Douglas Denlinger Samba Member
Joined: May 23, 2003 Posts: 1091 Location: Arizona's version of the east coast
Posted: Sat Jan 26, 2008 11:33 am Post subject: |
| Quote: | 2. Under the front seat - ie any little feet on the cab seatbase? Any (painted area) sound deadening material? Rubber stops (on the painted area)?
Thanks
RS |
Here's the next set of photos for reference:
No sound deadening on the front seat stands, no evidence of any...ie glue, etc. BTW that's not rust it's the dust from the OG horse hair padding
There appears to have been rubber stops (round stops based on paint discoloration around the 4 holes)
Posted: Sat Jan 26, 2008 11:40 am Post subject: |
| Rusting Hulk wrote: | | Doug does it still have an ashtray on the back of the middle seat? I would also be interested to see the front seat bracket on the bulkhead. |
Hope this helps _________________ Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986 |
crxgames Samba Member
Joined: October 02, 2007 Posts: 142 Location: Walton, Kentucky
Posted: Sat Jan 26, 2008 11:42 am Post subject: |
| That is one sweet/clean bus. Glad it went to someone who seems to care about it. |
RockStock Samba Member
Joined: November 26, 2004 Posts: 2584 Location: England
Posted: Sat Jan 26, 2008 11:47 am Post subject: |
More:
7. Rocker/Sill detail - both sides - any drain holes along the outer edge?
8. Inner wheel arch colour/s - front and rear
9. Evidence of SWR overspray on outer belly pans
| 23 window collection wrote: | | There appears to have been rubber stops (round stops based on paint discoloration around the 4 holes) |
yes, mine still has a couple of these black bungs _________________ -StockRocks- |
Posted: Sat Jan 26, 2008 11:50 am Post subject: |
| RockStock wrote: | | 23 window collection wrote: | | There appears to have been rubber stops (round stops based on paint discoloration around the 4 holes) |
yes, mine still has a couple of these black bungs |
Pictures? _________________ Transporter Restorations
Upholstery Haus
Posted: Sat Jan 26, 2008 11:51 am Post subject: |
| 23 window collection wrote: | | RockStock wrote: | | 23 window collection wrote: | | There appears to have been rubber stops (round stops based on paint discoloration around the 4 holes) |
Pictures? |
Yes, I'll take some _________________ -StockRocks- |
Posted: Sat Jan 26, 2008 12:01 pm Post subject: |
Additional photo in gallery _________________ Transporter Restorations
Upholstery Haus
Posted: Sat Jan 26, 2008 12:07 pm Post subject: |
Anyone ever see this stuff???
Sound deadening?
Upholstery Haus
Last edited by Douglas Denlinger on Sat Jan 26, 2008 12:10 pm; edited 1 time in total |
Posted: Sat Jan 26, 2008 12:08 pm Post subject: |
| RockStock wrote: |
4. The Glass Sekurit iogos - fixed side glass/front screens/cab door windows/skylights |
All the glass in the bus is this logo. Except the corners which are still plexiglass. The windscreens appear to have been replaced. Would the windscreens be the same logo? In my earlier life experiences with BD's two 52's I owned had the large block logo. I would think by 55, the US DOT probably required something other than the German Sekurit??? Any thoughts??
Upholstery Haus
campingbox  Samba Member
Joined: November 14, 2000 Posts: 8053 Location: Olympia, Washington
Posted: Sat Jan 26, 2008 12:25 pm Post subject: |
If it's a U.S. spec bus then it should have Sigla, with logos in the outter corners. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 41905 Location: Phoenix, AZ
Posted: Sat Jan 26, 2008 2:03 pm Post subject: |
The front seat should have the little rubber pads. They are the same pads used on early post-Barndoor Buses. They are available new.
The 4 little feet on the front seat should stick straight down to prop up the front. Most of the ones I have seen are always bent underneath or broken off. If you drive the Bus for a long time, it's more comfortable for the seat to be propped up by the legs. _________________ How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
"Water is the only drink for a wise man" | "Communication prevents complaints" |
Drew Ogden Samba Member
Posted: Sat Jan 26, 2008 2:56 pm Post subject: |
Doug, a late US barndoor would likely have sigla front windshields, what are your logos?
Edit: sorry, just saw that Greggy mentioned the same thing |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2493 Location: San Diego, CA
Posted: Sat Jan 26, 2008 3:44 pm Post subject: |
Doug, nice bus.
Are your door pocket rivets sliver colored or brass?
Are you sure about the mileage being 10K? It is interesting that the bus lost its motor, got a respray and has shifter and pedal wear like it has seen more use. You would expect the speedo to have rolled on a bus with those characteristics. |
Posted: Sat Jan 26, 2008 3:50 pm Post subject: |
| Anchovy wrote: | Doug, nice bus.
I was talking to Barndoor Dave today and he remembers when Rick Madden bought that bus from Jack White. Dave said when they drove it up from Oregon after Rick bought it that they blew the tranny up coming off the freeway. Luckily it was only a few blocks from Rick's house.
Doug thinks it has 100,000 miles, meaning it's travelled just over 10K miles since being advertised in '88. |
Posted: Sat Jan 26, 2008 4:32 pm Post subject: |
| campingbox wrote: | | Doug thinks it has 100,000 miles, meaning it's travelled just over 10K miles since being advertised in '88. |
Of course, that seems to make more sense.
Did it come with the ambulance step from VW? |
Posted: Sat Jan 26, 2008 5:55 pm Post subject: |
Dougie - my bus' birth certificate says it was delivered to Riviera Motors, Portland, via San Francisco. Wonder if yours was the same
criminal masking effort on an og paint bus!
| campingbox wrote: | | Rick Madden bought that bus from Jack White |
was Rick the guy who had it for sale in the Hot VWs ad? _________________ -StockRocks- |
Posted: Sat Jan 26, 2008 6:21 pm Post subject: |
| 23 window collection wrote: | Anyone ever see this stuff???
Sound deadening?
from the 53/54 Workshop Manual:
Forest Find DLX (55):
Unk BD:
Swedish 54:
all the pics i have show the 5"(?) wide black strip stuff on the vertical firewall section...
whereas the arch covers and lower firewall area appear match yours _________________ -StockRocks- |
Posted: Sat Jan 26, 2008 6:48 pm Post subject: |
My '54 had a similar material under the front seat and helped to keep the springs from rattling on the sheet metal.
Posted: Sat Jan 26, 2008 7:19 pm Post subject: |
Schmeling's 54/55 Sunroof Standard
Sound deadening, same location
One of the 4 rubber bungs too, btm right of steering wheel
[Over-rated bus, I was told(;] _________________ -StockRocks- |
Posted: Sat Jan 26, 2008 9:18 pm Post subject: |
Where are the feet? ^^^
The rubber stops are no problem to locate.....cross that one off the list  _________________ Transporter Restorations
Upholstery Haus
