Alex6373 Samba Member
Joined: August 05, 2007 Posts: 882 Location: Vancouver Island,B.C.
Posted: Tue Sep 02, 2008 5:43 pm Post subject: 12 volt tachometer on a 6 volt car? |
Digging around in my shop and i came upon a 12 volt tach and was wondering if it could be installed on my 63 6 volt beetle ?
and if so how will it read ?..... will it show correct rpms when set to 4 cylinders?
Any help on this would be very helpfull thanks Brett |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Tue Sep 02, 2008 5:55 pm Post subject: |
I don't think any 12 volt electrical device will work with a 6 volt system outright. You could get an inverter to boost the voltage. I just got a 6 volt tach through these guys.. http://www.tachshack.com. Nothing fancy but it works. Check my gallery for a pic. Chris _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
Posted: Tue Sep 02, 2008 6:00 pm Post subject: |
thanks for the help i actually hooked the 12 volt tack up and it and the light works but the rpm readings seem low and that is what i am wondering now if it wont last (the tack will burn out) and wont read correct? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Wed Sep 03, 2008 10:23 am Post subject: |
Great idea i just had a look at clip 1 and they sell a 6v to 12 v drop for around 10 buck again thanks for the idea |
Huntd105 Samba Member
Joined: February 13, 2019 Posts: 22 Location: England
Posted: Fri Jul 31, 2020 11:06 am Post subject: Re: 12 volt tachometer on a 6 volt car? |
Looking i to the same thing.. ive got a tach . Ive got a step up 6v to 12v.. my question is wiring it all up.
Im Guessing ignition switch 6v to step up converter 12 volts out to the tach .
Negative side of coil to other connection on the tach .
Is that the correct way? . Or do i also need to step up or down the wire coming from the coil?
Any help would be appreciated massively |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Fri Jul 31, 2020 11:59 am Post subject: Re: 12 volt tachometer on a 6 volt car? |
Huntd105 wrote: |
No - the feed wire from coil negative terminal would connect directly to the gauge. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
