Wheels and Tires...compiling a list...ever so slowly
Goto page 1, 2, 3  Next
vwthingboy
vwthingboy is offline
PostPosted: Thu Jul 27, 2006 8:00 am    Post subject: Wheels and Tires...compiling a list...ever so slowly Reply with quote
So, has anybody put together a list of issues related to changing wheels and tires?
Below is an initial cut at it, to be updated with input from the gallery...i.e. your expertise. (Items with "?" are in question)
Ideally we could put a list together of all wheels that will fit a stock setup and go from there.
Potentially, we could have a gallery of different wheels, listing any mods that have to be made in order to use them.
If I understand properly, the concerns are:
Wheel diameter: 14" vs. 15" or larger (some disk brake setups require 15" wheels due to large diameter brake rotor).
1973 and 1974 Mexican-built for the U.S Things came stock with 14" Thing-specific wheels, but 15" were available as an option. As early models were never mass imported to the U.S., the 15" rims are very rare. (from VeeWiki)
From TheThing.org: http://www.thething.org/frame37.html
From 1 March 1973 onwards VW 181s had unique 5JK x 14" wheels fitted with 185 R14 tyres. These VW 181-only (they have a 181- part number) are different from other 5JK x 14" VW wheels in two major respects:
1. The off-set dimension is greater than the other 14" wheels such as those used on the type 2. Use bus wheels on your VW 181 and everything will scrape a bunch.
2. The original VW 181 wheels are un-slotted, solid centred. All other 14" VW wheels are slotted.
From Hanno's site: http://www.geocities.com/vwtyp181/index.htm
Wheel width: Stock 14" wheels were 5" wide
Optional 15" wheels were 5.5"? wide (and can safely hold up to a 235mm? wide tire).
Aftermarket wheels range from 3.5" to 10" wide or more.
The issue with wide wheels and tires is rubbing on the front suspension, how the load is placed on the hub or lugnuts, and fender coverage.
Max tire size = ??
Tire Width: The original stock tire size was 185SR14. Both Continental and Goodyear were OEM suppliers.
1968-1972 German models had 165/15 tires on 4.5 x 15" rims; later models had 185/14 tires on 5 x 14" rims as original equipment.
It is commonly said that the widest tire that will fit on the front of a Thing with stock wheels, fenders, and ride height is a 205mm/75mm/15".
Additionally, a 185mm-width tire is about all that will fit under the hood as a spare.
The variables of tire size, wheel diameter, wheel offset, and front end ride height, all effect the maximum tire size without rubbing.
Stock lug diameter or "bolt pattern" or "bolt circle" is 5 x 205mm (or 8.07") also known as "Wide 5"
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=92
(The lug configuration can change with the use of different brakes or wheel adapters)
Wheel adapters change the lug pattern and add "unsprung" weight to the wheel/tire combo. Some people feel they are unsafe.
"Offset" which is the distance from the wheel's inner hub mounting surface to the centerline of the wheel.
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
(Stock Thing offset is ?? positive)
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. (From Tire rack)
Offset that is not correct can improperly distribute the car's load.
Wheel spacers change the offset, may require longer lugnuts and add "unsprung" weight. Some feel they are unsafe.
"Backspacing" is measured by laying the wheel face down and laying a straight edge across the diameter of the wheel then measuring to the wheel's hub mounting surface. The distance between the straight edge and the inner hub mounting surface is called "backspacing" or "backspace." That's where the measurements such as 4 .25 backspacing etc come from.
Old VW wheels can be difficult for tire shops to balance as the shops don't have an adapter to fit the wheels.
(If you have an old brake drum you can bring it with you to use for balancing?)
Old VW wheels are "Lugcentric":
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=91
The big hole in the center of the wheel gives the tire shops fits.
Improperly balanced wheels can create the "wobbling" phenomenon which creates shaking in the steering components and vibrates the steering wheel at around 50-55mph.
Lug seats of different wheels: the shape of the metal where the lug contacts the wheel
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=102
Stock lug nuts are 12mm? long
Wheel studs can be installed in brake drums or rotors. The wheel is held in place with wheel nuts that fit the studs.
Valve stems. Metal versus rubber?
Tire inflation levels. Stock PSI settings (19lbs in front) were based on old tire specifications, and may not apply to, and be too low for, modern tires. Or maybe the front tire pressure is spec'd so low because the weight of the Thing's front end is relatively low. This is a point of some (mild) controversy.
In general, a higher tire pressure improves steering response and handling, but also increases ride stiffness.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=1
Overall tire diameter should be selected based on type of engine and transmission used. A motor with more torque will offset the greater tire diameter just as well as lower gearing.
Some people use tires that are too large for the Thing's transmission. Offroad applications may use lower-geared transmissions.
In general, smaller tires have less rolling resistance and improve gas mileage.
Also, larger tires will effect the mph number shown on your speedometer.
