My buggy project.
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
GS guy
GS guy is offline
PostPosted: Sun Mar 02, 2008 6:54 am    Post subject: Reply with quote
Looking great with the new wheels!
On the tubing/body pass-thru, I'm doing something similar on my Deserter, except at the rear. Running the upper side tubes outside the bodywork and needed a way to pass from inside to outside of the fiberglass, just like your front firewall. I'm doing it similar, except using steel bushings between the sandwich plates. This way the plates bolt up tight steel to steel, the fiberglass does not get tightened (100%) between steel plates. I sized the bushings to allow rubber pads to be used between the fiberglass and sandwich plates, and when tightened down it compressed the rubber (and fiberglass) slightly before it's down to steel on steel contact. Maybe overkill?? I just didn't want anything crtitical to be relying on the fiberglass for full support.
Jeff
Glasser
Glasser is offline
PostPosted: Sun Mar 02, 2008 7:52 am    Post subject: Reply with quote
Thanks Jeff.
Awesome idea!! Just goes to show there is always other and better ideas to get the same results (I'm not saying mine was the best way).
I'm really stuck on the back with my build. I want all the bars inside the tub and I need to tie the back of the car into the inner tube work. My design has the tubes running parallel with each other and don't meet end to end like the front. I'm having a heck of a time thinking of a good way to go through the back fiberglass and tyeing the cage to the rear of the car. I figure I'll start on the front of the car and hopefully by the time I get to the back I'll have it all sorted out..... I hope.
Brent
MURZI
MURZI is offline
PostPosted: Sun Mar 02, 2008 8:02 am    Post subject: Reply with quote
Hell YEA!!! nice!!!!
PENNY LOAFER MAFIA..step up or step back...
1962 Beetle Convertible http://s23.photobucket.com/albums/b374/MURZI/new%2062%20vert/
1968 BAJA http://s23.photobucket.com/albums/b374/MURZI/testmule/
My old Dune Buggy http://s23.photobucket.com/albums/b374/MURZI/
Quit playing...build a 2276 and be done with it.......
Glasser
Glasser is offline
PostPosted: Sun Mar 02, 2008 8:19 am    Post subject: Reply with quote
LOL. I've really been thinking about chopping the front wind screen and going with the chopped look...... but I'm 6'3" and my head is well above the seat Sad
I had to lower the seats (they are bolted to the pan, no slider) just so I wouldn't be looking through the top frame of the windshield. I guess I could always "tilt" the seats some but I would have to cut the floor and have the seats as the lowest part of the pan. Confused
Brent
My build up http://www.thesamba.com/vw/forum/viewtopic.php?t=265364&postdays=0&postorder=asc&start=0
Project#2. Neighbors build up. http://www.thesamba.com/vw/forum/viewtopic.php?t=327008
GS guy
GS guy is offline
PostPosted: Sun Mar 02, 2008 8:43 am    Post subject: Reply with quote
Not to take away from your thread Brent - but some ideas on body pass-thru.
Here's a shot of my chassis from last Summer, this is when I started tacking up the upper longitudinal support tubes and bracing. You can see at the rear of the upper tubes, aft of the roll bar, where they terminate and body pass-thru takes place:
And a close-up of the pass-thru, note the bushings between the plates:
I had to carefully fit the inner pass-thru supports from existing chassis out to the body with he body in place. With the angles involved, this took several trial and error fittings before they could be tacked in.
I wanted to get the side rails outside the bodywork to leave more room inside for seats. The GS locates the cockpit several inches further forward than the standard VW pan layout. As the chassis gets narrower as you go forward, interior cockpit width is at a premium!
Cheers, Jeff
Glasser
Glasser is offline
PostPosted: Sun Mar 02, 2008 10:51 am    Post subject: Reply with quote
No worries about that, thanks for the info. Pictures are worth a 1000 words as they say. I had a pretty good idea what you did, now seeing the brackets you did gets me thinking in a whole different direction. And that is what I needed!
Your frame looks wicked. Cool
Brent
Glasser
Glasser is offline
PostPosted: Wed Apr 09, 2008 8:51 pm    Post subject: Reply with quote
I can finally resume my build now that I have me tube bender.
I'm enjoying this emencly..... that's because I haven't screwed up yet. Laughing
I'm going to try my plate design as is. If I hear too much creaking or wear on the fiberglass I will be able to easily modify the set up later.
