bad headlight
jimmyrock
jimmyrock is offline
PostPosted: Thu Jul 19, 2007 5:39 pm    Post subject: bad headlight Reply with quote
So, my passenger headlight is out on my '72 vert. The high beam works but not the regular light. I changed the headlight and unfortunately, the same thing happens. Any ideas?
68ghia
68ghia is offline
PostPosted: Thu Jul 19, 2007 5:41 pm    Post subject: Reply with quote
Check the usual suspects... connections, fuses, grounds. If it's only one headlight I suspect you have a wire loose somewhere.
1968 Ghia coupe
"no, no.... they come in peace!"
iowegian
Samba Curmudgeon
iowegian is offline
PostPosted: Thu Jul 19, 2007 6:02 pm    Post subject: Reply with quote
There are 4 headlight fuses: high left; low left; high right; low right.
jimmyrock
PostPosted: Fri Jul 20, 2007 5:23 am    Post subject: Reply with quote
great, thanks for the help.
70 140
70 140 is offline
PostPosted: Fri Jul 20, 2007 6:46 am    Post subject: Reply with quote
I find that the wiring harness from the passenger side lights are a little shorter then I like. Check that the yellow wire didn't pop off the fuse terminal.
FiremarshalBill
FiremarshalBill is offline
PostPosted: Sat Apr 14, 2012 6:56 am    Post subject: Reply with quote
I had a similar problem recently, but it was only the left hi-beam that wasn't working. After I pulled the headlight and tested it (worked fine), checked the wiring behind the dash for continuity and/or a loose connections (everything was fine), I finally broke out the wiring diagram (graciously provided by Samba) and realized that the left and right hi-beams went to different fuses. It was only then that I checked the fuse box under the dash and found #3 fuse missing (it had simply popped out and rolled under the edge of the floor mat). Now, don't I feel pretty stupid? Embarassed I'm reminded again that when working with an automotive electrical system, the FIRST thing to check is the fuses!
Firemarshal Bill
1970 Karmann Ghia Convertible
www.ACAircraft.com
