Bay Window Front Nose Replacment
Page: 1, 2, 3  Next
Joey
Joey is offline
PostPosted: Tue Sep 19, 2006 2:19 am    Post subject: Bay Window Front Nose Replacment Reply with quote
I'm replacing the hole front of the van..
because there is some rust Laughing Shocked with this one.
There's no turning back now!
The new nose on.
Here's how I welded the inner structure of the 'A' pillars:
And here are the finish pillars:
The glass will go in Wednesday. Hope it fits Pray .
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
onion456
onion456 is offline
PostPosted: Tue Sep 19, 2006 4:10 am    Post subject: Reply with quote
looks great!
omg, i just *know* thats what mine looks like under the windshield seal.. *gulp*
cant wait to learn to weld... again looks great, thanks for sharin the pics!
dickcharlton
dickcharlton is offline
PostPosted: Tue Sep 19, 2006 12:44 pm    Post subject: Reply with quote
I need to do that too. I'm dreading it. Sad
MarkWard
MarkWard is offline
PostPosted: Tue Sep 19, 2006 1:22 pm    Post subject: Reply with quote
I cut the nose off of a 71 destined for the crusher for my 68. When I actually got to looking at the windshield area along with the dents from the bumper guards, I am now leaning towards a replacement panel. Hope the windshield fits up nice for you.
Joey
Joey is offline
PostPosted: Thu Sep 21, 2006 6:43 pm    Post subject: Reply with quote
The windshield is in ...sort of, it's a bit off center, toward the drivers side too much. I'll have to see if I can push it over somehow or maybe it'll settle in over time ..if not ..oh well. Top to bottom fits good though!
The doors are back on as well and line up perfectly.
The hardest part of the whole job was getting the wire for the dome light down the "A" pillar ..go figure!
Joey
Joey
Joey is offline
PostPosted: Tue Oct 17, 2006 12:47 pm    Post subject: Reply with quote
Here the finished product ..well, sort of.
Here's the pillars - no filler, just grounded down metal.
As you can see I'm not concerned about matching colors Laughing .
I still have a few spots to cover-up with some paint to protect from rust. I'm gonna give it a paint job next year ...flat black Cool hides everthing.
This van is only driven in the winter, so looks is not too important.
Joey
Adventurewagen
Adventurewagen is offline
PostPosted: Tue Oct 17, 2006 1:28 pm    Post subject: Reply with quote
Wow. Very nice. I'm in the process of filling my horribly dented front end with pounds of bondo for now and covering up the rust spots more or less. I took off the front wheel and decided i'd fix it up just a bit between now and when i cut off the front like you.
Any trouble detaching the dash and internal front pieces from the nose? Anything you would have done differently with cuts, welds or just plain anything?
Did you use an oxyacetylene torch for the welds? Great post.
63 Gulf Blue Notch
71 Sierra Yellow Adventurewagen
Joey
Joey is offline
PostPosted: Tue Oct 17, 2006 2:38 pm    Post subject: Reply with quote
The dash, vents, fusebox etc. just unscrews from the front of the van. Just keep track of what screw goes where. There was only one wire that I had to cut and splice back together - the rest just unplugged.
Everything went well ..wasn't really that difficult at all.
Take a lot of measurements from lots of different places for reference. examples: between the two door hinges on each pillar (14 1/16" if I remember correctly), top door hinge to the 'B' pillar. For the windshield opening, I found the middle of both the top and bottom of the opening and measured there vertically. Also from the middle I measured 22" over (left & right, both top and bottom) then measured vertically there.
The more reference points the better. When preparing the new nose, cut it oversized to fit at first then use a grinder take a bit off at a time until it fits just right ..measure 10 times - cut once! (my windshield opening ended up being 1/32" bigger ..not too bad!).
I cut the 'new' front nose from my old 79 westy over five years ago ..it took me this long to build up the courage to do this!
I used a MIG welder.
