thom Samba Member
Joined: October 12, 2000 Posts: 4683 Location: Sacramento
Posted: Tue Dec 26, 2006 10:32 pm Post subject: Repro side trim - a case study |
A month or so ago, I bought a set of repro side moulding from KGPR. Then I saw that ISP West was making it in stainless, so I bought a set of that.
So, which do y'all think looks more correct?
The ISP stuff is definitely 'bigger' than the OG or KGPR stuff, but I don't know well enough to tell what it should look like. The OG piece used for ref is one of the random pieces of trim that came with my car.
 _________________ -Thom
Bus Registry
1952 Type 11c
1956 Single Cab
1957 23-Window Deluxe
1960 DD Panel
1956 Type 1 Karmann Ghia
1962 Type 3 Karmann Ghia
1963 Type 3 Karmann Ghia
1968 Single Cab |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 2791 Location: So. Cal. Oceanside GFK!
Posted: Tue Dec 26, 2006 10:50 pm Post subject: |
Are you sure the ISP West Stainless will work? I thought they only made the later model trim, not for the low-light. _________________ It's not about the window, it's about the people.
German Folks |
thom Samba Member
Posted: Tue Dec 26, 2006 11:06 pm Post subject: |
Thanks Thom, I'm calling Alex tomorrow  _________________ It's not about the window, it's about the people.
German Folks |
Lind Samba Member
Joined: November 06, 2000 Posts: 7478 Location: idaho
Posted: Wed Dec 27, 2006 12:24 am Post subject: |
I think that there are three different profiles of original trim. _________________ .
karmann57 Samba Member
Joined: October 22, 2004 Posts: 705 Location: Look up, waaay up...
Posted: Wed Dec 27, 2006 9:12 am Post subject: |
What are your first imperssions of the ISP s/s trim? I was really interested when I saw the ad, I have an older KGPR set and would definitely like something that will hold up better (bends and dings, the way it bulges where the clips are [yes probably incorrect clips...]).
From the pictures, assuming it fits properly, I personally would go with the ISP set.
Shane _________________ Karmann Ghia Owners of Canada |
waxhead Samba Member
Joined: January 19, 2004 Posts: 606 Location: Philly 'burbs
Posted: Wed Dec 27, 2006 9:21 am Post subject: |
What about the clips to attach the trim? - I've only seen plastic clips for sale, not the metal type that are on my '59. _________________ Mike B.
1976 Porsche 912E #1047
1976 Porsche 912E #1299
1974 Thing |
kingkarmann Samba Member
Posted: Wed Dec 27, 2006 11:29 am Post subject: |
The KGP&R trim looks "crisp" with nice sharp edges and more defined angles. They look "right" to me. The plastic clips leave a bit to be desired however If you decide to go with KGP&R here's a bit of info about their clips. They use this plastic clip that has a push pin in the middle that when pushed spreads the legs of the pin in the hole to allow the clip to grab on . There is very little tolerance for any material other than the metal and the paint over it. If you have skimmed filler near the holes or you have really heavy paint the clips won't seat properly. _________________ Retired Sambanista |
pbaptist Samba Member
Joined: January 02, 2005 Posts: 1075 Location: Netherlands
Posted: Wed Dec 27, 2006 12:32 pm Post subject: |
It is great to have a choice now.
From the pictures the KGP&R looks more correct with the sharper edges, but the ISP is probably more easy to install. Hard choice.
Did you know that the first style side moulding has a loose piece at the edges. Later (I don't know when this changed, but somewere at the end of 56) they were one piece.
Patrick _________________ Dutch Karmann-Ghia lover.
2* Karmann Ghia Coupe (1957, 1966 Pigalle)
2* Karmann Ghia Convertible (1958, 1971)
2* Rometsch Lawrence Convertible (nr 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database |
thom Samba Member
Posted: Wed Dec 27, 2006 12:45 pm Post subject: |
The ISP trim uses what I assume to be the same clips as the KGPR trim - little plastic H-clips.
The ISP trim is definitely beefier than the KGPR stuff. but the ridge profile isn't as sharp. The KGPR trim feels like it will kink if I breathe on it wrong.
