Replace ball joints
hmbruce
hmbruce is offline
PostPosted: Tue Jun 13, 2006 12:49 am    Post subject: Replace ball joints Reply with quote
any suggestions on replacing my ball joints on 72 reg beetle, i've never done it before but it dont look too bad.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jun 13, 2006 3:09 am    Post subject: Reply with quote
You need a special tool to do the job.
You can try to use a generic one but it's best to borrow the correct tool.
Glenn
Member #1009
#BlueSquare
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Tue Jun 13, 2006 8:58 am    Post subject: Reply with quote
Here are some good threads from the past to help this sticky along...
http://www.thesamba.com/vw/forum/viewtopic.php?t=136024&highlight=ball
http://www.thesamba.com/vw/forum/viewtopic.php?t=132020&highlight=ball
http://www.thesamba.com/vw/forum/viewtopic.php?t=108664&highlight=ball
http://www.thesamba.com/vw/forum/viewtopic.php?t=79547&highlight=ball
http://www.thesamba.com/vw/forum/viewtopic.php?t=71263&highlight=ball
dews70bug
dews70bug is offline
PostPosted: Tue Jun 13, 2006 7:35 pm    Post subject: Reply with quote
Harbor freight has these kits. Not real sure if it will work for VW but they have a few to chose from.
http://da.harborfreight.com/cpisearch/web/search.do?keyword=ball+joint+tool&Submit=Go
Mr. 010
Glenn is offline
PostPosted: Tue Jun 13, 2006 7:38 pm    Post subject: Reply with quote
Time to make it a Sticky.
Let's stay on topic.
Glenn
Member #1009
#BlueSquare
VanderBus
VanderBus is offline
PostPosted: Fri Jun 16, 2006 8:28 pm    Post subject: Reply with quote
I've used that big Harbor Freight C-clamp style kit to replace the ball joints on my 69 a few years back. I got it on sale for around $40.00 and ended up deforming the C-clamp after doing two cars. It did the job but I'd get a better quality kit if I knew I was going to use it a lot.
1969 Bug (in pieces)
1970 Bus (daily driver)
ridge05_71
ridge05_71 is offline
PostPosted: Sun Jun 18, 2006 6:27 pm    Post subject: Reply with quote
I just replace my ball joints, tie rods, tie rod ends, steering dampner, put dropped spindles and converted over to disk breaks in the front of my 72 about two weeks ago. If you need any help, let me know and I might be able to lend a hand. I just went to auto zone and rented the tools to do the job.
Breck
low66
low66 is offline
PostPosted: Sun Jun 18, 2006 7:00 pm    Post subject: Reply with quote
boy am i glad i bought one of thoose when changing mine..I tried for hours without one of thoose, i didnt even get any off.. Brought one of thoose and 30 min later i had them all off..very good tool to have. I think mine cost like 45 bucks
bug_me
bug_me is offline
PostPosted: Sun Jun 18, 2006 8:10 pm    Post subject: Reply with quote
Anyone know where to get the VW specific press?
Mr. 010
Glenn is offline
PostPosted: Mon Jun 19, 2006 6:25 am    Post subject: Reply with quote
I got mine from a retired VW mechanic... along with the rest of his VW specific tools. I contaced OTC and they said they stopped making the VW jigs 20 years ago and have no plans to make any more.
Glenn
Member #1009
#BlueSquare
max16v
max16v is offline
PostPosted: Mon Jul 24, 2006 4:25 pm    Post subject: Bottom Ball Joints proves difficult. Reply with quote
im in the process of replacing my ball joints right now. i was reading some threads that Glenn posted and that answered several questions except one....
I have rented the BJ tool from AutoZone and the Top ball joints came out with no problem but the Bottoms are giving me trouble. The AZ tool is generic and i cant figure out a way to press the bottom bj's out. If any one has had success using the generic tool let me know. Thanks.
