Best Porsche engine swap for type I
linearone
linearone is offline
PostPosted: Fri Sep 19, 2008 4:43 am    Post subject: Best Porsche engine swap for type I Reply with quote
What is the best Porsche engine to swap into a VW beetle in terms of ease of swap? I was told the 80 HP vw914 engine drops right into place, no mods necessary, would a 911 engine fall into place without brain surgery?
I feel like if I were to buy another bug just to have a hot rod (I might) I wouldn't try to hot rod a 1600 block , rather Id swap an engine designed to do this from the factory.
Id love to just drop in a complete porsche engine.. what should I use?
scott s
scott s is offline
PostPosted: Fri Sep 19, 2008 5:01 am    Post subject: Reply with quote
Do a search for TIV into T1. Or Type Four into Type one.
It's not a "drop-in" procedure.
Also, check out Jake Raby's stuff...he's the TIV guru around these parts.
Nothing screams "poor workmanship" like wrinkles in the duct tape.
Mark33563
Mark33563 is offline
PostPosted: Fri Sep 19, 2008 5:35 am    Post subject: Re: Best Porsche engine swap for type I Reply with quote
[quote="linearone"]...I was told the 80 HP vw914 engine drops right into place, no mods necessary...quote]
If it were that easy EVERYBODY (exept the purists) would be running T-IV gear.
Completely different cooling gear. Yes, it will bolt up to the tranny, the ease of install stops about there. In its stock form (with cooling, etc.) it will not fit in the engine compartment. It will work in a baja but you will need a special flywheel (kennedy comes to mind) and a rear engine support for starters....
"That's an ultra-rare Dung Beetle... in reverse, it rolls up giant balls of crap. " - Dave24
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Gallery Classifieds Feedback
whutdidyousay
whutdidyousay is offline
PostPosted: Fri Sep 19, 2008 5:40 am    Post subject: Reply with quote
Just start with one of the special new cases on the market and add a nice turbo.... That'll get your hair standing on end.... Keep it a VW an you don't have to pay Porsche prices for parts and you get more power.
'68 bug (Sadie)
danke meine Freunde
I'm tryin to build a dream one piece at a time, just bear with me.
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Sep 19, 2008 10:15 am    Post subject: Re: Best Porsche engine swap for type I Reply with quote
Actually the best "Porsche" engine to use is a modified type 4 bus engine. Many have been done very well.
At least buy the video to see what is involved.
http://www.aircooledtechnology.com/store/product.php?productid=16466&cat=317&page=1
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Sep 19, 2008 10:18 am    Post subject: Re: Best Porsche engine swap for type I Reply with quote
Use a performance Type 1. Unless you already have the "Porsche" engine for free it's cheaper to stay with a VW engine.
Glenn
Member #1009
#BlueSquare
fastinradford
fastinradford is offline
PostPosted: Fri Sep 19, 2008 10:22 am    Post subject: Re: Best Porsche engine swap for type I Reply with quote
and more reliable, and cheaper to fix when it brakes and parts are more readily available
westcoast-paul
westcoast-paul is offline
PostPosted: Fri Sep 19, 2008 10:39 am    Post subject: Re: Best Porsche engine swap for type I Reply with quote
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-9607-DVD
Here is a 47 second sample of the video.
- Paul
linearone
PostPosted: Fri Sep 19, 2008 1:44 pm    Post subject: Reply with quote
has anyone ever squeezed a 911 engine in a type I ? i can almost get a fairly complete 911 motor from a budy's buddy.. just a thought
69 bugin
69 bugin is offline
PostPosted: Fri Sep 19, 2008 4:16 pm    Post subject: Reply with quote
the older type 4 engine in the 1960-69 porshe is allmost a drop in
but you would have to buy a up right kit and do some mods to the engine
bay of your bug it has been done with the 911 conversion but looks stuppid to me i just would stick with your type 1 and build it bigger
whutdidyousay
PostPosted: Fri Sep 19, 2008 4:23 pm    Post subject: Reply with quote
Besides, you don't want to be one of those guys (or gals) to say "I've got a porsche engine in my bug". Rolling Eyes ... We've heard about those...lol
'68 bug (Sadie)
danke meine Freunde
Randy in Maine
PostPosted: Fri Sep 19, 2008 5:12 pm    Post subject: Reply with quote
Serious money any time that you have to do anything to a 911 engine.
A well built type 4 or a well built type 1 engine would give you significant kick in a beetle.
Performance does indeed cost money. How much you got?
Mr. 010
Glenn is offline
PostPosted: Fri Sep 19, 2008 5:13 pm    Post subject: Reply with quote
911 is a 6 cylinder and quite a bit longer and heavier.
Not a good option.
Glenn
Member #1009
#BlueSquare
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Sep 19, 2008 5:45 pm    Post subject: Reply with quote
Here is a 911 in a Type 3. T-3 has a much bigger engine compartment, and they still had to do a lot of cutting.
Gary: OK. Ima poop.
73BuzzBomb
73BuzzBomb is offline
PostPosted: Fri Sep 19, 2008 7:31 pm    Post subject: Reply with quote
bay of your bug
Rolling Eyes
'73 Super
2270 type IV
Mr. 010
Glenn is offline
PostPosted: Fri Sep 19, 2008 7:33 pm    Post subject: Reply with quote
You mean the 356/912 engine. The Type 4 wasn't put in a Porsche until late 1969 when they debut the 914.
Glenn
Member #1009
#BlueSquare
Randy in Maine
PostPosted: Sat Sep 20, 2008 5:09 am    Post subject: Reply with quote
If I recall correctly, the 912 basically used the Porsche 356 Super 90 engine until 912 production was discontinued in 1969.
When the 912e was built in 1976, it did use the basic type 4 2.0 engine that was being used in the 914-4 at the time.
It was a nice car and they actually made a fair number of them.
Mr. 010
Glenn is offline
PostPosted: Sat Sep 20, 2008 5:11 am    Post subject: Reply with quote
The 912E (aka 923) was a stop gap so that Porsche had a low cost model after they stopped the 914 and before the 924 was ready.
Do some work the the engine and it was faster than the 911 of the same year.
Glenn
Member #1009
#BlueSquare
Mark33563
PostPosted: Sat Sep 20, 2008 7:27 am    Post subject: Reply with quote
If you are hell bent on sticking a porsche engine in the car, get the tranny along with it and graft in the whole assembly. No need to worry about flywheels and clutch compatibility.
I am trying to convince my father to let me stick this 914 gear (tranny and engine) into a '69 ghia vert he has parked in his barn. Would suprice the crap out of robert-ricer burner on the street Razz If not, I'll see about scoring a ghia sedan for the project...
Russ Wolfe
PostPosted: Sat Sep 20, 2008 9:30 am    Post subject: Reply with quote
They didn't start making the T-4 style engine until 1969.
Gary: OK. Ima poop.