If you are using larger tires, the number on the speedometer is lower than your actual speed. (Are there different speedo cables that account for this?)
Additional modifications that effect wheel and tire selection/applicability:
Front:
Different front beam (narrowed or widened)
http://www.thething.org/frame26.html
Beam adjusters which can raise and lower the front beam
Spindles different than stock - people switch out to lower the car
Rear:
Rear suspension modifications -
Adjusting the "splines" refers to the rear torsion bars and adjusting how the torsion bar plate attaches to them. Normally this method is used to raise the rear, for offroad applications or to correct the rear "sag" that occurs over time.
3" wider and 3" longer trailing arms are used on some offroad setups. Suspension mods can add "travel" to the system, which allows it to travel more vertically, up and down.
Ideally there could be a table correlating the variables of tire size, wheel diameter, wheel offset, and front end ride height, all of which effect the maximum tire size without rubbing.
I've probably left out a bunch of stuff.
Feel free to correct or add info.
-Sean in NYC
Captain Spalding
Captain Spalding is offline
PostPosted: Thu Jul 27, 2006 8:25 am    Post subject: Re: Wheels and Tires...compiling a list Reply with quote
I love the idea of a single thread that answers all these wheel related questions. Perhaps once this thread has run its course, you could distill all the info into a single post, and ask that it be made into a sticky.
Or maybe the front tire pressure is spec'd so low because the weight of the Thing's front end is relatively low. I think this is a point of some (mild) controversy.
Overall tire diameter should be selected based on type of transmission used. Some people use tires that are too large for the Thing's transmission. . .
Append to read "based on type of engine and transmission used." A motor with more torque will offset the greater tire diameter just as well as lower gearing.
I would add max tire size to the list. Ideally there could be a table corellating the variables of tire size, wheel diameter, wheel offset, and front end ride height, all of which effect the maximum tire size without rubbing. It would take some effort and cooperation, polling members of the board with different tire sizes and degrees of lowering, etc. But it would be worth it to have something definative.
Also compile a list of available wheels with 5x205 bolt pattern.
LEJ
LEJ is offline
PostPosted: Thu Jul 27, 2006 5:49 pm    Post subject: Reply with quote
vwthingboy wrote:
Offset" which is the distance from the hub to the wheel centerline, also called backspace
The first part is correct, offset is the distance from the wheel's inner hub mounting surface to the centerline of the wheel.
Backspacing is measured by laying the wheel face down and laying a straight edge across the diameter of the wheel then measuring to the wheel's hub mounting surface. The distance between the straight edge and the inner hub mounting surface is called backspacing or backspace.
The more you know, the more you know you don't know.
vwthingboy
PostPosted: Fri Aug 11, 2006 7:32 am    Post subject: Reply with quote
Mental exercise du jour:
The largest tire that will fit under a Thing is 205/75/15.
That tire should be 27" tall and 8" wide, so those would be your max dimensions.
(Math: 205mm/25.4=8.07"...8.07x.75=6.05...6.05x2=12.1"...12.1"+15"=27")
In theory, then, wouldn't a 205/60/17 tire be the same size overall?
That tire should be 26.7" tall and also 8" wide.
So, as long as the offset is correct, a 17" wheel could fit, no?
Or an 18", 19" or 20" wheel with lower profile tires, as long as you don't exceed the 27" by 8" limits.
And doesn't it also mean that you could use any wheel width, up to as large as 8" in the front without narrowing the beam or getting wider fenders?
(That French Thing in the classifieds, which may never sell, got me thinking)
Captain Spalding
PostPosted: Fri Aug 11, 2006 9:33 am    Post subject: Reply with quote
Don't run out and buy those tall rims yet . . .
Theoretically speaking what you are saying is correct. You can relax and forgo the mental exercise by using this nifty Tire Size Calculator. I compared three different sizes, and here are the results:
But theory and practice are often at odds, and such is the case in this situation. I sidled over to TireRack.com and did a search for 205/75R15. There were 31 tires available in that size. I also did a search for 205/60R17 and 205/55R18. There were ZERO results. That doesn't mean that tires in those sizes aren't available anywhere, but certainly your choices will be limited. Compromise will likely be required.
scamutz
scamutz is offline
PostPosted: Thu Aug 17, 2006 1:08 pm    Post subject: Reply with quote
While we're on Tires/Wheels...does anyone know of a supplier that is familiar with Thing wheels and the offsets?
I'd like to order some new wheels..Radars, or something similar. but don't want to go through the headache of having to explain the offset etc.
Anyone?
