PHIL PRINZ Samba Member
Posted: Thu Dec 22, 2005 5:15 pm Post subject: wiring diagram for dune buggy |
i need a wiring diagram for a dune buggy. dont want to buy a new set of wires just to get the wiring diagram. thanks phil |
baja5 Samba Member
Joined: February 28, 2004 Posts: 4326 Location: Ramona,Ca.
Posted: Thu Dec 22, 2005 6:02 pm Post subject: |
Each dune buggy is typically different depending on what you run. There's not really much to wiring one. Positive, switch, load ground.What exactly are you trying to get wired up? |
USMCord1 Razorback
Posted: Fri Dec 23, 2005 10:42 am Post subject: wiring diagram |
im looking for charging system to and from battery, genarater, regulater,and fuse box. lights and ignition system is no problem i just need help with charging system thanks for your replys. |
UncleBob Grease Midget
Joined: August 21, 2002 Posts: 2862 Location: Northeast Florida
Posted: Fri Dec 23, 2005 11:10 am Post subject: |
Here's the Bugpack bag-o-wires harness.
Go here for individual circuit diagrams:
http://www.dune-buggy.com/techtips/wiring.htm _________________ OG JHC
don't worry, the ciggaret is fake. |
Posted: Sat Dec 24, 2005 12:27 am Post subject: thanks that was what i needed |
unclebob thanks for the info that was what i was looking for thank you very much |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Mon Oct 23, 2006 6:49 pm Post subject: |
Hi I am looking at the same wiring diagram that Uncle Bob posted above and this may be a dumb question but what I need to know is where does the red 12 guage wire (12R) coming from lug #50 off the ignition switch go to if I don't have a #50 on my starter? All I have is the #60 lug (solenoid) on my starter since it is a 12volt starter from a '72 bug. Do I just not use this red 12 guage wire (12R) wire? thanks _________________ 1963 Ragtop Bug |
Posted: Tue Oct 24, 2006 6:03 am Post subject: |
EMPIImp69 wrote: |
Hi I am looking at the same wiring diagram that Uncle Bob posted above and this may be a dumb question but what I need to know is where does the red 12 guage wire (12R) coming from lug #50 off the ignition switch go to if I don't have a #50 on my starter? All I have is the #60 lug (solenoid) on my starter since it is a 12volt starter from a '72 bug. Do I just not use this red 12 guage wire (12R) wire? thanks |
That wire goes to your solenoid. It's the 12V signal needed to engage the solenoid. The 'Start' wire.
You only need that wire if you want to start the engine from the driver seat. _________________ OG JHC
Posted: Tue Oct 24, 2006 7:01 am Post subject: |
Yea I figured it out last night after looking at a different schmatic..I had the wrong one going to the lug on the solenoid, thanks. _________________ 1963 Ragtop Bug |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Oct 24, 2006 7:05 am Post subject: |
Speaking of wiring diagrams, I built my buddies harness almost completely last night using my little guide. Simple. I put a chair in the kitchen, measured off 16ft and started pulling wire one by one. I would just twist tie the wire to the back of the chair and then just pull the wire to length and clip. I also printed, in MS word, a file that labels all wires with little Avery labels. I have the file if anyone wants it just email me. michaelmurzi "at" charter.net Here is my guide.
If anyone knows a site that will host the file, let me know.
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Tue Oct 24, 2006 7:10 am Post subject: |
Murzi you the man but what I already started doing was wiring up everything in the back and then I will cut everything to the correct length once I wire everything up to front near the fuse block, thx. _________________ 1963 Ragtop Bug |
Frontloader Samba Member
Joined: April 25, 2006 Posts: 79 Location: Brazoria County, Texas
Posted: Tue Oct 24, 2006 11:57 am Post subject: |
I have been using the wiring diagram shown above in rewiring my buggy.
I have the standard aftermaker switch which everyones sells that I will be using in place of the original.
The aftermarket switch has three connectors marked - Battery, Ignition, and Accessories. There is a center post that is not marked.
Will someone confirm for me the connection between battery, ignition and accessories and the numbers on the wiring diagram - 30, 50, and 15/54. My head hurts right now from studying these diagrams and trying to sort things out. However, color coding the diagram like Murzi did sure did help.
Also, would the center post on the new switch be used for anything? I have another wiring diagram which shows that center post connected to the fuse box and the battery terminal on the starter solenoid.
Hopefully I can eventually compare the two and figure the correlation out. |
MURZI Samba Member
Posted: Tue Oct 24, 2006 5:54 pm Post subject: |
Keep in mind the pic I posted was for my harness I built and not necessarily the "key" to the bag of wires. It is meant for someone to easily build thier own harness in one night. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Tue Oct 24, 2006 7:02 pm Post subject: |
Frontloader wrote: |
Also, would the center post on the new switch be used for anything? |
I don't have one of the ignition switches in my hand, but, if you're referring to the schematic I posted..
The Black 16AWG wires on switch are 'Ignition'. All tied together.
The 10AWG Red wires are considered 'Battery'. Tied together as well.
The last, smaller Red 12AWG wire is 'Start'. That must be the unmarked center post you're referring to.
And, accessory post is unused in this diagram. _________________ OG JHC
Posted: Wed Oct 25, 2006 6:48 pm Post subject: |
Uncle Bob
Thanks for the reply. Will give that a try and see how it matches up.
Ed |
streetbuggy8804 Samba Member
Joined: August 25, 2009 Posts: 652 Location: Placentia,ca
Posted: Sun Feb 14, 2010 9:45 am Post subject: |
Anyone using a 5 wire indicator switch? I have wired everything using this kit but it only shows wiring for a 3 wire indicator. I know the other wires are for the dimmer relay but I can not get the turn signals to work. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Feb 14, 2010 10:39 am Post subject: |
Is it a VW switch, or a aftermarket switch? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Feb 14, 2010 10:56 am Post subject: |
streetbuggy8804 wrote: |
Convert (wire ) it to 3 wire if its just for turn signals...
jspbtown Samba Member
Posted: Sun Feb 14, 2010 12:23 pm Post subject: |
Use a test light to determine which brings power into the switch, and then which leads are hot when you move the switch to the left and to the right. It should only take a few moments to figure that out.
As previously stated...use only three wires (power in, power to the left, power to the right). |
Posted: Sun Feb 14, 2010 2:10 pm Post subject: |
It is a stock vw turn lever. I wanted to use the dimmer function of it though. I believe it's off of a 71 beetle. I know I need to use a dimmer relay, just wondering if anyone has done it |
