lowering squareback
timalan1
timalan1 is offline
PostPosted: Mon Sep 19, 2005 8:28 pm    Post subject: lowering squareback Reply with quote
Can anyone tell me how low you can lower a sq/back without having an adjustable beam, and how?Thanks. Mine is lowered but would like it lower.
Spezialist
Banned
Spezialist is offline
PostPosted: Mon Sep 19, 2005 8:33 pm    Post subject: Re: lowering squareback Reply with quote
your car already has "adjustable" front end, rear.
Popcorn
Russ Wolfe
Russ Wolfe is offline
PostPosted: Mon Sep 19, 2005 8:38 pm    Post subject: Reply with quote
T-3's have adjustable beam from the factory. It is called a spline torsion bars
Gary: OK. Ima poop.
hoss
hoss is offline
PostPosted: Mon Sep 19, 2005 10:32 pm    Post subject: Reply with quote
This is detailed in the Type3 FAQ... I think its in a large, bold typeface right when you load it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=68736
'54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy
PostPosted: Mon Sep 19, 2005 10:49 pm    Post subject: Reply with quote
Yes, check the links in the FAQ and let us know if you have any questions. Or post in those lowering threads.
spoon
Samba Penetrator
spoon is offline
PostPosted: Fri Sep 23, 2005 6:16 pm    Post subject: Reply with quote
Ok you guys. What does a spline look like anyways? I have a Bentley and I cannot even figure out where to start. Not only that, every thread about this I look at contain terms like "spline", "inner", "degrees". Wow, can someone post a picture?
Justin Twisted Evil
Russ Wolfe
PostPosted: Fri Sep 23, 2005 6:53 pm    Post subject: Reply with quote
Let me see what I have.
Gary: OK. Ima poop.
spoon
Samba Penetrator
spoon is offline
PostPosted: Fri Sep 23, 2005 7:15 pm    Post subject: Reply with quote
Thanks Russ.
I am about an hour into the passenger side front over here. People say to separate this bolt, but then there are like 3 bolts! I am uber confused but I hope to have my baby slammed by the nights end.
Justin Twisted Evil
Russ Wolfe
PostPosted: Fri Sep 23, 2005 7:19 pm    Post subject: Reply with quote
I dont have any pic of the front end apart. Sorry.
Gary: OK. Ima poop.
spoon
Samba Penetrator
spoon is offline
PostPosted: Fri Sep 23, 2005 7:43 pm    Post subject: Reply with quote
Ok, heres what I did..Im not sure if im doing the right thing but this is where i ended up.
spoon
Samba Penetrator
spoon is offline
PostPosted: Fri Sep 23, 2005 7:55 pm    Post subject: Reply with quote
GREAT! I now know how to lower my squareback. But, Im now assed out because I put th3e reference marks in the wrong spot because i didnt know what the hell i was looking at. Now I have a problem.
spoon
Samba Penetrator
spoon is offline
PostPosted: Fri Sep 23, 2005 10:21 pm    Post subject: Reply with quote
Yeah whatever... my passenger side is now "randomly" done... it looks friggin sweet. I just need to finish up the other side tomorrow in the morning, I am hoping I get the splines identical to the passenger side, which will be a low percentage considering I have no idea how many splines I turned Shocked
Justin
Russ Wolfe
PostPosted: Sat Sep 24, 2005 7:32 am    Post subject: Reply with quote
Now, grease the hell out of it when you are done. Those bearings in there are made from "unobtainium".
Gary: OK. Ima poop.
Bobnotch
Bobnotch is offline
PostPosted: Sat Sep 24, 2005 8:54 am    Post subject: Reply with quote
Also, recheck the toe in. I've found if you lower it 2 or more splines, the toe in changes, and actually goes toe out. Shocked On average, they will go 1/2 inch toe out, which means you have to adjust both sides to get it back to 1/8th inch toe in. Wink This can be done in about a 1/2 hour with a tape measure. Very Happy
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
spoon
Samba Penetrator
spoon is offline
PostPosted: Sat Sep 24, 2005 4:05 pm    Post subject: Reply with quote
I finally finished. The drivers side look less than 45 minutes, and I even had crappy hand tools that didn't work right. The hardest part here is getting the ball joints/spindles back into place, that pretty much sucked.
Notched
Notched is offline
PostPosted: Sat Sep 24, 2005 10:28 pm    Post subject: Reply with quote
Lookin' good! Funny how the first side takes forever, huh? The second side is sooooo much faster.
Man, I love lowered Squarebacks!
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
redbug74
redbug74 is offline
PostPosted: Wed Sep 28, 2005 1:04 pm    Post subject: Reply with quote
I was pretty skeered to try it, but using the instructions on this site me and 2 buddies did it in a couple of hours. Yeah, the first side does take longer than the second. I guess its the boost of confidance when you see how easy it was. Thanks just my .02 worth
paul_fio
paul_fio is offline
PostPosted: Tue Oct 05, 2010 10:02 pm    Post subject: Reply with quote
What size are those tires and wheels? It looks great.
BKiller
BKiller is offline
PostPosted: Wed Oct 06, 2010 6:44 am    Post subject: Reply with quote
Nice bump of a 5 year old thread! Rolling Eyes
VW SP2
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Oct 06, 2010 7:03 am    Post subject: Reply with quote
spoon is still around Here! (9/22/10) Rolling Eyes
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
