Blauhaus Samba Member
Joined: June 18, 2003 Posts: 140 Location: Jacksonville, FL
Posted: Wed Nov 09, 2005 11:25 am Post subject: Bad Relay? |
Hello,
Having a bit of trouble with my turn signals...in that they aren't working at the moment. My car is a '65 though converted to 12v.
Here's the scoop. Turn signal stalk actuated either up or down (right or left) yields the following results: The indicator lights come on the guage (both, solidly) with no blinking and no lighting of the actual bulbs in the housings outside of the car and no clicking sound .
I've checked and replaced bulbs and checked fuses. The high beam switch on the column still functions BTW. Does this sound like a relay issue.
Thanks,
Robert |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Nov 09, 2005 11:37 am Post subject: |
Check the grounds before condemning the relay. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu Nov 10, 2005 11:43 am Post subject: |
Definately check your grounds. That's where many electrical gremlins live. There's a ground for the guage too. (At least mine has.)
After re-wiring my dash, <- click I spent a couple weeks on signals alone.
Now I get this problem: My blinkers work fine, till I step on the brake. Then the dash indicator goes solid, and I believe the outside signals stop.
WTF? Otherwise, all lights/indicators work fine.
I've almost have the wiring diagram memorized, but can't figure this out. _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Thu Nov 10, 2005 12:29 pm Post subject: |
Air-Cooled Head wrote: |
I've almost have the wiring diagram memorized, but can't figure this out. |
Wrong bulb in a brake socket, one taillamp wired wrong, or... a bad ground! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Denis Samba Member
Posted: Fri Nov 11, 2005 7:35 am Post subject: Flasher problem |
I had exactly the same problem the other day. I also thought the flashed was bad. I removed the flashed to get a number off it and then replaced, after this the system worked fine. Must have been dirty contact pins on the flasher. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Nov 11, 2005 10:44 am Post subject: |
With the conversion to 12V, what flasher unit did they use. An off the shelf from a local flaps, or did they go with the 12V -9 wire, or did they change out the steering column and are using a later 3 wire flasher unit?? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Denis Samba Member
Posted: Fri Nov 11, 2005 12:29 pm Post subject: Relay |
I have a stock '71; of course it's 12 Volts and I believe still has the original flasher relay. The relay had 3 connections on the bottom where it plugged into the top of the fuse panel. |
Posted: Sun Nov 13, 2005 11:59 am Post subject: |
Russ Wolfe wrote: |
With the conversion to 12V, what flasher unit did they use. An off the shelf from a local flaps, |
That's what mine was, and what I replaced it with.
I obviously still haven't got my wiring/grounds squared away. Now, the right side works, except on the brakes, and the left is totally out.
Back to the wiring diagram,,,
Also, I have a 68 T1 column. Does that make a diff? _________________ Everything known to man has been written.
