oilspot Samba Member
Joined: July 11, 2002 Posts: 909 Location: Southern NM
Posted: Wed Dec 14, 2005 10:16 am Post subject: heat exchanger dissasembly |
I've got a good type three stock muffler that I'd like to take the heat exchangers off of to sell. I just came in from heating the nuts with a torch. I'm going to let them cool, soak them with wd-40 and them probably heat them again tommorow. (i want them to come off clean).
my question is which side is the nut on, muffler or heat exchanger.
I don't want to start turning the nut the wrong direction and end up stripping the threads. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Dec 14, 2005 2:59 pm Post subject: |
The nuts screw onto the muffler, so it's the usual clockwise to tighten, anticlockwise to loosen.
They can be really fun! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Dec 14, 2005 3:11 pm Post subject: |
I imagine that they'll be great fun to get loose. That's why I'm planning on taking a few days to mess with them to get them apart.
My first problem was not having a large, thin wrench to grab the nut with. It's kinda funny that a rear springplate was laying on the ground right next to the muffler. With just a light touch of a grinder down the inside of where the axle would sit on the springplate, you've got a nice, thin wrench!
ghetto, yes, but a lot gets accomplished in the ghetto |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Dec 14, 2005 4:01 pm Post subject: |
also - try PB Blaster ; works much better than WD-40; pick it up in any FLAPS.... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Dec 14, 2005 7:43 pm Post subject: |
Those nuts screw into the heat exchanger.
Acetylene torch will usually get them loose. Propane torch is doubtful as it doesnt have enough BTU's _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Wed Dec 14, 2005 11:19 pm Post subject: |
I'm using an Acetylene torch.
I may give the PB blaster stuff a try. I've had a few other people tell me it's pretty decent stuff. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Thu Dec 15, 2005 7:52 am Post subject: |
WD-40 is NOT a penetrating oil, it's a water displacer. PB Blaster is the best. You may as well spit on the thing rather than waste your money on WD-40...you'd get the same results. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
