calig Samba Member
Joined: June 04, 2007 Posts: 12 Location: highlands Ranch, CO
Posted: Wed May 21, 2008 7:16 am Post subject: Can someone explain full flow oil systems to me |
Im not the smartest guy on the block and I am having a hard time understanding what full flow oil systems are. All I know is that my 1776 dual carb motor is not full flow. I have been thinking about doing it but I have I some questions if you dont mind
What is Full flow?
Why do people do it?
what do I need to do to my case?
what do I need to buy?
Can I do it to an already built case or do I need to rebuild it?
what advantage will I get from full flow?
will my bug run cooler?
Thanks a bunch! |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed May 21, 2008 8:02 am Post subject: |
A full flow oiling system simply means the oil is pumped through a filter and sometimes a cooler before being returned to the engine.
The VW engine has no filter. It just has a screen. So the addition of an inline filter will extend the life of the engine.
Another draw back to the VW engine is the small oil capacity of the crank case. Adding a filter and lines will increase tthe amount of oil available to your engine.
Adding a cooler will also keep oil temps down and add additional capacity.
Should you do it? Well, the answer isn't simple. I would say yes to adding a filter simply because it helps to remove abrasive particulates from the oil.
As for adding a cooler, you first need to monitor your oil temps. DON'T add a cooler simply because it is the "cool" thing to do or because someone who sells them in a catalog says you need one!
Oil MUST be in the proper temperature range in order for it to lubricate properly. If you add a cooler and oil capacity, you may end up running too cool with your engine temperatures. This can be more damaging then running hot and also increases the warm up time of the engine.
So, if you want to spend money and buy cool stuff for your car, start with a few gauges. This will let you know whats going on and if you should add additional oil capacity or coolers.
As for filters, I prefer the oil pump/filter deal. It's simple, not expensive and won't add additional complicated plumbing to the engine. It only adds a minimal amount of capacity and some say it is too close to the exhaust, but this is a simple way to keep your oil clean.
If you are concerned about heat from the exhaust, a simple sheet metal heat shield can be fabricated to keep the radiant heat away from the filter. _________________ Mother Nature is a Mean Evil Bitch! |
calig Samba Member
Posted: Wed May 21, 2008 8:24 am Post subject: |
I have a bunch of gauges and I don’t like them because all I do is look at them and worry but that is another issue.
The oil temps get pretty hot in my mind. After about 30 minutes of city driving the gauge is around 210-220 and going up. That alone is not making me worry much but I feel like if I keep driving longer the temps will keep going up.
I also have a oil pressure gauge and it reads in the 40's when it’s cold and 20’s when its warm while I am driving. However sometime when I am at idle the oil light comes up. If I give it a little rev then it goes out but comes on again when I am back to idle. My tach shows my idle is around 800rpms. I also have the dual VDO oil pressure sender and was reading that it turns the light on at around 10-15psi and the stock sender comes on at 7psi. When at idle with a warm car the gauge reads at the 10 hash mark.
So I am a little worried that car is running on the hot side. I have the doghouse cooler and 1.5qt sump. The timing and carbs where just tuned by my local VW shop.
I was thinking that I would go full flow to add a filter and possibly another cooler but I don’t want to just cure a symptom. Also to do full flow the case needs to be tapped right? Can I do that on an already built motor or does it need a tear down? My motor is only a year old. |
Joesplace Samba Member
Joined: February 18, 2006 Posts: 313 Location: Brookings, Oregon
fred g Samba Member
Joined: October 30, 2004 Posts: 222 Location: So. NH / Santa Maria, Azores.
Posted: Wed May 21, 2008 4:39 pm Post subject: |
I was told oil temp is should run between 180 and 210F.
Can someone flesh this out for me.
thanks,
Fred _________________ 71 Kombi Rusty the 'Afront'
"Buy the ticket, take the ride." H.S Thompson |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Wed May 21, 2008 5:08 pm Post subject: |
180-210 is normal
210-230 is warm
230-250 is hot
250+ is turn the engine off _________________ Glenn
Member #1009
#BlueSquare |
Mwanza Voki Samba Member
Posted: Tue Oct 13, 2020 2:18 am Post subject: |
Greetings members.
