KMP Samba Member
Posted: Sun Oct 22, 2006 9:38 am Post subject: Type 1, Type 2, Type 3 - What's the Difference? |
Folks, new to this forum but not others so I know this question must have been asked before. I've searched and can't find a "no kidding" here's the answer. My question:
What are the differences between the Type 1, Type 2, Type 3 VW Westfalia?
I've been searching for one for my son, and the more I look, the more I want one. These things are neat! We currently are looking at a 1973 Westfalia which needs a couple parts so that's why I'm asking.
Thanks for being patient with me.
Kenny |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Sun Oct 22, 2006 9:50 am Post subject: |
Type 1 = Bug, Ghia, Thing
Type 2 = Bus
Type 3 = Squareback, Notchback, Fastback Type 3 Ghia
Type 4 = 411, 412 _________________ Glenn
Member #1009
#BlueSquare |
busnerd Samba Member
Joined: March 18, 2002 Posts: 336 Location: Vancouver, BC
Posted: Sun Oct 22, 2006 9:51 am Post subject: |
hey, check out this link here
http://en.wikipedia.org/wiki/Volkswagen_Type_2 (scroll down to the history part)
I think this is what you are looking for.. T1<'67, T2>'68, T3>'80 (all of these are sub categories of the Type II) _________________ Clarke B.
samba member # 3245
'78 Westfalia Dakota Beige
'64 Camper |
KMP Samba Member
Posted: Sun Oct 22, 2006 10:08 am Post subject: |
you guys made that to easy, or should i say, i was making it to difficult
and here i was thinking there was a difference from bus to bus. didn't realize it was based on different vw models.
the one we are looking at has a porsche engine that was put in it (it's a 1973). we haven't figured out yet what size engine but from my reading it may be a fair assumption that it's out of a 914. anyone know if it has the same starter? from an aftermarket website i was looking at it looks like it's the same, but realize we have to know what engine first.
thanks for the history link. as i mentioned before, just searching and reading up on these busses i'm getting hooked. |
Randy in Maine Samba Member
Posted: Sun Oct 22, 2006 10:16 am Post subject: |
From 1972-1979 all type 2's in this country came with a type 4 engine as did the 914.
Here is some fun reading. http://www.tunacan.net/t4/
A 73 would have come from the facotry with a a1.7L with 2 colex carbs. Engine code would have been "AW" with a compression ratio of 7.3:1 and 65 HP. |
KMP Samba Member
Posted: Sun Oct 22, 2006 10:22 am Post subject: |
you guys are to good. so a fair assumption is, the gentleman who decided to swap in a Porsche engine swapped in a 914. again, thanks for the pointing me in the right direction so i can do some reading. |
nemobuscaptain Samba Member
Posted: Sun Oct 22, 2006 10:23 am Post subject: |
Type 1= Beetle and ghia
Type 2= Transporter or truck
Type 3 & Type 4= like he said
BUT a Type 2 T1= splitty bus (67 and older)
Type 2 T2= breadloaf or bay window bus (68-79)
Type 2 T3= vanagon or maybe "wedge" to euros (80-91)
Type 2 T4= Eurovan up to a recent date (2003?)
Type 2 T5= new Eurovan
Of course, people often abbreviate Type 1 to T1 or Type 4 to T4. Confusing, eh?
Let me add that people also use T1 to refer to the upright 1600 style engine and T4 to refer to the 1700-2000 pancake or "suitcase" engine, and may therefore say T1 engined loaf bus (68-71) or a T4 engined late loaf bus (72-79). (Note late loafs busses also had 1600 Type 1 style engines in the rest of the world.)
SOOOO, it depends on the context. But these are the possible meanings. _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf |
steponmebbbboom Samba Member
Posted: Sun Oct 22, 2006 10:29 am Post subject: |
What redneck porch would be complete without a type IV engine on it.
If you dont see it right away, dig around behind the old water heaters and wood stoves. |
KMP Samba Member
Posted: Sun Oct 22, 2006 10:58 am Post subject: |
Quote: |
The Type 4 200mm, the 210mm, and the 215mm are all the same outside diameter and are basically identical with the exception of the clutch face diameter. |
Quote: |
For the average street Type 4 engine with a Type 1 transaxle, I recommend using any of the 200mm, 210mm or 215mm VW flywheels. They will all slide into a 12V bellhousing with little to no clearancing. |
Quote: |
The rest of this tech article will cover using a Type 4 engine with a Type 1 transaxle, as you can use the stock Porsche starter to finish the Porsche setup. |
Absent digging into it and being surprised Ithink above is my answer.
I also looked up starters on Auto Parts Warehouse and the OEM starter for the bus and Porsche 914 are identical:
Bus:
http://replacement.autopartswarehouse.com/parts/au...=Automatic
Porsche 914:
http://replacement.autopartswarehouse.com/parts/au...p;dp=false
At this point, I hope all that's left to figure out is if the engine is a 1.7, 1.8, or 2.0 litre. |
bd1308 Samba Member
Posted: Sun Oct 22, 2006 11:54 am Post subject: |
the 1.7 and the 1.8 engines from the 914 are directly from thier VW bretheren. The 1.7 came from the D-Jet type 4 and the 1.8 came from.....teh bus?
teh 2.0 had some bigger valves installed in it, and spark plug angles were changed, which made for more power and better fuel economy over the 1.8 |
