1973vwthing Samba Member
Posted: Wed Jul 18, 2007 4:38 pm Post subject: turn signal help? |
after i make turn signals won't click off...is there an adjusment so when i turn the wheel back t he turn signal lever springs back to off position?..thanks again!!! |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Wed Jul 18, 2007 4:41 pm Post subject: |
Sound like time for a new switch. There are two little ears for the cancel system and they break off, but sometimes just need lubed. In rare cases the tooth on the steering wheel breaks off. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Wed Jul 18, 2007 7:51 pm Post subject: |
so i will need to take off steering wheel and such to see condition of switch? |
74 Thing Samba Member
Posted: Wed Jul 18, 2007 11:18 pm Post subject: |
Yep, the cancellation tabs are on the turn signal switch. Remove the steering wheel and turn on the switch and you will see the cancellation tab come out on the side it work and probably broken or worn out on the side that does not. |