I've a question on the CB performance full kit link below:
https://www.mooreparts.com/vw-bug-full-flow-oil-fi...ished-cam/
1.Does it mean one uses the stock oil cooler(mine is Doghouse type 71 up)
2. The piping from the Oil filter,where does it terminate? In other words how does the engine get oil supply?
Checking to be sure...I seem to have a missing link.
Respectfully.
Mwanza. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Oct 13, 2020 5:02 am Post subject: Re: Can someone explain full flow oil systems to me |
Welcome to the Samba!
Yes, it has nothing to do with the oil cooler, so nothing of that sot changes.
And notice there is an IN and OUT line. Oil is pushed out of the pump, then going to the filter, and then the oil makes its way back towards the engine. If you remove the pump cover, you will notice a secondary hole/entry that is isolated from the pump section thats in charged of doing the actual pumping. Oil goes into the hole, and back into the same oil galley it would be pumping through on a stack no filtered system.
This Style of pump, or an IN OUT pump, is best suited for already running engines, because it is a bolt on, and you wont have to drill any oil galleys.
Here is a picture of a filter pump, or an IN OUT pump. However, a pump body like this can also be used as a single OUT style pump cover. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
GDKARMA Samba Member
Joined: March 06, 2020 Posts: 4 Location: Atlanta, Georgia
Posted: Mon Oct 02, 2023 10:29 am Post subject: Re: Can someone explain full flow oil systems to me |
Chickensoup wrote: |
Here is a picture of a filter pump, or an IN OUT pump. However, a pump body like this can also be used as a single OUT style pump cover. |
Hi, how does one know wether to buy the "dished cam or flat cam" version? And does this mount in a specific place or do people mount the filter in different places? Also, is other hardware needed to complete the installation?I have a '74 Karmann Ghia Convertable with a 1776. Thank you! |
wdfifteen Samba Member
Posted: Mon Oct 02, 2023 11:06 am Post subject: Re: Can someone explain full flow oil systems to me |
Full flow systems pump oil through a filter before it goes to the bearings.
Bypass flow systems pump only the oil released by the oil pressure regulator (bypass oil) through a filter before it goes back into the crankcase.
The Volkswagen flow system uses a bug screen at the bottom of the sump.
Full flow is best. |
zerotofifty Samba Member
Posted: Mon Oct 02, 2023 11:17 am Post subject: Re: Can someone explain full flow oil systems to me |
your oil is a bit hot. make sure that the vee belt is tensioned right, no oil on it. do not use a power pulley, make sure pulley is stock diameter so that fan runs at required speed. make sure rags and leafs are not sucked into fan, which will block cooling air, make sure fire wall padding is not leaning and blocking fan inlet. Make sure ALL cooling tin and rubber seals are correct and no gaps, this also includes heater ducting hoses.
If still hot after this, make sure timing is not too far advanced, mixture correct, and fuel grade high enough. Also make sure the four wheels spin freely as a dragging brake can make engine work hard and get too hot.
The Dog House system has a tiny sheet metal internal part that is critical to be installed to prevent cooling air from by passing the cooler. This part is called the "hoover bit" a samba search will yield many posts about this Hoover bit and its importance for cooling the oil. There are also foam seals around the dog house cooler that are critical to renew.
Make sure bypass valve for cooler is opening fully when hot (it opens at low oil pressure)
Wrong wieght of oil can lead to high temps (bypass wont open with too thick an oil) use recommended oil for your climate. Generally a 10w30 works for most folks, other might use a 20W 50. but what ever of this range, assure the bypass is opening fully when hot. If you are running 20w 50 you might want to test 10w 30 to see if that lowers temps, BUT besure you maintain good pressure, minimum of 10 psi per 1000 rpm when warmed up. i.e. minimum 30 psi at 3000 rpm.
Finally, or perhaps firstly, make sure your temp gage is correct. A test thermometer can slipped down the dip stick tube when engine is off and hot to use as a comparison. That test thermometer can be tested for accuracy in a pot of boiling water.
Report back!!!! Good luck, stay cool.
