JohnF Samba Member
Joined: March 07, 2005 Posts: 28 Location: Phoenix, Az.
Posted: Tue May 08, 2007 8:01 am Post subject: Need something better for aircleaner Weber Progressive |
I use my Thing 99% in the desert and have a Weber Progressive that I can't keep sealed worth a damned. I have the taller rectangular filter with the crap tin upper and lower mount that won't seal worth a darn. I have a pre-filter over the assembly too but even with 45 lbs of grease trying to seal the top and bottom I still get a regular mud-bog inside the filter. I machined an aluminum spacer to space the lower tin up away from the lumps on top of the carb so the lower tin would sit flat without that 1/4 inch fiber gasket that I can't find locally. I machined an upper and lower aluminum cover to replace the cheap chrome tin pcs but I couldn't get the bolts in there to screw it to the carb because of the clearance problem between the top of the assembly and the body sheetmetal above the carb area (still working on that one). I tried using the stock Weber aircleaner clips to hold it together but they won't open enough to allow for the extra thickness of the aluminum plates.
I saw an assembly online at RedLine that would let me mount a remote aircleaner but am not sure of accessability to get in in and clearance for the unit, anybody seen or better used one of these?
I just put in a new top end and am tired of sucking so much dirt.
Any ideas??
JohnF
Phoenix. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Tue May 08, 2007 8:17 am Post subject: |
Is there a reason you can't go back to the stock oil bath? Sounds like you've done a bunch of work - $175 + shipping may start to sound cheap.
You can throw a ton of dirt into it and it just asks for more.
http://www.thethingshop.com/detail.asp?PRODUCT_ID=181129613B
JohnF Samba Member
Posted: Tue May 08, 2007 8:32 am Post subject: |
[quote="Ian Epperson"]Is there a reason you can't go back to the stock oil bath? Sounds like you've done a bunch of work - $175 + shipping may start to sound cheap.
I may use my stock airbox if that adaptor at RedLine will fit OK.
JohnF |
