mak65 Samba Member
Posted: Mon Sep 04, 2006 12:02 am Post subject: 912 with type 4 engine |
| I have found a 912 with a type 4 engine, sounds like a good deal, been reading about this, is a type 4 an easy engine to find parts for, or should I just replace it with a type 1 engine. the engine doesn't run now, I am told the carbs are gummed up, Is there anything special that I need to know about this before I buy the car, the rest of the 912 looks to be in good shape, I have restored one before, but with a stock engine. please, some one provide some input. mark |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 2591 Location: Eastern WA
Posted: Mon Sep 04, 2006 1:19 am Post subject: 912 with type 4 engine |
Late 912's came with a type 4 from the factory , 912 E . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
mak65 Samba Member
Posted: Mon Sep 04, 2006 2:10 am Post subject: Re: 912 with type 4 engine |
| Teeroy wrote: |
| Late 912's came with a type 4 from the factory , 912 E . TROY |
So this car I want to buy is a 1966, 12 volt system, appears to be complete, Is there anything I should look for in the engine area that I should be concerned about or be aware of. |
69doublecab Samba Member
Joined: March 28, 2004 Posts: 2593 Location: Cedar Falls, Iowa
Posted: Mon Oct 09, 2006 9:54 am Post subject: |
If the conversion was done well, the type 4 engine is a very good fit. Make sure there is good sheet metal sealing around the engine. the gears will be a little low, the type 4 engine has more torque than either the 912 or 911 engine. either accept it or spend LOTS of money on higher ratio gears.
The type 4 engine is MUCH stronger than the type 1. sure, you can get a built up type 1 engine to make a lot of HP, but for how long?
Al _________________ Al Brase
1971 Dormobile
November 1955 (Wolfsburg) pickup WANT TO BUY ORIGINAL 15" BUS RIMS dated 2/55, 3/55, or 8/55, 9/55 or 10/55, OR ANY dated 1955- I'M DESPERATE!
69 doublecab (sold it!)
Vanagons |
newrider Samba Member
Posted: Fri Oct 28, 2011 9:31 pm Post subject: 912 with typeIV |
| I have a 1966 912 with a type IV engine. It has dual 40 idf webers. I thinking of putting on a set of 44IDF. It's a great car to work on; easy and inexpensive. |
