wheels for 74 ghia
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
juki48
juki48 is offline
PostPosted: Thu Mar 15, 2007 10:03 am    Post subject: wheels for 74 ghia Reply with quote
I'm looking for wheels for my ghia. I work at a machine shop so I was thinking I would add a 4x100 bolt pattern to my exhisting disks and drums.
What combinations of size and offsets have worked for you?
I like these in 15's or maybe 16's but not sure if they'll fit.
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=97
Skim
Rants Master
Skim is offline
PostPosted: Fri Mar 16, 2007 4:45 pm    Post subject: Reply with quote
If you switch to 4x100 your choice is endless but make sure you narrow that beam because most modern rims are FWD and have an offset that requires it or else they will stick out.
52 Split Rag
54 Barndoor 23
GFK
My 61 Impala Vert Build Up Topic Pics
juki48
juki48 is offline
PostPosted: Mon Mar 19, 2007 4:47 am    Post subject: Reply with quote
I'm not sure about the offset. I'd love to hear from people who have done this themselves.
Won't FWD wheels be tucked in tighter than RWD? It looks like I have less room in the back of the ghia.
helowrench
helowrench is offline
PostPosted: Mon Mar 19, 2007 7:47 am    Post subject: Reply with quote
poke around in the ghia forum
This has been covered quite extensively.
Rob
68 ghia coupe
71 ghia coupe
70 bug vert
and looking
68 notch
69 ghia
volksartist
volksartist is offline
PostPosted: Mon Mar 19, 2007 8:19 am    Post subject: Reply with quote
6 x 16 et 50 will fit in the front if you are not too low with stock beam
7 X 16 et 40 will fit in back without mods
I have boxster wheels. Not sure about tuner wheels.
juki48
juki48 is offline
PostPosted: Mon Mar 19, 2007 9:17 am    Post subject: Reply with quote
thanks for the reply. that helps with sizing. do you think the 16x7's would fit in the front? ever tried it?
volksartist
PostPosted: Mon Mar 19, 2007 10:22 am    Post subject: Reply with quote
The only way I could see would be with a two inch narrowed beam
and a whiteline style sway bar or no sway bar. It would rub on the inside.
Depending on the height you choose you may have to go to 45 profile
tires to prevent rubbing.
Good luck. 15's are easier because tires are more available for less $$
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
