VW sandrail frontend CLAP?
runner4wheelin
runner4wheelin is offline
PostPosted: Wed Mar 21, 2007 7:31 pm    Post subject: VW sandrail frontend CLAP? Reply with quote
So yah... i was on dunebuggy.com and they said it was an older type of buggy, and they directed me to here. I was wondering what kind of sandrail this is, what kind of clamp this is, and where i could get a clap that would work on this beast. lol thanks Cool
After the paint job...
The clamp....
View user's profile Send private message Visit poster's website MSN Messenger Classifieds Feedback
DavidLH
DavidLH is offline
PostPosted: Wed Mar 21, 2007 9:43 pm    Post subject: Reply with quote
Looks like an old Hi-Jumper frame and clamp. San Fernando Buggy Center was the manufacturer. Originally the name was cast into the clamp, yours was probably ground off by a previous owner?? SFBC was sold, relocated (Canyon Country,CA) and renamed Prowlers around the early 90's? NOBODY will have those clamps Sad. Hope you didn't powderpaint that frame, because here is the solution. Go over to the VW shop in Redding (on Parkview) and get some standard buggy beam clamps ($2.50 @ at most shops). If that shop doesn't stock them, they can order them from BugPack. Cut off the old clamps and weld on the new ones. Problem solved!
runner4wheelin
PostPosted: Thu Mar 22, 2007 7:57 am    Post subject: Reply with quote
Thanks dude... i will check up on those clamps hopefully this weekend. Im not sure what powderpaint is, we used regular paint (rustoleum) with paint thinner with a spraygun thats all i know. Why weld the clamps? why not just bolt them, wont they work just as good?
NKayser
NKayser is offline
PostPosted: Thu Mar 22, 2007 8:15 am    Post subject: Reply with quote
if you cant find one, Im sure if you brought the old one into a machine shop they could make one for you.
Its just a chunk of aluminum (maybe?) and a little mill work.
just food for thought,
Nick
Warrior buggy project, making progress
e-mail - [email protected]
DSTMULE
DSTMULE is offline
PostPosted: Thu Mar 22, 2007 12:37 pm    Post subject: Clamp Reply with quote
You know somebody has one of those clamps sitting in / under there pile of junk...good parts they have been saving forever. You just have to find them or they find you.
takotruckin
SUPER Baja
takotruckin is offline
PostPosted: Thu Mar 22, 2007 1:02 pm    Post subject: Reply with quote
how bad do you want it?
http://www.thesamba.com/vw/classifieds/detail.php?id=404610
Member of the baja's that don't run club, for now!!
DavidLH
DavidLH is offline
PostPosted: Thu Mar 22, 2007 7:47 pm    Post subject: Reply with quote
You need 8 clamps total. When you see the regular beam clamps you will see you must weld 4 of them on your frame (after cutting off your old clamps). I mentioned powderpaint because if you did it, you would have to ruin it to modify your front end. Since you painted it, your okay and can easily retouch after welding on the new clamps. I would suggest a couple of diagonal braces on the floor just behind your beam. I always see them on rail frames, maybe yours were removed by the previous owner...... Can someone please post a pic of a factory frame to show what I am talking about? I don't have a computor and can't post pics Sad.
rickosuave1987
rickosuave1987 is offline
PostPosted: Thu Mar 22, 2007 9:45 pm    Post subject: Reply with quote
Here is a pic of the clamps he is talking about.
One set would need to be welded in place of those stock ones and the other bolted to them to clamp down the beam.
'69 Baja Bug
STFU
rickosuave1987
PostPosted: Thu Mar 22, 2007 9:48 pm    Post subject: Reply with quote
And here is a pic of them installed
and another closer one
'69 Baja Bug
STFU
DavidLH
DavidLH is offline
PostPosted: Thu Mar 22, 2007 9:59 pm    Post subject: Reply with quote
Rick, thanks for posting the pics. Also if you look close it also shows the diagonal braces I suggest adding to the floor.
cobhc619
cobhc619 is offline
PostPosted: Thu Mar 22, 2007 11:34 pm    Post subject: Reply with quote
on that last pic the aluminum beam on that rail looks tweaked...kinda like its smiling Smile
1970 Baja
1973 Westy
jps1145
jps1145 is offline
PostPosted: Fri Mar 23, 2007 11:24 am    Post subject: Reply with quote
You can make a matching clamp out of a piece of channel iron. I had to do that for my old buggy. I had a similar set up.
Get a piece of channel that is 1" wide with 1-1/2" legs and cut semi circles out on the sides and drill matching holes and bolt it up. No sweat. You can weld up caps on the ends to clean it up.
Tehachapi, CA
'69 Baja
Vintage Funco single seater
My Baja
rickosuave1987
PostPosted: Fri Mar 23, 2007 11:41 am    Post subject: Reply with quote
Laughing Yea, he is the self proclaimed "Wheelie King"
And about the channel, that sounds like a good idea, and you already have 1 clamp you can use as a template right?
'69 Baja Bug
STFU
runner4wheelin
PostPosted: Sun Mar 25, 2007 12:52 am    Post subject: Reply with quote
so far... rough look
runner4wheelin
PostPosted: Sun Mar 25, 2007 1:03 am    Post subject: Reply with quote
Got a 15.5 gal keg for the gas tank. That thing is FRIKEN heavy full. Im a big dude and i was straining. Im thinking it might be alot of weight on the rear but the front end and 2 dudes kinda even it out a tad. lol or... we will just be doing wheelies down hills not pressing the gas
rterfert
rterfert is offline
PostPosted: Sun Mar 25, 2007 10:45 am    Post subject: Reply with quote
I just stumbled across your post Rolling Eyes
If you havent found one yet?
they should say highjumper on the front
I have a set from an old school frame I probably wont put back together.
shot me an email