Joey
barefootwestie
barefootwestie is offline
PostPosted: Tue Oct 17, 2006 2:40 pm    Post subject: Reply with quote
Boy, in that 4th picture, you should have some great airflow. Only thing missing would be a flashlight in your lap to warn the oncoming drivers. Laughing
My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia
dwill49965
dwill49965 is offline
PostPosted: Tue Oct 17, 2006 2:48 pm    Post subject: Reply with quote
Looks great, Joey. Nice job.
Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote:
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent?
gmag69
Type2 Nutcase
gmag69 is offline
PostPosted: Tue Oct 17, 2006 11:24 pm    Post subject: Reply with quote
[quote="56ovalbug"]Here the finished product ..well, sort of.
ol: .
Man that is sweet. Smile I'm going to be putting a new nose skin on my 78 hopefully next spring. I'm going with a repo one from BD. The only bad thing is it's going to cost me almost as much to ship it as it is for the nose itself. Shocked Sad It will be worth it though. I'm probably going to get new rear quarters too and the middle rocker with the lower sliding door track already attached. I'd like to open my slider without it falling off all the time. Laughing It will be worth it in the end though. I still have to get the gallon of bondo off the drivers side floor that someone put on there and see how bad it is. Looks like that Mario guy they've been talking about in the Rants worked on it. Laughing Can't wait to get it solid again. It is a labor of love and another bus saved from the crusher.
Geno Very Happy
Check out my Westy resto. thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=230285
i_am_cool_fred
i_am_cool_fred is offline
PostPosted: Tue May 22, 2007 11:35 am    Post subject: Reply with quote
the before pictures would fall into the "when is a bay to far gone" thread. but man that finished product makes anything look like it has potential. good work
proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV
jeston
jeston is offline
PostPosted: Sun Sep 23, 2007 10:34 am    Post subject: Rust protection iside frames? Reply with quote
How do you protect against rust inside the frames and between metal pieces you weld together. I am doing a lot of work repairing some frames and floor sections on my bus and now that I have it all cut out and am ready to put it back together I want to do it right. For example I am replacing a U-chanel that connects to the rear outrigger to make a completely closed section and I am wandering how to protect the inside of the section. I bought it from Wolfsburg West and it comes with a primer on it but I am worried that when I weld it the Heat affected Zone will destroy the paint and welds rust so quickly. Do you use any corrosion protection between flanges and inside channels?
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Sun Sep 23, 2007 10:43 am    Post subject: Re: Rust protection iside frames? Reply with quote
Weld through primer.
aeromech wrote:
in my opinion you don't know shit
waterboy
waterboy is offline
PostPosted: Sun Sep 23, 2007 11:08 am    Post subject: Reply with quote
I have to do the same with mine, it's only the small panel piece directly under the windshield and not the entire skin. Question, what is the best way to cut the old metal out? Sawzall with metal blade? Or some other tool?
Joey
Joey is offline
PostPosted: Sun Sep 23, 2007 3:34 pm    Post subject: Reply with quote
All I used was a drill to drill out the spotwelds and a hacksaw to cut the 'A' Pillars, the rest was rusted free Razz .
An angle grinder with a cut-off wheel or a sawzall will work too.
Joey
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Tue Mar 31, 2009 9:08 am    Post subject: Reply with quote
Do you know if it can be transfered including the lower inner nose support? Or is it better to repair the lower inner support then transfer the outter skin or nose?
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Joey
Joey is offline
PostPosted: Tue Sep 13, 2011 2:54 pm    Post subject: Reply with quote
Well, it's been five years sine I replaced the nose on my '79 panel and it looks like it needs to be repaired already. I removed the windshield and found some rust. Not as much as I thought there would be but enough. I have the Gerson panel for the bottom but I'll have to make the pieces for the other rust holes. The perils of road salt....
Pics of the repair coming soon...
Joey
babysnakes
babysnakes is offline
PostPosted: Tue Sep 13, 2011 3:26 pm    Post subject: Reply with quote
Joey, you are a true bus pilot.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Tue Sep 13, 2011 3:53 pm    Post subject: Reply with quote
Damn, time to move.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
Page: 1, 2, 3  Next