TIA
Mike in Tampa
'74 Thing - "Verna"
scamutz
scamutz is offline
PostPosted: Thu Aug 17, 2006 1:11 pm    Post subject: Reply with quote
http://www2.cip1.com/SearchResults.asp?Cat=1932
For instance....would these fit? They are apparently all 5x205mm
TIA
Mike in Tampa
'74 Thing - "Verna"
fisheye
fisheye is offline
PostPosted: Sat Aug 19, 2006 1:57 pm    Post subject: Reply with quote
I just purchased some wheels from CIP. I have not mounted them yet though. The backspacing is the key item you need to look at. I have 15x6 wheels with only 2.5 inches of backspace right now and they rub in the front. I just bought the 15x6.5 BRMs with 4.125 inches of backspace. This should move the outer edge of my tires in by nearly 1.5 inches (in theory). I will post the results when I get the tires mounted.
Stevec6x6
Stevec6x6 is offline
PostPosted: Wed Sep 06, 2006 2:39 pm    Post subject: Reply with quote
this thread rocks..
sticky this bad boy.
Ian Epperson
Ian Epperson is offline
PostPosted: Wed Sep 06, 2006 5:48 pm    Post subject: Re: Wheels and Tires...compiling a list Reply with quote
Or distill it into a wiki page:
http://veewiki.com/TheThing/Wheels
(not yet created, but ANY veewiki link will offer to create a new page)
If everyone is amenable, I'll repost it there.
Kubelmann has put up a wiki page on doing a disk brake conversion:
http://veewiki.com/K-mann_4_wheel_brake_conversion
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Wed Sep 06, 2006 7:56 pm    Post subject: Reply with quote
With Things, I think tire width becomes a problem before tire height. If you go out and peek under the fenders, there's plenty more room above, to the front of, and behind the tire. However, the tire can only get so wide before it gets close to the suspension-limiter-parts (dunno the real name) in back, and rubs against the front fenders when turning. Of course, make your front tires tall enough, and they'll rub on turns no matter how skinny. Smile
vwthingboy
PostPosted: Thu Sep 07, 2006 11:38 am    Post subject: Reply with quote
To me, the most confusing part of the issue is the backspace and offset.
I haven't found a definitive answer to what the stock Thing backspace and offset are.
I assume it's different for the 14" and 15" rims because they are different widths.
Those Rader rims from Cal Imports have a 3.25" backspace.
They are 5" wide rims, so the wheel centerline is at 2.5".
That must mean they have a .75" positive offset.
(Impressive math, eh?)
fisheye
fisheye is offline
PostPosted: Thu Sep 07, 2006 12:45 pm    Post subject: Reply with quote
If they are marked 3.25 in backspaced, the 5" rims the center would be 2.5 inches, however the face of the wheel that attaches to the drum will be 3.25 inches in from the outer edge of the inside lip of the wheel or 1.75 inches in from the outer edge of the wheel. How is that for a long run-on sentence?
fisheye
fisheye is offline
PostPosted: Thu Sep 07, 2006 6:18 pm    Post subject: Reply with quote
Here are my results on the 6.5 inch BRM style wheels from CIP1. I have 215x65x15's and they seem to fit in all areas except one. They rub very slightly on the end of the upper beam when the steering is turn all of the way to the right or left. The tires run - not the wheels. So far no fender rub in the front though! I may put 205's on the front to stop the rub if becomes a problem.
emersonbiggins
emersonbiggins is offline
PostPosted: Thu Sep 07, 2006 8:55 pm    Post subject: Reply with quote
235/45/17 tires
17" x 7½" rims
ET 35
Towel Rail
PostPosted: Thu Sep 07, 2006 9:33 pm    Post subject: Reply with quote
emersonbiggins wrote:
235/45/17 tires
17" x 7½" rims
ET 35
25.3" tall and 9.25" wide, if my math is correct. Are you running wheel adaptors, Ed, or does the backspacing take care of everything?
emersonbiggins
PostPosted: Thu Sep 07, 2006 9:40 pm    Post subject: Reply with quote
Drilled drums, no adapters.
On the back I had to countersink one of the spring plate bolts and cut a little off the snubber plate.
On front, I didn't have to change anything. Not even the stops for the steering box.
I am installing front discs now with beetle spindles.
Towel Rail
PostPosted: Thu Sep 07, 2006 9:46 pm    Post subject: Reply with quote
Is the snubber plate the bowl-like thing welded to the top side that contacts the rubber cone when the suspension bottoms out? If so, I've been wondering what that was called!!
Also, I wonder where the "fact" comes from that 205/75R15 is the largest tire that can be run, since people can (and do) run larger...
emersonbiggins
PostPosted: Thu Sep 07, 2006 9:56 pm    Post subject: Reply with quote
Snubber plate is just what I called it but you described it.
With my wheels, not much clearance along the back side. At the stock height, there is room to go taller.
scamutz
scamutz is offline
PostPosted: Fri Sep 08, 2006 12:55 pm    Post subject: Reply with quote
"Also, I wonder where the "fact" comes from that 205/75R15 is the largest tire that can be run, since people can (and do) run larger..
The first place that I ever saw it (years ago) was on the Thing Shop site.
http://www.thethingshop.com/faq.htm[/quote]
