griest77 Samba Member
Posted: Mon Mar 03, 2008 2:18 pm Post subject: |
| jerry's70westy wrote: | | Do you have pictures? Would love to see it! |
Will try to get pics tonight |
TexasAirCooler Samba Member
Joined: October 31, 2005 Posts: 841 Location: Lone Oak, TX
Posted: Mon Mar 03, 2008 2:58 pm Post subject: |
| Quadratrückseite wrote: | OMG - I thought that was a Photoshop job at first!
(until I looked at your other pics)
How much are you selling that front windshield for? (assuming it's crack and chip free) |
It has a some small bubbles on the drivers bottom, not cracks or chips.
I have a guy that said he wanted it and is suppose to coem look at it next weekend. I don't know how it would survive a shipping? If your interested, PM me and I'll send you some pics and you can see if you want to mess with it. _________________ Terry
'69 · bug
'68 · 5/1600 project
'65 · 13 window deluxe
"Heroes don't wear capes. They wear dog tags." - Semper Fidelis |
static Samba Member
Joined: March 22, 2002 Posts: 1576 Location: Glands of Montgomery
Posted: Mon Mar 03, 2008 4:44 pm Post subject: |
I had mine towed. I broke down on the way back from the grocery store.  _________________ Like VW campers? Join us!
http://www.tinyurl.com/westy |
volksterii Samba Member
Joined: December 01, 2006 Posts: 426 Location: San Diego CA
Posted: Mon Mar 03, 2008 4:53 pm Post subject: |
I just replaced my kads with dells. Drove it about two blocks then the accelerator pump lever broke. Replaced it, now running smooth.  _________________ 71 Westy Hardtop, 1915
2005 Touareg V8 air susp. |
static Samba Member
Posted: Mon Mar 03, 2008 7:13 pm Post subject: |
Hey! Nice looking bus! _________________ Like VW campers? Join us!
Kirwin Samba Member
Joined: April 08, 2005 Posts: 413 Location: Newport News, VA
Posted: Mon Mar 03, 2008 7:24 pm Post subject: |
Re-installed the right rear brake shoes, replaced the right side emergency brake, replaced all the rubber brake lines and bled the brake s. Installed my newly painted rims and new tires. Then cried after I pulled the Bus out of the garage and saw brake fluid pouring out of the front left brake line. Sigh...I'll fix it next weekend.  _________________ 1978 VW Transporter (DLNDBUS)
Mazda B4000
Willys CJ-2A (WWII colors)
Ford F-150
Cannondale road bike
Specialized mountain bike |
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2273 Location: Bristol, Tennessee
Posted: Mon Mar 03, 2008 7:30 pm Post subject: |
| Sunshine_the_bus wrote: | ...
First thing in the morning we'll be doing the compression test. Then, using Redline's how-to, I'm gonna' try to set up her progressive carb. If that doesn't work, I bought the rebuild kit for it . Peace! |
The compression test showed some bad news. Cylinder #
1 = 120
2 = 108
3 = 110
4 = 90
I worked on some other projects and didn't get into the carb today. Peace! _________________
| busdaddy wrote: | ...and try a few chubby ones until you find one you like.
1977 Westfalia P27
M-code Plate
1990 Passat GL 2.0L 16V
Full Moon Bus Club |
Mark Samba Member
Joined: January 20, 2003 Posts: 1499 Location: Sooke, BC Canada
Posted: Mon Mar 03, 2008 7:41 pm Post subject: |
- Gave the Westy it's first wash since the new paint,
- treated windshield w/ RainX, (excellent stuff if you haven't tried it),
- POR-15'd the splash pan, (didn't stain my hands this time),
- cured intermittent flasher relay problem, & replaced 2 burnt marker lamps,
- adjusted IDF hex bar & linkage arms,
- touched up paint & undercoating missed by idiot @ body/paint shop,
- made drain holes under battery trays (left & right) where same idiot covered during welding,
- checked tire pressure, (after reading 9 pages of the tire sticky before realizing most of that thread was an internet pissing match),
- got insurance for the next 6 months,
- ordered just enough stuff for cip1 to get free shipping,
cracked a beer, then another... |
rjonas Samba Member
Joined: July 24, 2004 Posts: 522 Location: Mesa, AZ (Missouri transplant)
Posted: Tue Mar 04, 2008 7:02 am Post subject: |
Sunday in St Louis it was 78-deg so I washed my new 73 Westy inside and out. I recently purchased it and am rescuing it from garage storage since 1987. Monday it was 30-deg and I pulled the engine and drained @ 7 gallons of nasty old gas only to find about 1/2" of black molasses in it. Hopefully I can get that boiled out. Stripped all the tin and accesories off down to the long block. 124K well maintained original miles on her and all looks good. Ran a cylinder leak down test and had 97% on #1,2,3 and 92% on #4. Woohooo....it all good.
