BrockGrimes Samba Member
Joined: September 18, 2006 Posts: 1015 Location: Clovis, NM
Posted: Thu Jun 05, 2008 8:40 pm Post subject: Press in studs in drums while running 8 spokes? |
Anyone have press in studs and running 8 spoke wheels?
If so which studs?
I can't seem to get a straight answer from suppliers.
Also what lug nuts did you use?
I know some are tappered differently.
Thanks _________________ Selling the SB:
http://www.thesamba.com/vw/classifieds/detail.php?id=557335 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Sat Jun 07, 2008 10:43 pm Post subject: |
I don't have any experience with 8 spokes, but Dorman has a very impressive catalog of bolts etc. to order from! |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Mon Jun 09, 2008 3:08 pm Post subject: |
Should be the 14mm (about 9/16") same as the lug bolts you are running on stock rims . I noticed that the studs from my 90's GM and ford trucks are the same 14mm. Check with your local auto parts store thay should have replacements. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
Posted: Mon Jun 09, 2008 8:26 pm Post subject: |
I'm mainly looking for length.
I've gotten different measurements depending on the company I ask.
So I figured someone must run them so I'd get a better idea from them. _________________ Selling the SB:
