EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
WharfRat Samba Member
Posted: Fri Mar 26, 2004 8:43 am Post subject: |
well, to get this started off right, how much do you have to lower a front end to compensate for the height loss from removing the reduction gear boxes?
how much can you lower a bus before you have to install a narrowed beam?
what would be the procedure, john muir style, for putting a mild drop on a bus? nothing too extreme, but just a shade lower than stock? |
66split Samba Member
Joined: August 19, 2002 Posts: 809 Location: Bham, WA
Posted: Fri Mar 26, 2004 9:29 am Post subject: |
Rear Swing Axle;for a good description of parts for a swing axle conversion please head over to www.bus-boys.com then click on the "suspension conversion " header, there they have their lowering kits. If you click on "swing axle" then go to the fact sheet it tells you everything you need to know about lowering and converting to a swing axle and all the parts they recommend.
Rear IRS;
For a good description of lowering via IRS check out www.23window.com he has a great list of parts and info as well.
Front suspension:
For the front you can go with "Drop spindles" for anywhere from a 2.5 inch to 7inch drop or you can buy an adjustable beam OR you can do both for a more comfortable ride.
People that sell beams and spindles (that I know of) in the USA;
Wolfgang
Nate
Rizzag
Camerod
Franklins
Bus Boys
People that do the rears;
Wolfgang
BusBoys
Franklins
Camerod
Bus Boys
If you do not recognize the names above, please do a search. There are probably more out there, feel free to add them. There are also quite a few companies in Australia and the UK that do the same thing. There is also a good book called "How to modify bus suspension and Brakes" (or similar) by James Hale. (check amazon)
L8r
eh0s Banned
Joined: June 25, 2003 Posts: 760 Location: Splitsville, AB, Population = 1
Posted: Fri Mar 26, 2004 10:17 am Post subject: narrowing and some requests |
The best tutorial I've seen on narrowing a beam...
http://www.thesamba.com/vw/forum/viewtopic.php?t=64301
Also, in the interest of keeping this thread on topic, can people simply edit their posts instead of getting off-topic? Or if you have new information, just add it to an old post you have. I plan to add more to this post when I get more info.
Specifically (if someone has links or good info on):
BD lowering ? Pre-63 spindles will slide right in, but the tie rod will be mounted to a different position, anyone done this?? Also a bug rear end is the perfect fit, again, anyone do this?
Straight axle conversion (parts/how to?)
Any other lowering how to's ? Maybe even a simple one for installing spindles/beams? |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Fri Mar 26, 2004 4:52 pm Post subject: |
Awesome tutorial for making your own straight axle kit.
Here _________________ -Andrew |
23isthenumber Samba Member
Joined: February 11, 2004 Posts: 66 Location: california
Posted: Fri Mar 26, 2004 8:03 pm Post subject: |
so i am putting a axle kit on the back of my 63 panel. i am also going to lower the front. here is the thing...... the guy who is helping me (im a newbe) says i can lower the front by flipping the king pins or somethin like that. does this really work? or is he full of it. he says this really works and he has done it plenty of times befor. if so will it still be as low as the back? sounds to good to be true. thanks alot guys! _________________ rock it old skool.... |
23window Samba Member
Posted: Fri Mar 26, 2004 8:23 pm Post subject: |
WharfRat wrote: |
I put IRS in the back and dropped it one notch on the springplates. I also put Bus-boys adjusters in the front and adjusted them one notch lower than stock. My bus is a little lower by about 1.5". Its alot of work and $ for little lowering it provides, but I did it to stay "almost stock" and get rid of the redux boxes. |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Fri Mar 26, 2004 10:24 pm Post subject: |
OK I'll shamelessly plug myself again. Here is a website I kicked up after narrowing my front needle bearing beam 4" plating the shock towers:
http://www.geocities.com/iltis74/bus_beam_narrowing.html
As far as flipping the king pins yes they are called dropped spindles and when you throw some adjusters on the beam at the same time you've just dropped the front in possably the best method out there. A press and a welder are all you need. Any good sites with pictures on dropped spindles? |
PRIMER-LOOK Samba Member
Joined: December 16, 2002 Posts: 31 Location: Holland
Posted: Sun Mar 28, 2004 1:57 am Post subject: |
oke andrew this http://www.aussieveedubbers.com/forum/viewthread.p...;aid=11375
is indeed a nice site ....BUT what they dont mention is how to rework your springplates , yes they say get the beetle pattern but you will see wen you install the springplates and try to get your wheels set up straight you will have NO suspension travel left (plate hits upper stop).
So dont forget to notch your springplates .............btw who has info on notching spring plates pics pics pics.
dennis |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Mon Mar 29, 2004 9:26 am Post subject: |
Primer-Look in Andrew's post that link shows you what your spring plates should look like.
On the lowering topic:
If I want to raise the rear slightly after installing a straight axle set-up. If I were to Raise it one inner spline and lower it 1 outer spline it should raise it only about 3/16" right? _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Billet_Bus Samba Member
Posted: Sat Apr 03, 2004 4:28 pm Post subject: |
Can someone post up the tech on howto narrow the rear torsion housing and an inches to inner/outter notch ratio for the rear also.
Thanks _________________ www.Full-Race.com
Anything else is just half fast.
CTD Fabrication |
Sy Kipp Samba Member
Joined: April 04, 2004 Posts: 24 Location: Lehighton, Pennsylvania
Posted: Tue Apr 06, 2004 7:34 pm Post subject: |
Hello everyone, I'm new to the split screen scene. I bought a 62' Kombi and it needs alot of work. I have 2 bay garage a mig machine and a spare motor and that's about it. I've been surfing the Samba for about 2 years then I finally acquired this bus. I'm buying another transaxle to do the lowering in the rear as per the tutorial that Andrew posted on Friday. I read and gather as much info as I can before I attempt anything of this magnitude. If any of you could enlighten me as to some basics in body changes or dimensions in the 60's like the wide rear door in 64" I would be grateful... _________________ Do what you can, where you are, with what you have!
1959 SC |
pimpsome Samba Member
Posted: Tue Apr 13, 2004 12:26 am Post subject: |
i bought my 67 with a busboys adjustable beam already in it and its so nice to beable to raise it up an inch when ya want to
to bad its going up for sale later this month |
Posted: Thu Apr 15, 2004 12:01 am Post subject: |
i have heard about removing torsion slats in front to drop the front end. is this possible on a 63? is this like removing leaves? thanks alot! _________________ rock it old skool.... |
rene p. l. Samba Member
Joined: September 27, 2002 Posts: 280 Location: YQB, Québec, Canada
Posted: Thu Apr 15, 2004 3:05 pm Post subject: |
I think the bests ways to go for the rear are creative engineering irs kit, but you can buy parts from a 68 bay bus. For the front, Red 9 desing look great. That's the way i will do on mine ... Did somebody do those conversions???
www.red9design.co.uk
www.creative-engineering.com |
Stanw3 Samba Member
Joined: September 26, 2003 Posts: 1077 Location: Albuquerque, NM
Posted: Fri Apr 16, 2004 6:56 pm Post subject: |
23isthenumber wrote: |
i have heard about removing torsion slats in front to drop the front end. is this possible on a 63? is this like removing leaves? thanks alot! |
It's possible - but don't do it. I have a 61 panel that the PO did this on - it rides horrible! I'll be correcting it soon. It's not safe - the springs are in there for a reason. Adjustable or drop spindels -that's the only way(s) to go. |
DaveB Samba Member
Joined: June 03, 2002 Posts: 489 Location: Raeford, NC
Posted: Sat Apr 17, 2004 8:06 pm Post subject: IRS rear |
I've got the CE rear IRS with Kruiznwagen (Sp?) from Australia adjustable control arms. _________________ Dave Brooks
USAF Retired
1966 Custom Camper |
Posted: Sun Apr 18, 2004 3:03 pm Post subject: |
Adjustable control arms? For the front or Rear? _________________ Anthony
SBS #1
SBS #1 on FB
DaveB Samba Member
Posted: Sun Apr 18, 2004 3:55 pm Post subject: |
They're for the rear. They have a ecentric (right word? off center hole in the bushing) that adjust camber and toe end some. _________________ Dave Brooks
USAF Retired
Daniel Samba Member
Posted: Sun Apr 18, 2004 4:12 pm Post subject: |
I am also using the Kruizinwagon IRS kit, and will soon have their adjustable springplates fitted as well. It's a very good quality product. |