Brent
ManxBug
ManxBug is offline
PostPosted: Wed Apr 09, 2008 10:40 pm    Post subject: Reply with quote
I wouldn't chop the windshield. I used to have taller seats and sat with my forehead over the windshild. All I can say is that we have some big insects in Alberta!
Air Riders, VW Club
Glasser
Glasser is offline
PostPosted: Thu Apr 10, 2008 6:13 am    Post subject: Reply with quote
I wouldn't chop the windshield. I used to have taller seats and sat with my forehead over the windshield. All I can say is that we have some big insects in Alberta!
Yah I hear ya. Before I lowed my seats I was in this situation. I put the window on and it almost looks chopped already. Not sure why, it is a standard height. I'm hoping with the cage it will help make it look lower like in Muzi's rendition.
Brent
Glasser
Glasser is offline
PostPosted: Sun Apr 13, 2008 6:42 pm    Post subject: Reply with quote
Did a little more this weekend...... then ran out of tube. I was sold two lengths of 1.75 Dia by mistake so will return them and get the 1.625.
I'm getting the software figured out....slowly. Did the first hoop and something didn't work out quite right but had extra material so was OK. The back hoop I left extra material and everything worked out perfectly. The extra material I added had to be cut off. Width has worked out perfectly every time.
Brent
MURZI
MURZI is offline
PostPosted: Sun Apr 13, 2008 7:07 pm    Post subject: Reply with quote
Brent, what size tires and rims....friggin perfect!!!!! In my best "Chico and the man voice"... Looking good, looking good!!!
Glasser
Glasser is offline
PostPosted: Sun Apr 13, 2008 7:21 pm    Post subject: Reply with quote
Laughing
Thanks bud.
245/60/R15s on the back mounted on an 8" wide rim.
145/65/R15s mounted on a 5" rim on the front (pushing the limits a bit.) The fronts are Smart Car tires pre 08 (In 08 they now have wider tires front and back).
Brent
surfnc
surfnc is offline
PostPosted: Sun Apr 13, 2008 9:26 pm    Post subject: Reply with quote
X2 Very Happy Very Happy
Love the stance!!!
Glasser
Glasser is offline
PostPosted: Mon Apr 14, 2008 6:14 am    Post subject: Reply with quote
Thanks Surf.
While the back obviously has to come up a bit the front should be able to stay where it is. It's on the snubbers now in the front but will add a full tank of gas.. or the same weight as one, turn the adjusters so it just lifts off the snubber and weld with the adjusters in the lowest position (they are not welded in right now) and remove the snubers completly. Then I have all up adjustment from there.
I wonder if a full tank of gas vrs. an empty tank will change ride height?? I wouldn't think it would be much if it did.
Brent
Glasser
Glasser is offline
PostPosted: Wed Apr 16, 2008 8:17 pm    Post subject: Reply with quote
Got the back bars done. Tied the cage into the front of the car and got some side impact bars in place. Still not sure if I like the side impact bars showing. One side of me says hid them (lower the back), the other side says show them if you got them.
The reason I went low on the side impact bars is I need all the room I can get for my legs. If I had the bar flush with the side of the buggy all the way across my legs would interfere with the steering wheel.
I still have a seat belt bar to run across behind the seats and a dash bar. I think I will also tie the rear bars back to the rear main hoop along the seat surface.
Brent
Glasser
Glasser is offline
PostPosted: Thu Apr 17, 2008 7:37 pm    Post subject: Reply with quote
Still plugging away. Rear cage complete.
Brent
Glasser
Glasser is offline
PostPosted: Sun Apr 27, 2008 3:02 pm    Post subject: Reply with quote
Tied the back end all together this weekend. Roll bar, shock towers, and wish bone.
Brent
aquamanx
aquamanx is offline
PostPosted: Wed Apr 30, 2008 6:59 pm    Post subject: Reply with quote
Lookin real good! I think you got the hang of that bender.
CoryN
CoryN is offline
PostPosted: Wed Apr 30, 2008 7:14 pm    Post subject: Reply with quote
I'm digging the pink transmission mount Wink
aquamanx
aquamanx is offline
PostPosted: Wed Apr 30, 2008 7:37 pm    Post subject: Reply with quote
Yea thats sweet Shocked Don't let my wife see that shit she already wants a pink sand rail. Rolling Eyes
Longbody build http://www.thesamba.com/vw/forum/viewtopic.php?t=266189&postdays=0&postorder=asc&start=0
04 aqua buggy - sold
72 orange buggy - sold
72 green longbody buggy - aka Shrek
68 Manx future project
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 3 of 7