I don't really know what is 'correct' for my car. Knowing my luck, my car is supposed to have the trim with the separate ends. I'll find those the day after I score a set of one-piece bumpers and matching guards
The ISP trim is slightly wider than the KGPR trim - what's up with that? Is that correct, or ??? _________________ -Thom
Bus Registry
1952 Type 11c
1956 Single Cab
1960 DD Panel
1968 Single Cab |
Posted: Wed Dec 27, 2006 4:02 pm Post subject: |
Hi thom,
I'am sure you will found then one day. Till then I think the KG&P strips are the most correct.
About the one piece bumpers: I know Jeff has a spare set or maybe only the rear bumper, and Joe Ruiz also has a rear onepiece bumper for sale.
Today I spoke another Dutch KG lowlight addict, who has a complete set on his car and also knows another set for sale. (He wouldn't tell me were ). So, There are some avialable.
joe comfort Samba Member
Joined: March 18, 2005 Posts: 370 Location: Lake Havasu, AZ.
Posted: Sat Dec 30, 2006 11:09 am Post subject: |
| Thom, which trim are you going to use? |
thom Samba Member
Posted: Sat Dec 30, 2006 1:05 pm Post subject: |
| joe comfort wrote: | | Thom, which trim are you going to use? |
Dunno yet. I like the durability of the SS pieces, but I think I prefer the more correct-looking aluminum bits.
I've been doing some research trying to find better clips, but so far, no joy... _________________ -Thom
Bus Registry
1952 Type 11c
1956 Single Cab
1960 DD Panel
1968 Single Cab |
coad  Samba Scapegoat
Posted: Sat Dec 30, 2006 2:08 pm Post subject: |
Thom, if you get a chance could you measure a piece and tell me the width of the ISP trim?
Are all three the same width? |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2657 Location: Now in Honea Path, SC
Posted: Sat Dec 30, 2006 2:10 pm Post subject: |
I have seen a posting (on another forum)
by Scott Dempster of KGP&R regarding the
bulges in the trim usually caused by those
plastic clips. His advice was to squeeze the
legs of the clips together somewhat, before
installing them into the body, using pliers or similar.
 _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
Posted: Sat Dec 30, 2006 2:15 pm Post subject: |
| coad wrote: | Thom, if you get a chance could you measure a piece and tell me the width of the ISP trim?
The ISP west ones are 13MM or 17/32" wide. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Sat Dec 30, 2006 2:35 pm Post subject: |
| lonotch wrote: | | coad wrote: | Thom, if you get a chance could you measure a piece and tell me the width of the ISP trim?
The ISP west ones are 13MM or 17/32" wide. |
thanks |
JeffL Samba Member
Posted: Sat Dec 30, 2006 5:28 pm Post subject: |
| pbaptist wrote: | It is great to have a choice now.
Patrick | Yea baby, you know your stuff! I still have my originals. I had a billet piece made to insert in some NOS pieces. Who does the original "bright plating"?
The profile of the KGPR seem to be the closest in thom's pics. |
thom Samba Member
Posted: Sat Dec 30, 2006 7:30 pm Post subject: |
| coad wrote: | | Thom, if you get a chance could you measure a piece and tell me the width of the ISP trim? |
I get 13mm for the ISP trim, 11mm for the OG trim, and 10.75 for the KGPR trim _________________ -Thom
Bus Registry
1952 Type 11c
1956 Single Cab
1960 DD Panel
1968 Single Cab |
gregson1 Samba Member
Posted: Sun Dec 31, 2006 3:48 pm Post subject: Repro side trim - a case study |
I have a '65 car with full set of the original interior and exterior trim. Jim at the House of Ghia used to refer to this early style trim cross section as the 'hatchet style' trim, due to it's fairly sharp angles. The early reproduction trip from KGPR is really very accurate in this regard for all pieces. I wouldn't hesitate to use it on my car to replace some or all of the aged pieces currently in place.
For a later '60's and '70's Ghia, the 'softly rounded' trim cross section pieces might be a bit more accurate. |
