vw auxiliary heater
volksie boy
volksie boy is offline
PostPosted: Fri Nov 30, 2007 8:06 am    Post subject: vw auxiliary heater Reply with quote
has anyone tried that vw auxiliary heater over at barney,s ? not the blower but the heater ? third one from the top ? vanity.qwestdex.com/barneysimportparts/page7.html
Paul D
Paul D is offline
PostPosted: Fri Nov 30, 2007 8:20 am    Post subject: Re: vw auxiliary heater Reply with quote
Nope, but fixed your link for you, you needed a capital P on Page Wink
http://vanity.qwestdex.com/barneysimportparts/Page7.html
NOVA Airhead
NOVA Airhead is offline
PostPosted: Fri Nov 30, 2007 8:27 am    Post subject: Reply with quote
It seems like it would take a while to get some heat waiting for the oli to get warm as I would assume this heater would require extra capacity. Also, I would wonder what this could do for the engine as it would take longer for the oil to warm.
It seems like a solution in search of a problem. There are easier and better ways to get heat in your car.
Ghia Owner Emeritus
volksie boy
PostPosted: Fri Nov 30, 2007 8:46 am    Post subject: Reply with quote
pdaoust thank you for correcting that Nova i was wondering the same things that you had mention . so i thought i would do some research so i could make the best decision before purchasing . hopefully somebody will be able to shed some light on this .
Air-Cooled Head
Air-Cooled Head is offline
PostPosted: Fri Nov 30, 2007 10:55 am    Post subject: Reply with quote
I've not tried this also.
But if you're looking at alternatives, here's another.
http://www.thesamba.com/vw/forum/viewtopic.php?t=218662
(Haven't tried this one either.)
Everything known to man has been written.
Readers are Leaders!
DrDarby
DrDarby is offline
PostPosted: Fri Nov 30, 2007 11:26 am    Post subject: Reply with quote
In a cold climate you'll never get an oil cooler hot enough to heat the car. On top of that you'll have the engine in and out every time the seasons change to re-install the oil cooler or risk killing the engine. VW's conventional heater puts out quite enough heat if it is all hooked up properly and the car is not rotted out.
Midwest Autosavers, Inc. Woodstock, IL
jaymonkey
jaymonkey is offline
PostPosted: Fri Nov 30, 2007 6:18 pm    Post subject: Reply with quote
I have a 1500W inverter and a 1500W heater. Heater is 120V and draws about 15AMP, I haven't had any issues and it works well. Make sure you have a really good battery.
Bruce
Bruce is offline
PostPosted: Fri Nov 30, 2007 8:51 pm    Post subject: Reply with quote
No it doesn't. The laws of physics prove you wrong.
Patty B.
Patty B. is offline
PostPosted: Fri Nov 30, 2007 11:55 pm    Post subject: Reply with quote
DrDarby wrote:
... VW's conventional heater puts out quite enough heat if it is all hooked up properly and the car is not rotted out.
So true--my original heating in my '69 almost melted my shoe one spring!
volksie boy
PostPosted: Sat Dec 01, 2007 5:42 am    Post subject: Reply with quote
just how many generaters /alternaters are you running at the same time ? sorry jay but i know better i had a 700w intervter and a 500w heater 3 days later i had to replace my gen. Crying or Very sad
volksie boy
PostPosted: Sat Dec 01, 2007 5:54 am    Post subject: Reply with quote
i was looking to add extra heat but not use it as the primary heat. i,d really have to remove the engine every season just to re-install ? ouch Rolling Eyes as for killing the engine it,s already about gone but have a rebuilt replacement so that, i wouldn,t mind to bad however i don,t understand how it would kill it . would you explain this to me in a little bit of detail ?
volksie boy
PostPosted: Sat Dec 01, 2007 5:59 am    Post subject: Reply with quote
believe it or not air cooled head i just installed that about two weeks ago , on pg 2 you,ll see where i left my 2 cents on the post .
