HP of a 1915cc engine?
dootch
dootch is offline
PostPosted: Sat Sep 20, 2008 4:33 pm    Post subject: HP of a 1915cc engine? Reply with quote
Hi just wondering what heads to go with on my engine that i'm rebuilding? I currently have a set of 94mm piston/cyl. set ,engle 120 cam and a pair of kadron dual carb set up. Also what type of HP will this make and i do believe this will be a 1915cc? If someone can share some info that would be great. Thx
1st65ghia
1st65ghia is offline
PostPosted: Sat Sep 20, 2008 5:50 pm    Post subject: Reply with quote
My 1914 is making 134hp with the same cam but dual 44idf's and DRD l5 heads.
dootch
dootch is offline
PostPosted: Sat Sep 20, 2008 5:57 pm    Post subject: Reply with quote
So can you tell me ruffly what kind of Hp i will put out if i went with the same heads as your using or is there no real difference from 1915 to 1914cc i guess not really? and do you know what your car does in the Quarter?
Ann Mezger
Ann Mezger is offline
PostPosted: Sat Sep 20, 2008 6:33 pm    Post subject: Reply with quote
He did give you a rough estimate. Unfortunately there is no way to give you much better / more accurate answer in respect to your particular engine because you haven't listed specific details about your combo. Engine displacement doesn't dictate HP or TQ & it's not as simple as "xyz" heads & cam = "xyz" hp. There are NUMEROUS variables to consider. Figuring out 1/4 mile times is even more complicated because you also have to factor in the gear ratios, tire size & tread, weight of the car, how well the suspension works & driver experience or error. What his car does has nothing to do with what your car can or will do.
www.vintageperformance.net
kielbasa
kielbasa is offline
PostPosted: Sat Sep 20, 2008 8:53 pm    Post subject: Reply with quote
its the same damn motor, just people either round down, or round up when calculating the displacement
Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries
vwracerdave
vwracerdave is offline
PostPosted: Sun Sep 21, 2008 10:21 am    Post subject: Reply with quote
90 HP
Your limiting factor will be the dual Kadrons. I would not bother with anything more then stock valve heads with a good fluff & buff.
69 X 94 = 1915.383cc I have no clue why people call them 1914cc
mufins13
mufins13 is offline
PostPosted: Tue Sep 23, 2008 9:30 am    Post subject: Reply with quote
im in the build of a very similar motor, looking to build a turbo motor. 69x94 crank with o44 heads with 40mm intakes and 35.5 exhaust, but i dont know what kind of cam to use. As of right now im looking at running the 40 IDFs that i have on a blow through set up. and im thinking about using a AS2 with an external waist gate. 8lbs on the street only looking for like 200hp.
Sigurd
Sigurd is offline
PostPosted: Tue Sep 23, 2008 11:46 am    Post subject: Reply with quote
vwracerdave wrote:
90 HP
Different figures for pi.
94 x 94 x 69 / 1000 x 3.14 = 1914.41
94 x 94 x 69 / 1000 x 3.14159 = 1915.38
I would love to see how people get 1916 Rolling Eyes .
Btw, 90.5 x 90.5 x 69 /1000 x pi = 1775.4 How are people getting 1776?
Jimmy111
Jimmy111 is offline
PostPosted: Tue Sep 23, 2008 12:08 pm    Post subject: Reply with quote
The same way they are getting 150HP out of their 1915's. Very Happy Magic!
SkrapMetal
Samba Hornblaster
SkrapMetal is offline
PostPosted: Tue Sep 23, 2008 1:50 pm    Post subject: Reply with quote
I had the same cam in my 1915, with IDF's, heads ported, 138hp. Ditch the kads and don't cheap out on the heads or you'll be wasting your time.
oo9less since 2007
-72 Ghia-
dootch
dootch is offline
PostPosted: Tue Sep 23, 2008 2:01 pm    Post subject: Reply with quote
What should i go with for heads ? maybe something like DRD L5 and what about 44 Webers?
dog_jr911
Swamp Donkey Assistant
dog_jr911 is offline
PostPosted: Tue Sep 23, 2008 5:50 pm    Post subject: Reply with quote
x2
AKA Chris™
ROCKIN a ESP LTD F2E
dog_jr911
PostPosted: Tue Sep 23, 2008 5:51 pm    Post subject: Reply with quote
why not a bigger displacement? if your going to take the time to build a larger engine, build THE large engine. 2110-2332
AKA Chris™
dootch
dootch is offline
PostPosted: Tue Sep 23, 2008 7:20 pm    Post subject: Reply with quote
So maybe i could use the Kads on my stock 1600 and go with Webers on my 1915cc right? that's if it's ok to use the Kads on a stock engine?
iowa vw
iowa vw is offline
PostPosted: Tue Sep 23, 2008 7:29 pm    Post subject: Reply with quote
Yeah the weber idf's will work better for the 1915. The Kadrons will work great on a stock engine.
Sigurd
Sigurd is offline
PostPosted: Wed Sep 24, 2008 6:11 am    Post subject: Reply with quote
My DRD 1915 longblock has L5 heads (40 x 35.5), and a 120 cam with my 40 Dells on top. Those recommendations came straight from Darren. Based solely on that, I would say that IDFs would be better for you.
andk5591
andk5591 is offline
PostPosted: Wed Sep 24, 2008 8:34 am    Post subject: Reply with quote
Not Hijacking, but I am putting together a 1915 in a couple weeks (ya know, I have been saying that for 6 months now) - anyway - stock cam. 1.4 rocker - moderate porting on heads, 1 5/8 header - for a street car. Are you saying the Kads wont flow enough? Once again - The engine will probably never see more than 4500 RPM..... Thanks
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
DarthWeber
DarthWeber is offline
PostPosted: Wed Sep 24, 2008 11:44 am    Post subject: Reply with quote
Stock valves = 1 3/8" header
40 x 35.5 valves = 1 1/2" header
42 x 37.5 valves = 1 5/8" header
dubsquared
dubsquared is offline
PostPosted: Wed Sep 24, 2008 11:58 am    Post subject: Reply with quote
My car weighs 1890 with me in it(1695 without). Ran a 15.3@86mph
Calculator says 99.9 hp.
8:1, 110 cam, 1.25 rockers, 043 40x35.5 barely ported(cleaned up), Empi 44s, aluminum crank pulley, 1 5/8 merged header with 2.5" magnaflow muffler...
It was a pretty mild build as it was intended for turbo, but it'll give you an idea anyway...
65 hp air-cooled, now with 100 hp
800+hp water-cooled
Both VWs...
nsmsam
nsmsam is offline
PostPosted: Fri Nov 06, 2009 12:48 pm    Post subject: Reply with quote
I also have the same question. I'm building a 1915(someone building that for me actually). Carbs will be weber 44. The heads is 44 x 37.5 How much will this affect hp ?
The cam is engle. It doesn't have 120 or 110 those type of number, it says 'tsc' something but it does look pretty tall.
Is our stock tranny ok for the increase hp?
