iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Sat Jun 03, 2006 3:10 pm Post subject: Installing distributor drive shaft |
i bought a new mexican longblock and there is no distributor drive gear installed,
why don't they install the drive gear when the build the engine?
can I get one from another engine without the puller?
How does the puller work?
How do I put the drive gear in the case without screwing anything up?
thank you thank you
I thought I was home free with this engine but apparently not. |
EZGZ Samba Member
Joined: October 10, 2005 Posts: 923 Location: Loveland, Colorado
Posted: Sat Jun 03, 2006 3:49 pm Post subject: |
You can use an old distributer drive.
A puller is a good idea.
There is also a small washer (spacer) under the drive gear.
Most books I have seen give detailed distributer install help with pictures. If you don't have a book you can go to a library or take notes at barnes and Noble. _________________ 64 custom Ghia, 66 Bug, Sandrail, Barrien tub |
Posted: Sat Jun 03, 2006 4:01 pm Post subject: |
I have how to rebuild your engine but that book tells you to do it with the case halfs apart. |
VIN Samba Member
Posted: Sat Jun 03, 2006 6:36 pm Post subject: |
if your using a stock distributor i believe you have to have the large half toward the cylinders, the slit parallel, with the crack in the crankcase while at TDC. 009 it doesnt really matter. dont forget the shim(s) and carefull of the brass worm gear. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
supermanbidder Samba Member
Posted: Tue Dec 11, 2012 11:42 pm Post subject: |
the above pic I assume that this is at top dead center #1 correct ?
dang chevys were never this much aggravation |
Posted: Tue Dec 11, 2012 11:48 pm Post subject: condensor hits distributor clamp |
my condensor (on bosch 019) seems to be hitting my dizzy clamp |
Glenn Mr. 010
Posted: Wed Dec 12, 2012 4:47 am Post subject: Re: condensor hits distributor clamp |
supermanbidder wrote: |
Get a early clamp like #2.
_________________ Glenn
Member #1009
#BlueSquare |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Dec 12, 2012 8:57 am Post subject: Re: condensor hits distributor clamp |
I install all my dist drive pinions so that the slot is between the dist clamp stud and the fuel pump stud. That will eliminate this problem. |
Posted: Wed Dec 12, 2012 9:23 am Post subject: |
is this acceptable placement for it (when on tdc) so my timing will be correct? |
Posted: Wed Dec 12, 2012 9:24 am Post subject: |
do you know anyone that might have one ? |
