dootch Samba Member
Joined: April 02, 2007 Posts: 66 Location: Brantford,Ontario,Canada
Posted: Sat Sep 20, 2008 4:33 pm Post subject: HP of a 1915cc engine? |
Hi just wondering what heads to go with on my engine that i'm rebuilding? I currently have a set of 94mm piston/cyl. set ,engle 120 cam and a pair of kadron dual carb set up. Also what type of HP will this make and i do believe this will be a 1915cc? If someone can share some info that would be great. Thx |
1st65ghia Samba Member
Joined: November 16, 2006 Posts: 200 Location: CAMAS,WA
Posted: Sat Sep 20, 2008 5:50 pm Post subject: |
My 1914 is making 134hp with the same cam but dual 44idf's and DRD l5 heads. |
dootch Samba Member
Posted: Sat Sep 20, 2008 5:57 pm Post subject: |
So can you tell me ruffly what kind of Hp i will put out if i went with the same heads as your using or is there no real difference from 1915 to 1914cc i guess not really? and do you know what your car does in the Quarter? |
Ann Mezger Samba Member
Joined: October 13, 2003 Posts: 933 Location: Delaware
Posted: Sat Sep 20, 2008 6:33 pm Post subject: |
dootch wrote: |
He did give you a rough estimate. Unfortunately there is no way to give you much better / more accurate answer in respect to your particular engine because you haven't listed specific details about your combo. Engine displacement doesn't dictate HP or TQ & it's not as simple as "xyz" heads & cam = "xyz" hp. There are NUMEROUS variables to consider. Figuring out 1/4 mile times is even more complicated because you also have to factor in the gear ratios, tire size & tread, weight of the car, how well the suspension works & driver experience or error. What his car does has nothing to do with what your car can or will do. _________________ www.vintageperformance.net |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sat Sep 20, 2008 8:53 pm Post subject: |
dootch wrote: |
is there no real difference from 1915 to 1914cc i guess not really? |
its the same damn motor, just people either round down, or round up when calculating the displacement _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15279 Location: Deep in the 405
Posted: Sun Sep 21, 2008 10:21 am Post subject: |
90 HP
Your limiting factor will be the dual Kadrons. I would not bother with anything more then stock valve heads with a good fluff & buff.
69 X 94 = 1915.383cc I have no clue why people call them 1914cc _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
mufins13 Samba Member
Posted: Tue Sep 23, 2008 9:30 am Post subject: |
im in the build of a very similar motor, looking to build a turbo motor. 69x94 crank with o44 heads with 40mm intakes and 35.5 exhaust, but i dont know what kind of cam to use. As of right now im looking at running the 40 IDFs that i have on a blow through set up. and im thinking about using a AS2 with an external waist gate. 8lbs on the street only looking for like 200hp. |
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Tue Sep 23, 2008 11:46 am Post subject: |
vwracerdave wrote: |
90 HP
69 X 94 = 1915.383cc I have no clue why people call them 1914cc |
Different figures for pi.
94 x 94 x 69 / 1000 x 3.14 = 1914.41
94 x 94 x 69 / 1000 x 3.14159 = 1915.38
I would love to see how people get 1916 .
Btw, 90.5 x 90.5 x 69 /1000 x pi = 1775.4 How are people getting 1776? |
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Tue Sep 23, 2008 12:08 pm Post subject: |
The same way they are getting 150HP out of their 1915's. Magic! |
SkrapMetal Samba Hornblaster
Joined: January 18, 2006 Posts: 2558 Location: Dallas, TX
Posted: Tue Sep 23, 2008 1:50 pm Post subject: |
I had the same cam in my 1915, with IDF's, heads ported, 138hp. Ditch the kads and don't cheap out on the heads or you'll be wasting your time. _________________ oo9less since 2007
-72 Ghia- |
dootch Samba Member
Posted: Tue Sep 23, 2008 2:01 pm Post subject: |
What should i go with for heads ? maybe something like DRD L5 and what about 44 Webers? |
dog_jr911 Swamp Donkey Assistant
Posted: Tue Sep 23, 2008 5:50 pm Post subject: |
SkrapMetal wrote: |
Ditch the kads and don't cheap out on the heads or you'll be wasting your time. |
x2 _________________ AKA Chris™
ROCKIN a ESP LTD F2E |
Posted: Tue Sep 23, 2008 5:51 pm Post subject: |
dootch wrote: |
why not a bigger displacement? if your going to take the time to build a larger engine, build THE large engine. 2110-2332 _________________ AKA Chris™
dootch Samba Member
Posted: Tue Sep 23, 2008 7:20 pm Post subject: |
So maybe i could use the Kads on my stock 1600 and go with Webers on my 1915cc right? that's if it's ok to use the Kads on a stock engine? |
iowa vw Samba Member
Joined: November 08, 2006 Posts: 588 Location: Los Angeles, CA 90036
Posted: Tue Sep 23, 2008 7:29 pm Post subject: |
Yeah the weber idf's will work better for the 1915. The Kadrons will work great on a stock engine. |
Sigurd Samba Member
Posted: Wed Sep 24, 2008 6:11 am Post subject: |
My DRD 1915 longblock has L5 heads (40 x 35.5), and a 120 cam with my 40 Dells on top. Those recommendations came straight from Darren. Based solely on that, I would say that IDFs would be better for you. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Wed Sep 24, 2008 8:34 am Post subject: |
Not Hijacking, but I am putting together a 1915 in a couple weeks (ya know, I have been saying that for 6 months now) - anyway - stock cam. 1.4 rocker - moderate porting on heads, 1 5/8 header - for a street car. Are you saying the Kads wont flow enough? Once again - The engine will probably never see more than 4500 RPM..... Thanks _________________ D-Dubya Manx clone - 63 Short pan,1914.
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Wed Sep 24, 2008 11:44 am Post subject: |
Stock valves = 1 3/8" header
40 x 35.5 valves = 1 1/2" header
42 x 37.5 valves = 1 5/8" header |
dubsquared Samba Member
Posted: Wed Sep 24, 2008 11:58 am Post subject: |
My car weighs 1890 with me in it(1695 without). Ran a 15.3@86mph
Calculator says 99.9 hp.
8:1, 110 cam, 1.25 rockers, 043 40x35.5 barely ported(cleaned up), Empi 44s, aluminum crank pulley, 1 5/8 merged header with 2.5" magnaflow muffler...
It was a pretty mild build as it was intended for turbo, but it'll give you an idea anyway... _________________ 65 hp air-cooled, now with 100 hp
800+hp water-cooled
Both VWs... |
nsmsam Samba Member
Joined: May 01, 2009 Posts: 33 Location: San Jose, CA
Posted: Fri Nov 06, 2009 12:48 pm Post subject: |
I also have the same question. I'm building a 1915(someone building that for me actually). Carbs will be weber 44. The heads is 44 x 37.5 How much will this affect hp ?
The cam is engle. It doesn't have 120 or 110 those type of number, it says 'tsc' something but it does look pretty tall.
Is our stock tranny ok for the increase hp? |