Here is some baywindow porn for ya:
 _________________ 1965 21-Deluxe-SWR/BG "Sonora"
1973 Type-181 Thing "Velma"
www.aircooledmissouri.com |
Posted: Tue Mar 04, 2008 2:25 pm Post subject: |
| Pics wont go through if you want to see peace sign floor email me at [email protected] and I will be glad to send you the pic. |
GMerr2 Samba Member
Joined: December 11, 2004 Posts: 50 Location: Chattanooga, Tennessee
Posted: Tue Mar 04, 2008 5:55 pm Post subject: |
I got tired of seeing mine sit in my carport....so I've been working on it for a couple of weeks now.....so my neighbor walked out his back door just in time to see me running around my carport after The Monstrosity started for the first time in a long time screaming "IT'S ALIVE!!!! IT'S ALIIIIIIVE!!!!! HAHAHAHAHAHAAAAA!!". So I cleaned up the tin and bent back some pieces on the outside edges of the engine compartment and put an engine seal in. And found another gas leak.....the one old line I didn't change because it wasn't leaking 2 weeks ago......so now I get to climb up in there and run it down to it's beginning (I think it's the one coming out from the gas tank)....and I'm not exactly thin, so this should be fun....anyone got any tips??
Rev. George.....Chattanooga, Tn _________________ "THE MONSTROSITY" MY 1971 WESTY
2005 GENUINE SCOOTER CO. STELLA....The Super Scooter! |
Devon-Dyno-Soar118 Samba Member
Joined: August 30, 2004 Posts: 846 Location: Devon UK
Posted: Wed Mar 05, 2008 6:26 am Post subject: |
I did this-
Now its fitted the rest of the bus looks shabby! _________________ 71 West coast Kombi
54 Oval, 60k km from new
Daves 68 Bug Project
Rust Collector. |
Bay Window Steve Samba Member
Joined: July 13, 2006 Posts: 280 Location: Van Alstyne, Texas
Posted: Wed Mar 05, 2008 8:34 am Post subject: |
Nice!
What did you paint that with? _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Original Air Cooler Member |
itlives Samba Member
Joined: July 12, 2005 Posts: 1421 Location: Shreveport La
Posted: Wed Mar 05, 2008 8:09 pm Post subject: |
I pulled my gas tank. It looks great inside!! I ohm tested the sender -it seems fine too.
Now, I need to find the large fuel filler hose to fit a '74 .
Anybody know where to get it? |
Posted: Fri Mar 07, 2008 7:19 pm Post subject: |
Swept the snow off................  _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
tubdub Samba Member
Posted: Fri Mar 07, 2008 8:18 pm Post subject: 71 |
On my 71 kombi that i recently picked up from a guy i work with. It was his fathers who passed away about 1998 or so. It had been sitting til we went and looked at it. We put a battery in and sprayed some starting fluid in the carb and it started up
I did this in the last 3 weekends i had off.
put new windshield in
replaced all window seals
changed gear oil
replaced front pass. seat with good one from the junkyard
installed 4 new yokohama LT tires
replaced rotors,calipers, brake pads and shoes, wheel cylinders and rubber lines
tune up
put sliders in the middle window sections on each side
buffed out the red oxidized paint
installed tow hitch from jeremy
fixed taillights and license plate light
put a better steering wheel on
changed the windshield wiper assy.
sent some door handles off to gabriel to get keyed alike.
replaced the pass side front door inner latch and rod. now it opens from inside or the outside.
and drove it around now that i insured it with hagerty
still need to replace the guage cluster as 2 of the pieces of glass are rattling around and i have one from the junkyard that is in nice condition.
also added a interior camper light to my motorhome bus but thats a split not a bay
all this besides going to the junkyard and stripping 4 bay window busses to sell the extra parts i didnt need to finance this.
bradgsanford Heathen
Posted: Fri Mar 07, 2008 8:24 pm Post subject: |
| Bay Window Steve wrote: |
Swept the snow off................  |
It sucks that ya'll got so much damn snow and we in OKC didn't get any.
I have a brother in law that lives in Anna, Bay Window Steve. He's one of those guys that everyone seems to know so maybe you do too. His name is Matt Henderson? Ring a bell? |
Posted: Fri Mar 07, 2008 8:37 pm Post subject: |
| bradgsanford wrote: | | Bay Window Steve wrote: |
Actually, I think so. My last name is Henderson also. I get that question alot.
ps: I wanted your bus bad.  _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2434 Location: Manassas VA
Posted: Sat Mar 08, 2008 10:47 am Post subject: |
I finally got around to replacing my battery. It was an Interstate, put in by the PO. It was peg holed for June 2001. It was a 50 month battery. Do the math. So I took it to the Interstate battery distributor warehouse that supplies most of the Northern VA parts vendors. And these guys are great. The dude behind the counter (and he's a real card) said, "Oh, since you got so much more life than expected outta this battery your new one will cost you more..." Thank God I've got the same sense of humor he had. He said that particular 50 month battery is no longer produced by Interstate, but the equivalent is the 75 month model, and that he happened to have a "warehouse special" return that came back to them due to an improper order. Still totally wrapped with the warranty. That reduced my price $20. So I got a 6 1/4 year Interstate battery for $68.20 total. _________________ '66 Beetle
'71 Westy Camper
'95 Passat V6 GLX Wagon |
donemoto Samba Member
Posted: Sat Mar 08, 2008 12:10 pm Post subject: |
Still waiting for spring.  _________________ 1975 Campmobile
1962 Bug Convertible
Homebuilt VW Trike
1966 HD Sprint H
1940 HD ULH Flathead
1985 Electra-glide Classic with Tour-Pac
1968 Harley Rapido
2003 VW Passat Turbo
1968 Honda CL Scrambler 175cc
1962 Honda Cub 50 Step-thru
1965 Honda Cub 50 Step-thru Electric Start |
