superman73 Samba Member
Joined: December 21, 2006 Posts: 2032 Location: Crystal Springs, Mississippi
Posted: Thu Jul 10, 2008 10:16 am Post subject: cleaning "water" spots on aluminum wheels |
ive got a set of riviera wheels that i bought used and they are pretty clean except for some spots on the aluminum, like water spots. what is the best way to clean them before polishing them? i have some mothers aluminum polish and a power ball. _________________ Chuck
Jesus Saves
70 deluxe bus
74 ghia 1776 dual carb
67 manx clone
various other parts cars.
http://www.thesamba.com/vw/forum/viewtopic.php?t=228364&highlight=superman73sb+bellsouth |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Thu Jul 10, 2008 4:04 pm Post subject: |
If the aluminum is raw (no clearcoat) I would get a green (fine) scotch brite pad - even one with a sponge on it from the grocery store will work. And gently scrub.
Assuming you are going to polish anyway. _________________ 1972 Standard Beetle
1969 Baja Beetle |
Posted: Thu Jul 10, 2008 5:33 pm Post subject: |
the "spots" actually appear to be the white corrosion in the early stages. i did use a green scotchbrite pad earlier with some aluminum wash by eagle one. i then polished them with mothers aluminum polish and a rag. i can get the power ball to work good. _________________ Chuck
Jesus Saves
70 deluxe bus
67 manx clone
Posted: Thu Jul 10, 2008 8:51 pm Post subject: |
Well, polishing is basically abrading the surface micron by micron until the surface is shiny. Maybe consider some type of clear coating to protect all of your hard work. _________________ 1972 Standard Beetle
1969 Baja Beetle |
