oibovveroi Samba Member
Posted: Fri Jan 11, 2008 7:17 pm Post subject: going from wide five back to stock four |
im thinking about going back to the stock four lug on my 69.
the po had put wheel adaptors and a set of american eagles empi wide five rims.
i have changed the drums to that of a 67 in front and rear to ditch the adaptors but i think when i do the front drums over to disk i will go to the four lug.
just curious on how many people out there might have went to the five and then went back to four lug?
maybe i should keep the wide five look....? |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Fri Jan 11, 2008 7:32 pm Post subject: |
Its all up to you and what type of wheel you prefer to run. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Robert12 Samba Member
Joined: February 16, 2004 Posts: 21 Location: Culpeper, VA
Posted: Sat Feb 02, 2008 6:47 pm Post subject: |
I am thinking of doing the exact opposite you are doing? I want to take my 69 to the wide 5 look with adapters how did you do that? any pictures?
Thanks
Robert _________________ 1962 Ragtop, 1965 Notchback, 1974 Thing |
Skim Rants Master
Posted: Sat Feb 02, 2008 8:55 pm Post subject: |
Robert12 wrote: |
Thanks
Robert |
You wont need adapters if you use 66-67 bug front drums. The rear is just about as easy if you use wide 5 rear drums with the spacer between the axle nut and the drum. _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Sun Feb 10, 2008 10:57 am Post subject: |
i used the 67 drums in front and rear.
the rear with a spacer.
if you do it dont forget to buy new rear shoes for a 67 on the front its the same size.
sorry i never took any pictures but there are a crapload of threads that go into detail on this if you use the search. |