Full flow related to oil filtration. _________________ Give peace a chance. No American war with Russia! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Mon Oct 02, 2023 6:06 pm Post subject: Re: Can someone explain full flow oil systems to me |
GDKARMA wrote: |
GDKARMA, Please don't take offense in what I'm typing. I'm not trying to be condescending.
If you are asking about what cam gear you have in your engine. It's kind of an indication that you are not very experienced with your engine/car.
One way to know if you have a dished cam gear or not is to look.
Pull the oil pump and see if the cam gear is dished or flat.
On a rebuilt 1776, my money is on a flat cam gear. But you need to know for sure before ordering a full flow (FF) pump and filter setup.
If your engine is in the car and fully assembled. Installing a FF system on your running engine may bring more headaches that what you are bargaining
for installing a FF system.
There are a few alternatives to installing a FF system on a running/installed engine.
The CB filter pump is a good alternative. You remove your old oil pump and install the filter pump setup. It works, as long as you have a header on your Ghia. If you have a stock muffler, and the heat riser tube is on the left side. Your kinda S.O.L!
https://www.cbperformance.com/product-p/1792.htm
I have this filter pump on two engines. It works! But the filter pump cover needs a little clearancing to clear the crank pulley tin.
Then there is the CB FF in/out pump and cover. I have no experience with this setup. So it too, may need a little clearancing to clear the crank pulley tin.
https://www.cbperformance.com/product-p/maxi26late.htm
In both of the above examples. You still need to know what cam gear you have in your engine before ordering.
There may be a folks that say, "just drill the case, in situ." Sure it can be done, if you have the tools and are skilled at keeping the aluminum/magnesium chips out of the oil galley's.
I run FF on larger high revving engines. On the lower revving engines, filter pumps are my choice for ease of installation.
YMMV! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Posted: Mon Oct 02, 2023 6:22 pm Post subject: Re: Can someone explain full flow oil systems to me |
67rustavenger wrote: |
GDKARMA wrote: |
YMMV! |
Or never had the engine apart.
If you buy a late model 1600DP that originally came with dished cam, it's very easy to not know if it was never rebuild or rebuilt with a dished or flat cam.
Only way to know for sure is to pull the pump and look at the cam gear.
I would ASSume that he's asking about adding full flow to an existing engine. _________________ Glenn
Member #1009
#BlueSquare |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15975 Location: North Florida, USA
Posted: Mon Oct 02, 2023 8:18 pm Post subject: Re: Can someone explain full flow oil systems to me |
Glenn wrote: |
Only way to know for sure is to pull the pump and look at the cam gear. |
To add to Glenn's response...
Cam + gear on the left is 3-rivet "flat" cam. The slot of the oil pump drive gear is immediately in front of the gear face.
Cam + gear on the right is 4-rivet "dished" cam. The slot is set deeper into the case.
Just looking at the rivet attachment points you can see the cams and gears are not compatible. The gear on the right is clearly more dished to allow room for a larger oil pump that sits deeper into the case. The dish makes room for the larger/longer pump & gear. This means the pump must match the cam gear. The cases that came with the larger pumps also had larger oil passages.
Knowing if you have a flat or dished cam is the first step. Dished cams are mostly original stock cams. Flat cams could also be stock but many/most aftermarket/performance camshafts come with a flat cams.
Next thing you need to know is if your case is a later case with larger oil passages or an early case with smaller oil passages. Here is a pic showing different pumps. Notice the smaller pump outlet on the left (earlier) pump.
One last point to note is the left (early 21mm gear) pump above uses M6 studs to attach to the case. Later (26mm long gear) pumps used M8 studs.
Since changing your cam would require a complete case disassembly you need to find a full flow pump that matches your cam and your case. Pick either a flat cam or dished cam pump to match your cam. Then select the size of the pump gears. 21mm long gears would be for early single-relief cases with M6 studs. 26mm gears with M8 studs for dual-relief cases with larger passages. 30mm gear pumps are available for even more pressure.
Even if you have a flat cam, 26mm or 30mm pumps can be designed to work with the cam by having the extra gear length extend out further out the rear of the case. You can see this when you compare the middle pump with the right one. They have the same 26mm pump gears but the middle pump will fit the more shallow flat cam gear. _________________ AshMan40