86 Scirocco
69 Bug
CC_Hawg
CC_Hawg is offline
PostPosted: Wed Aug 02, 2006 8:12 pm    Post subject: Reply with quote
I don't know about the rest of you, but I'm thinking that bugforlife needs to start a rent a tool program that is a cross between Autozone and Netflix - the tool you need, keep it as long as you like... Laughing
vicsvw
vicsvw is offline
PostPosted: Wed Aug 02, 2006 8:44 pm    Post subject: Easy way and cheap Reply with quote
There is an easer way to remove them and any one with an Electric welder has the best tool made to remove them. We have removed several hundred this way and always works great. Pulled a many bearing races the same way. See -> Ball Joint Removing <> http://www.1800vw.bizhosting.com/qa_balljointrem.htm Any one with a press can put the new one in, just be sure it's aligned properly. Even if you have the Special tool this is easer. Pulled an 8" bearing race with a 110v Harbor fright welder and a $2.00 hammer. www.vwhelp.com
I just might buy one of those fancy tools, so I can charge the customer twice as much "Special tool and all"
SLO-N-LO-69
SLO-N-LO-69 is offline
PostPosted: Fri Aug 04, 2006 2:32 pm    Post subject: Reply with quote
Has anyone used any of the ones at the harbor freight site linked to above? If so which one and how did it work?
VICTEXAS
VICTEXAS is offline
PostPosted: Sun Oct 15, 2006 5:41 pm    Post subject: BJ REPLACEMENT Reply with quote
I'm not a great mechanic by any stretch-- but if your ball joints have been rusted in for over 20 years like mine--- a blow torch may be good to heat up the control arm... BFH may help--- (big freakin hammer).
I used the Harbor Freight C Clamp--- and began to tear up the tools-- but I got all 4 in. Used a 450LB Air Impact to get 'em all pressed in tight. Then promptly poked an F'n hole in my rubber trying to pull up the spring after greasing the joint. I'll run it until it busts... and then replace...
Oh yea-- don't heat up the control arm when putting them back in-- you'll melt the teflon.... did that too.. it pissed me off... dragged that project out an extra week.
VL
View user's profile Send private message MSN Messenger Classifieds Feedback
roymann
roymann is offline
PostPosted: Sun Oct 15, 2006 7:43 pm    Post subject: Reply with quote
I heated mine with a torch and hammered them out with a heavy drift pin.
Amazing what a little heat will do to break the 30 yr old rust weld!
Hammered the new ones in with a heavy duty 1 1/2 inch plumbers socket.
73 Bug deVille
77 Vert - Under Destruction
Lookie here - http://images.thesamba.com/vw/gallery/pix/305639.jpg
ed stanley
ed stanley is offline
PostPosted: Mon Oct 16, 2006 4:35 am    Post subject: Reply with quote
That's how I did it, too. I was reluctant to say so, because I know some would say that's a terrible thing to do - put a torch to the control arms to swell them up and pound out the old ball joints. Changes the metalurgy, loses hardness, etc. etc. My experience has been that they can take it, though. I know - I know, it doesn't make it right.
roymann
roymann is offline
PostPosted: Mon Oct 16, 2006 4:54 am    Post subject: Reply with quote
You don't have to heat them until they glow red! Just raising the temp a couple of hundred degrees is enuff to move the molecules and break
the chains.
73 Bug deVille
ed stanley
PostPosted: Mon Oct 16, 2006 8:02 am    Post subject: Reply with quote
Yes - quite true! You don't need "red" heat to accomplish the job.
74airbug
74airbug is offline
PostPosted: Mon Oct 16, 2006 2:46 pm    Post subject: Reply with quote
I took the control arms out of the beam and took them to a local front end shop. It took the mechanic about 15 minutes to press out the old ones and press in the new ones - $20 well spent... Cool
I can say "ol' fart" cuz I'm a ol' fart...
Len
Page 1 of 7
