FlyA181 Samba Member
Joined: August 14, 2006 Posts: 13 Location: Santa Cruz, CA
Posted: Fri Nov 10, 2006 10:55 am Post subject: Wiper Motor Maintenance |
Hello:
My wiper motor works but makes a lot of noise. has anyone taken theirs apart and given it the once over? How about putting grease or oil on the bearings? Can you replace the brushes? There is an electric motor rebuilding place here in town that I had rebuild my spa motor, perhaps I should drop off the wiper motor. Anyone else done the same thing? Any tricks? |
ztnoo Samba Member
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Sat Nov 11, 2006 9:55 pm Post subject: |
It sounds like you may need to rebuild it. The shafts on both sides should be greased with a good marine wheel bearing grease every 2 years or so, depending on what kind of wheather you drive in. Also the shaft seals should be checked and changed ( 3 bucks a pair) so that you don't get water inside the shaft bushing and rust them all up. This will smoke the motor for sure. Parts are difficult to find. The motor itself can be a real pain to repair, and seldom ever get put back togather right. It is very easy to loose the ting parts and hard to remember how they go back. The wiper motor can be a real challenge. I do rebuild them, so PM me if you would like to have it done. |
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Tue Nov 14, 2006 12:16 pm Post subject: wiper parts |
Do you sell the cut gaskets?
I just did a picture to make it easier, i dont know the technical terms for each of the parts
http://i10.photobucket.com/albums/a116/FreakCitySF/wiper.jpg
I'm looking for the outside wiring cover, anything less than 30.00 if you have them. (#1 )
Also the rubber gasket that goes under the wiper motor cover. ( #2 )
As well as the waxpaper gasket inside the motor. (#3)
Also the wiper arm/rod, the teeth on mine are a little work, do you have any of those in pretty good shape? ( #4)
http://i10.photobucket.com/albums/a116/FreakCitySF/wiper.jpg |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Nov 14, 2006 2:32 pm Post subject: |
Kubalmann rebuilds these I believe. PM him or he may pipe in on this thread to offer assistance. |
Posted: Tue Nov 14, 2006 8:53 pm Post subject: |
Pm me and I'll try to hook you up. Sounds like your up to your elbows in a little wiper motor maintenance. |
kubelmann Samba Member
Posted: Sun Nov 26, 2006 5:21 pm Post subject: |
For the record "Al Capulco" and 'Kubelmann" are friends and both repair/recondition/rebuild Thing wiper motors. Take my friendly advise and contact either or us to solve your wiper motor troubles. Neither of us do this as our "day job" We do it rather than attend "self help" sessions, hire a therapist or go into rehab..... Both of us love to make broken stuff work.
Life is not a problem to solve rather a wonder to behold.. |
mattt Samba Member
Posted: Wed Dec 13, 2006 12:23 am Post subject: |
kubelmann wrote: |
Kubelmann.....do you often refer to yourself in the 3rd person? |
Posted: Wed Dec 13, 2006 10:35 am Post subject: |
I was wondering if anyone could draw up the gaskets so i could transfer them to gasket material and cut my own. My orignals are gone.
chris |
Posted: Wed Dec 13, 2006 6:37 pm Post subject: |
Matt didn't you notice I shifted from 3rd person to first person plural. It was intended as a literary devise. Chris, I can make wiper motor gasket templates... pmail me |
