes to the heater channels are intact, heater channels aren't rusted out, control cables are connected) then you should be able to get great wads of heat within about a minute of starting your car. When we first put my daughter's square together all of the flaps didn't close off completely. She kept complaining that her feet were getting cooked.
Raise the right lever to control the amount of heat. Raise the left lever to cook the legs of backseat passengers. _________________ Tony
'70 Fastback AT/FI (daily driver (exept when the starter won't work, or it's out of gas, or I don't go anywhere, ...))
"...it is a well known fact, that those people who most want to rule people are, ipso facto, those least suited to it."
Help Improve TheSamba |
Posted: Wed Sep 14, 2005 7:10 am Post subject: |
SquareTone wrote: |
Raise the right lever to control the amount of heat. Raise the left lever to cook the legs of backseat passengers. |
had my first experience with this this past April on a roadtrip from Missouri to Ennis, TX: aggro joe kept playing with the levers and roasting my feet while driving through Oklahoma at midnight.... he couldn't believe the sheer amount of heat compared to the hamster-breath in his bug... thankfully the novelty wore off... _________________ póg mo thóin
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Wed Sep 14, 2005 8:39 am Post subject: |
(if you have a 71 fastback like mine) you also have two knobs on the front of the door jams (just inside) that channel air from your feet to your defroster. Don't know if notches/squares have these.
don't remember if down or up is defroster. can check my manual if you need to know. Should be apparent.
If you really want to see how they work, pull the back seat and mess move them you'll see the cables move.
My heater in the FB works like a champ
robert |
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Wed Sep 14, 2005 9:58 am Post subject: |
VW Addict wrote: |
Basically, ask anyone they are there for decoration. |
Obviously you've never had a type 3. With the heat on you can bake cookies inside. _________________ OGST
Samba Member #4862 |
69fastbuck Samba Member
Joined: December 02, 2004 Posts: 22 Location: Oakdale,Pa
Posted: Wed Sep 14, 2005 5:33 pm Post subject: heat |
Living in western Pennsylvania as a child my parents had a 54 bug then a double cab.I didn't know cars had heat untill we got a corvair with a gas heater.The type 3s an oven. _________________ 1969 fastback, toga white,manual trans. |
