Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sat Jun 10, 2006 4:58 pm Post subject: 11 tooth odometer gear needed |
Hey folks,
Anyone out there has an 11-tooth odometer gear they can spare? My speedometer is complete and fully functional, except for this gear. This is the small gear at the end of the odometer shaft. I'd rather locate this one gear, than have to buy an entire speedometer.
Thanks,
Warren |
kubelmann Samba Member
Posted: Sat Jun 10, 2006 5:15 pm Post subject: |
That gear is a definate weak link in the odometer gear train. They tend to break, split or break a tooth. It is very unusual when a speedo is broken but still has that gear in good condition. I have no idea where you will find one unless you have contacts with a person who is rebuilding speedos. There are a bunch of folks rebuilding those speedos these days. But I have no idea where you could get that gear... |
Posted: Sat Jun 10, 2006 6:52 pm Post subject: |
How about other compatible speedometers? Was this gear used on other VW models? Maybe I could salvage the gear from a more common, cheaper speedometer? |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Sat Jun 10, 2006 7:22 pm Post subject: |
One of these days I am going to our local wrecking yards. I will try and to remember to bust a few old VW bug speedo heads open and pull some gears. |
n0limdon Samba Member
Joined: October 06, 2005 Posts: 192 Location: Cresco, Ia.
Posted: Sun Jun 11, 2006 1:20 pm Post subject: |
The article by Rick Smith which I mentioned in your other post, says there are other VW models that have the brass 11 cog gear, however no info as to which ones.
By the way I'am in NE Iowa about 60 some miles from Lacrosse, Wi.
Author also mentions the super glue fix will last at least 5 - 6 yrs. I believe you said it didn't work for you however, wonder why?? I done one also and it is ok, however I did go to a brass one in another unit. I have the super glued one as a backup. |
Posted: Sun Jun 11, 2006 1:29 pm Post subject: |
If I find a decent plastic one I will cast it in brass. I can rubber mold it and make castings off it then. |
Posted: Sun Jun 11, 2006 1:44 pm Post subject: |
One of the teeth on my gear broke off as well, so I couldn't fix it. I emailed a guy in Florida who supposedly fixes speedometers (john@ccspeedometers) but I haven't heard back from him. The website, www.ccspeedometers, isn't available either. This company and person was referenced in "Rob and Dave's Air cooled Volkswagen Pages". |
Posted: Sun Jun 11, 2006 6:27 pm Post subject: |
I found a source for the 11-tooth gear! Only $15 plus shipping/handling!
http://www.speedometerplus.com/
I'll be giving them a call tomorrow morning... |
JIbe-it Samba Member
Joined: September 16, 2004 Posts: 42 Location: New Jersey
Posted: Sun Jun 11, 2006 6:54 pm Post subject: |
Thanks! I like that site better... I can order and pay online and they are located in Virginia. Much closer than Calif. The sooner I get the gear, the sooner and can fix the speedometer and put my dash back together and get back on the road! |
