volksie boy Samba Member
Posted: Fri Nov 30, 2007 8:06 am Post subject: vw auxiliary heater |
has anyone tried that vw auxiliary heater over at barney,s ? not the blower but the heater ? third one from the top ? vanity.qwestdex.com/barneysimportparts/page7.html |
Paul D Samba Member
Joined: July 30, 2006 Posts: 565 Location: Far away from the fruits & nuts
Posted: Fri Nov 30, 2007 8:20 am Post subject: Re: vw auxiliary heater |
volksie boy wrote: |
Nope, but fixed your link for you, you needed a capital P on Page
http://vanity.qwestdex.com/barneysimportparts/Page7.html |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Fri Nov 30, 2007 8:27 am Post subject: |
It seems like it would take a while to get some heat waiting for the oli to get warm as I would assume this heater would require extra capacity. Also, I would wonder what this could do for the engine as it would take longer for the oil to warm.
It seems like a solution in search of a problem. There are easier and better ways to get heat in your car. _________________ Ghia Owner Emeritus |
Posted: Fri Nov 30, 2007 8:46 am Post subject: |
pdaoust thank you for correcting that Nova i was wondering the same things that you had mention . so i thought i would do some research so i could make the best decision before purchasing . hopefully somebody will be able to shed some light on this . |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Fri Nov 30, 2007 10:55 am Post subject: |
I've not tried this also.
But if you're looking at alternatives, here's another.
http://www.thesamba.com/vw/forum/viewtopic.php?t=218662
(Haven't tried this one either.) _________________ Everything known to man has been written.
Readers are Leaders! |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Fri Nov 30, 2007 11:26 am Post subject: |
In a cold climate you'll never get an oil cooler hot enough to heat the car. On top of that you'll have the engine in and out every time the seasons change to re-install the oil cooler or risk killing the engine. VW's conventional heater puts out quite enough heat if it is all hooked up properly and the car is not rotted out. _________________ Midwest Autosavers, Inc. Woodstock, IL |
jaymonkey Samba Member
Posted: Fri Nov 30, 2007 6:18 pm Post subject: |
I have a 1500W inverter and a 1500W heater. Heater is 120V and draws about 15AMP, I haven't had any issues and it works well. Make sure you have a really good battery. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17288 Location: Left coast, Canada
Posted: Fri Nov 30, 2007 8:51 pm Post subject: |
jaymonkey wrote: |
No it doesn't. The laws of physics prove you wrong. _________________
Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
Posted: Fri Nov 30, 2007 11:55 pm Post subject: |
DrDarby wrote: |
... VW's conventional heater puts out quite enough heat if it is all hooked up properly and the car is not rotted out. |
So true--my original heating in my '69 almost melted my shoe one spring! |
Posted: Sat Dec 01, 2007 5:42 am Post subject: |
jaymonkey wrote: |
just how many generaters /alternaters are you running at the same time ? sorry jay but i know better i had a 700w intervter and a 500w heater 3 days later i had to replace my gen. |
Posted: Sat Dec 01, 2007 5:54 am Post subject: |
DrDarby wrote: |
In a cold climate you'll never get an oil cooler hot enough to heat the car. On top of that you'll have the engine in and out every time the seasons change to re-install the oil cooler or risk killing the engine. VW's conventional heater puts out quite enough heat if it is all hooked up properly and the car is not rotted out. |
i was looking to add extra heat but not use it as the primary heat. i,d really have to remove the engine every season just to re-install ? ouch as for killing the engine it,s already about gone but have a rebuilt replacement so that, i wouldn,t mind to bad however i don,t understand how it would kill it . would you explain this to me in a little bit of detail ? |
Posted: Sat Dec 01, 2007 5:59 am Post subject: |
believe it or not air cooled head i just installed that about two weeks ago , on pg 2 you,ll see where i left my 2 cents on the post . |
