J Flare Samba Member
Joined: September 27, 2004 Posts: 309 Location: San Diego
Posted: Sat May 26, 2007 2:54 pm Post subject: Where does this go ... |
I don't know where this is supposed to be plugged into. My backup lights don't work so I suspect it has something to do with them?
LUNATIK Samba Member
Joined: July 02, 2005 Posts: 309 Location: California
Posted: Sat May 26, 2007 3:06 pm Post subject: Re: Where does this go ... |
J Flare wrote: |
I have the same question but I know that doesn't have to do with the backup light. I think that cable is for the tranny sensor, I haven't seen one installed yet but I heard that Things use to be equiped with a flywheel sensor for something. My best explanation
But if someone have an idea for what that thing is used for ?? I'll be happy to know about it too.
Regards |
Posted: Sat May 26, 2007 3:52 pm Post subject: |
Well as long as im at it.......
Shouldn't I be able to run a single wire from the sensor on the trannie (located on the front side) to the coil for the back up lights??
I did this and get nothing? |
74 Thing Samba Member
Posted: Sat May 26, 2007 5:02 pm Post subject: |
To answer your questions-that box in the upper right of your engine compartment is for the VW Diagnostic test-they used to have a computer to plug into that and it would give them info on your cars system-it is in the back of the Bently Manual under the FI section. The Thing did not have a flywheel sensor-that was for FI.
Too hook up your reverse lights run a wire from you + side on your coil with an in line fuse to the reverse light switch on the nose cone of your tranny and hook to one of the terminals. Fron the other terminal run a wire to your reverse lights. Turn your ignition key to the 1st stop and put your car in reverse and go check-it should be working-if not then get out a volt meter or test light to verify that you are getting power to the switch and then from the switch. Also check your reverse bulbs. |
Posted: Sat May 26, 2007 5:25 pm Post subject: |
Thank you!
Where do I hook the wire on the reverse lights? I would have to think that there is an existing exposed connection.
Just to the left of the air cleaner in the pic by the red wire I have a black plug that comes from the wiring loom. My guess is that for the reverse lightd to plug into? |
Posted: Sat May 26, 2007 7:37 pm Post subject: |
OK this is how it goes...the orig wire that ran from the + side of the coil to the reverse switch was black in color. Remember you need to put an in line fuse here just in case something shorts!! The wire running from the other terminal on the switch is also black. It runs up by the starter and in a wire loom behind the oil bath cleaner and to a 4 plug terminal on your passenger rear light. You should be able to grab the 4 plug terminal which lies just below your rear light-put you hand inside the engine compartment and at the bottom of the light assembly should be a wire loom that is connected to the inside of the engine compartment body with wire holders. At the bottom of the engine compartment should be the 4 wire terminal. The blue wire is for the reverse lights-it should tee off on one side with one wire going to the passenger light and the other running hidden in the metal to the drivers side reverse light. The other side of this terminal for the blue wire should be connected to your reverse light wire. It may be easier to remove the oil batsh cleaner and trace some wires and secure everything properly. Let us know how it goes! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sat May 26, 2007 7:40 pm Post subject: |
That rubber 2 wire plug is for the induction sensor that goes on the #1 spark plug wire and is tied to the diagnostic port. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat May 26, 2007 8:00 pm Post subject: |
That was it!!!
Hooked em and they both work. Took it for a spin around the block in reverse
Thanks for the help!!! |
