rriconoscuito Samba Member
Posted: Sat Jul 26, 2008 1:18 pm Post subject: rebuiling a solex 30 pict 2 |
how hard is it to rebuild and were do you find a rebuild kit |
stupidsongs2 Samba Member
Posted: Sat Jul 26, 2008 1:30 pm Post subject: |
It doesn't seem very difficult, my girlfriend rebuilt her's before she learned to adjust the valves.
Busdepot.com is your way to go for cheap parts, or a local VW yard, shops don't usually mark gaskets up more than what shipping would be anyway. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26300 Location: Douglas, WY
Posted: Sat Jul 26, 2008 2:27 pm Post subject: |
Just taking it apart and putting it in a can of carb/parts cleaner, then rinsing and blowing it out with high pressure compressed air, and reassembline with new gaskets is easy enough. Now if the throttle shaft bushings have wear in them, your average do-it-yourselfer won't be able to fix that, you need to have a carb specialist do that. And one thing about the 30PICT-2, there is a small metering screw you cannot adjust or remove, it's set up from the factory that way, and I've seen it where if there's a lot of crap inside the carb from it sitting for years, you might not be able to get that part of the carb clean. So sometimes you can't get that carb to run very well, that's one of the reasons that carb is my least favorite Solex. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sat Jul 26, 2008 2:33 pm Post subject: |
glutamodo wrote: |
Andy is so right... the 30 pict 2 is a decent running carb ( especially with the correct stock vac distributor) IF it is tunable... if the carb does not respond to adjustment after rebuild chances are the internal passage and the "factory set" screw that is behind a plug in the guts of the carb is clogged/blocked and it's not worth messing with.
And rebushing the throttle shafts is a bit more set up/tooling/work than the average home mechanic can handle. |
pjoduo Samba Member
Posted: Sat Jul 26, 2008 6:50 pm Post subject: |
Just wanted to second that it is very easy. Get a lot of space, the right tools, and be patient.
If you have some serious blockage let the parts sit in paint thinner, did charms for mine.
I have a 30 pict 3, but I am guessing it is similar enough. I do know I removed the one jet I was not supposed to and it ended up going back in fine and running great... but maybe I fluked. |
Posted: Sat Jul 26, 2008 6:58 pm Post subject: |
pjoduo wrote: |
Seemingly so... BUT as Andy pointed out the 30 pict 2 is unique in the fact that it has that "pre set mixture screw" in the carb body behind a plug... you can't get to it.... ( check out a nice cross section diagram in the Bentley or other good resource/manual, not just an "exploded diagram")
We are not saying not to try and rebuild it... just need to know when to "throw in the towl" on various model carbs for various reasons when a rebuild/good cleaning does not make it run any better and your sure the carb is a DUD...
Posted: Sun Jul 27, 2008 7:11 am Post subject: |
well i took it apart but now i found out i have a different engine than what i thought _________________ 72 Super
1679cc engle 110 dual weber 34 ict : vw: |
Posted: Sun Jul 27, 2008 7:18 am Post subject: |
keifernet wrote: |
Yeah, exactly. I happen to have that bentley diagram in my folder of FTP images, (look at item 27) plus a pic I took myself and added a caption...:
-Andy
pjoduo Samba Member
Posted: Sun Jul 27, 2008 11:30 am Post subject: |
What an odd design... |
Posted: Sun Jul 27, 2008 2:01 pm Post subject: |
Odd, yeah sort of. That was VW's first attempt at finer controls of the emissions output of the engine via tweaking the carburetor design. It's not surprising they didn't get it quite right. The 30PICT-3 was better. |
