shifter
90runner
90runner is offline
PostPosted: Thu Jul 26, 2007 7:01 am    Post subject: shifter Reply with quote
Does the Thing use a the same shifter as the Beetle? Mines in rough shape and I want to put an after market one in.
markie61
markie61 is offline
PostPosted: Thu Jul 26, 2007 7:47 am    Post subject: Re: shifter Reply with quote
Yes. I have an Empi triggershift that works great.
Mark
Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 26, 2007 7:50 am    Post subject: Re: shifter Reply with quote
Mark
But for how long?
Before just buying a cheap aftermarket shifter, do some research. some are better than others. If you have the money and never want to buy another shifter, then buy a Berg. A good used Hurst is also a great option.
Read this: http://www.thesamba.com/vw/forum/viewtopic.php?t=244786&highlight=empi+shifter
Glenn
Member #1009
#BlueSquare
90runner
90runner is offline
PostPosted: Thu Jul 26, 2007 7:57 am    Post subject: Reply with quote
I've been looking at Hursts and EMPI trigger shifters as a replacement. And now reading about the EMPI I will skip that one.
markie61
markie61 is offline
PostPosted: Thu Jul 26, 2007 8:30 am    Post subject: Reply with quote
Alrighty, then....
...works great - for now....
Mark
Mr. 010
Glenn is offline
PostPosted: Thu Jul 26, 2007 8:33 am    Post subject: Reply with quote
markie61 wrote:
Alrighty, then....
Mark
Wait for the rivets to pull out. Be proactive and replace them with bolts now so you don't get stuck offroad with a long walk home.
Glenn
Member #1009
#BlueSquare
lowsquare
lowsquare is offline
PostPosted: Thu Jul 26, 2007 9:08 am    Post subject: Reply with quote
Any issues with the SCAT shifter? That's what I've got in mine. It's not an off road vehicle, but it is my daily driver. I've had no problems and really like how it works thus far... I'd recommend it based on how it has performed for me!
PRAISE THE LOWERED.
1973 THING
Ian Epperson
Ian Epperson is offline
PostPosted: Thu Jul 26, 2007 9:28 am    Post subject: Reply with quote
Glenn wrote:
markie61 wrote:
Alrighty, then....
Mark
Mine pulled out and left my shifter dangling when I was downshifting to pull into my driveway! Parked in its spot, so it was luckily a short walk home. Very Happy I pulled apart the shifter and found the failed rivets, so I cleaned it and replaced those cheap rivets with bolts and lock washers.
It had lasted about 6 years.
uberautowerks
uberautowerks is offline
PostPosted: Thu Jul 26, 2007 9:50 am    Post subject: Reply with quote
The Scat shifters (while not my favorite) last forever, even longer if you apply some grease to the internals every so often!
--- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black)
markie61
markie61 is offline
PostPosted: Thu Jul 26, 2007 10:44 am    Post subject: Reply with quote
Glenn wrote:
markie61 wrote:
Alrighty, then....
Mark
Yikes! 'Nother item on the list!
Mark
oasis
oasis is offline
PostPosted: Sat Jul 28, 2007 12:40 am    Post subject: Reply with quote
If you don't like the T-handle of a Berg and don't want to wait for a Hurst in decent condition, get a CSP shifter. (CSP shifters come in T-handles, too)
And just to be clear, Hurst shifters should not include their Indy shifter that was offered for a while -- pure junk.
Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI
