Difference between Type 1 and Type 3
rat fasty
rat fasty is offline
PostPosted: Tue Feb 19, 2008 8:28 pm    Post subject: Difference between Type 1 and Type 3 Reply with quote
HI I'M NEW IN THE AIRCOOLED WORLD AND I JUST WANNA KNOW WHAT'S THE DIFFERENCE BETWEEN TYPE 1 AND TYPE 3,BECAUSE I BOUGHT A TYPE 3 ENGINE WITH EVERYTHING READY(TYPE 1 TIN,ALTERNATOR BRACKET) TO PUT ON A BEETLE,THANKS A LOT GUYS
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Feb 19, 2008 8:32 pm    Post subject: Reply with quote
CAPS off please.
The basic longblock is the same.
Glenn
Member #1009
#BlueSquare
rat fasty
PostPosted: Tue Feb 19, 2008 8:34 pm    Post subject: Reply with quote
THANK YOU VERY MUCH
rat fasty
PostPosted: Tue Feb 19, 2008 8:36 pm    Post subject: Reply with quote
the only thing that change are the generator bracket and few things more?
Mr. 010
Glenn is offline
PostPosted: Tue Feb 19, 2008 8:38 pm    Post subject: Reply with quote
Oil fill, oil cooler and all the tin.
Glenn
Member #1009
#BlueSquare
rat fasty
PostPosted: Tue Feb 19, 2008 8:39 pm    Post subject: Reply with quote
thanks my friend
Max Welton
Max Welton is offline
PostPosted: Tue Feb 19, 2008 10:35 pm    Post subject: Reply with quote
The type-1 cooling system is designed to operate in an engine bay that is sealed underneath. The air must come through vents in the decklid and/or under the rear window.
The type-3 system draws air through vents high up on the rear fenders. The air passes through the bodywork and through a big rubber boot then into the fan shroud.
Max
1967 Type-3 Fastback
Eric_S
Eric_S is offline
PostPosted: Tue Feb 19, 2008 10:55 pm    Post subject: Reply with quote
Here is the in-depth answer:
http://www.thesamba.com/vw/forum/viewtopic.php?t=257736&highlight=type1+type3
Eric_S
What are all these extra parts?
rat fasty
PostPosted: Wed Feb 20, 2008 5:32 am    Post subject: Reply with quote
thanks guys
nextgen
nextgen is offline
PostPosted: Wed Feb 20, 2008 6:31 am    Post subject: Reply with quote
One big difference between the two or should I say the Three seeing this goes for a T-4 also.
If your fan belt fails on a T-3 or 4 you do not lose your cooling, you only lose your Gen or Alt.
Only on a T-1 do you lose cooling because the belt runs the blower and the alt or gen. also.
On the T-3 and 4 the blower is Crank driven.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
Mr. 010
Glenn is offline
PostPosted: Wed Feb 20, 2008 6:41 am    Post subject: Reply with quote
What if your Type IV has been converted to an upright configuration?
Wink
Glenn
Member #1009
#BlueSquare
vwracerdave
vwracerdave is offline
PostPosted: Wed Feb 20, 2008 6:45 am    Post subject: Reply with quote
Can anybody verify if they had a different cam in them from the factory?
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
Euro 67
Samba's 67 part whord
Euro 67 is offline
PostPosted: Wed Feb 20, 2008 6:49 am    Post subject: Reply with quote
The 1500S is the only I can think that would have a different cam, but not sure.
The basic Item's that need to come off the type 3 motor are:
Fan shroud
Mustache bar
bellows
type 3 tin
Dipstick tube (replaced by a type3-1 conversion dipstick tube)
oil cooler
68 Bug totaled one day will live again
69 Bug donor car
Many parts had, always need em!
millerje78 wrote:
I'm no expert but I'm guessing the spike during cold running has everything to do with the roofing tar(20-50) in the crankcase.
bill may wrote:
...i could be wrong as i have only been driving air cooled beetles since august 1965.
