kinsey Samba Member
Joined: March 08, 2007 Posts: 101 Location: victoria, canada - henderson, nevada
Posted: Thu Jan 31, 2008 8:37 am Post subject: |
Just whatever you do stay away from the easy out solution
of fiberglass insulation. Any moisture gets sucked up and held
and that equals rust.
I spent a lot of $$$ and time getting rid of the rust so I don't want it back.
Putting in peel and stick and reflectix with the foil tape takes
a lot longer. I even sprayed in some foam insulation in a couple
of hard to get to spots, but IMHO it was the best way to go.
I also sprayed under the bus with a generous amount of
gravel gaurd wherever I could.
A key place to pay attention to is the floor in the front of the bus.
And I put new rubber over the pedestals.
Kinsey  _________________ IT'S NOTHING THAT A FEW DAYS
IN "THE KEYS" WOULDN'T FIX
Islamorada Blue- '78 bay window
"The Spirit of Margaritaville" |
david_594 Samba Member
Joined: November 08, 2006 Posts: 483 Location: Columbus, OH
Posted: Thu Jan 31, 2008 9:29 am Post subject: |
| kinsey wrote: | Just whatever you do stay away from the easy out solution
How sure are you on this? My westy came with fiberglass insulation stuffed in the ceiling and all the side panels from day one. Within the last month I redid all the roof and interior panels and there was really no signs of rust anywhere where the fiberglass insulation was originally. _________________ 1968 westy weekender
2000 jetta tdi
79 vespa p200e |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1019 Location: S>E>Alabama
Posted: Thu Jan 31, 2008 11:36 am Post subject: Cabin insulation |
IMHO fiberglass is just fine in NON MOIST AREAS, such as doors.The roof /headliner areas will be fine with a vapor barrier of some sort(plastic).But for doors, I feel something not affected by moisture, and yes the factory did install fiberglass in the slider door, but so much better products are available 40 years later .  _________________ 71 Westy, Quintilla 67 912 Porsche 67 SC currently in paint!! |
Posted: Thu Jan 31, 2008 11:38 am Post subject: Cabin Insulation |
Apologies everyone, a non moist area is not a door  _________________ 71 Westy, Quintilla 67 912 Porsche 67 SC currently in paint!! |
panic_fan Samba Member
Joined: April 21, 2008 Posts: 459 Location: Stockbridge GA
Posted: Thu Oct 02, 2008 11:52 am Post subject: |
| NOVA Bus wrote: | | Yesterday I checked out that Reflectex material at lowes, seem's thin, didn't notice the R value. |
I work at a HVAC wholesale. Its R4 and R8 if you double it. Makes sense!
So you guys have had good luck putting the reflectix bubble wrap in the engine compartment? Did i read that right or was it just inside the bus. _________________ Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
theizzardking Samba Member
Posted: Thu Oct 02, 2008 12:20 pm Post subject: |
just the inside of the bus works like a dream
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=60 _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
phip Samba Member
Joined: July 25, 2007 Posts: 463 Location: Pittsburgh, PA
Posted: Thu Oct 02, 2008 12:51 pm Post subject: |
| IzzardKing, How has the Reflectex held up under your flooring? I was about to put it in but rememberd it's basically just bubble wrap with foil on both sides and felt like the bubbles would pop or deflate if I put floor on top of it - much reducing the value as insulation. So I'd like to hear how it is holding up, but I'm thinking I'll put just Peel&Stick on the floors and Peel&Stick + Reflectex everywhere else. |
Posted: Thu Oct 02, 2008 1:19 pm Post subject: |
it holds up fine what you also want to do that makes a big differance in sound, insulation, is go with the hardwood pergo snap and click style flooring
think that any extra material on the ground will keep in heat and deaden sound, also a really really good idea is the rubber padding stuff that goes under the pergo you can see it in my thread it's that green stuff, it's made from rubber so absorbs no water and deadens sound like a champ and ups the r value, the size and spacing of the buble wrap makes it where walking on it and such wont pop it, as since the bubles are small the weight of the person and floor is dispersed well enough to not break them, i had to pull some out a few days ago when i was installing a different bed in my camper and was wondering this same thing, everything looks ok!
sorry if that's hard to read @ work and am quit busy today!~ _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Posted: Thu Oct 02, 2008 1:35 pm Post subject: SCORE! |
I just scored a full 50ft roll of the reflectix bubble wrap from work. It was damaged???!!!??? (small tear!)
Next I just need some sound deadner and let the fun begin! _________________ Rich
1970 Baywindow Bus
Posted: Thu Oct 02, 2008 1:50 pm Post subject: |
i'd like to also mention i used no other sound deadening material besides the bubble wrap an rubber floor pad. Rubber does a very good job of blocking sound, the sound deadening paint is nothing more than a rubberized paint, it may be marginally better but i can't see that the difference would be that much. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
NinetyEight Samba Member
Joined: February 12, 2008 Posts: 420 Location: Oklahoma
Posted: Thu Oct 02, 2008 2:45 pm Post subject: |
Check out RAAMaudio. They've got their main sound deadener RAAMmat, and they've got a closed cell foam mat that you apply with spray adhesive which should help out a ton with the insulation you're looking for. Compared to other sound deadeners the ensolite is pretty easy on the wallet as well.
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr _________________ Otto Bus - 1978 Daily Driver
Rico - 1975 Bay (FOR SALE!)
http://bit.ly/cDFNqf
70's Church Bus Project
http://www.FromTheEyesofABus.Blogspot.com |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1094 Location: San Francisco, CA
Posted: Thu Oct 02, 2008 3:06 pm Post subject: |
I used this stuff, help keep out the radio waves
http://www.sciplus.com/search.cfm?utm_source=inter...searchtest _________________ 70 Westy, 2027cc "dual DRLA 40 m130 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit |
Posted: Thu Oct 02, 2008 3:27 pm Post subject: |
link is dead? what is it a tin foil hat?  _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Posted: Thu Oct 02, 2008 4:26 pm Post subject: |
close, cut and past this in search function in there site.
( 37965 SILVER FOAM SHEET )
Posted: Fri Oct 03, 2008 10:35 am Post subject: |
I would not wrap my exhaust or my heads in it.
The stuff i use, I tested it with the cigarette lighter from the bus, thinking to do the same thing, the neoprene side was not effected by the red hot surface of the lighter, but when i applied it to the aluminum side it tern to ash. _________________ 70 Westy, 2027cc "dual DRLA 40 m130 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 2849 Location: Portland, Oregon
Posted: Fri Oct 03, 2008 7:46 pm Post subject: |
Just a couple of BASIC* things to remember (aimed at those who are new to this stuff):
1. If you want to reduce noise as well as thermally insulate your vehicle, you need to bond the insulation to the metal for maximum effectiveness. This is why EVERY acoustic insulator is adhered to the body panel in one way or another.
2. Any additional insulation (thermal and/or acoustic) beyond the stock application will help. Crumpling up newspaper and stuffing it in the empty spaces will thermally insulate the vehicle better than nothing at all. I am dead serious. This is actually a survival technique; you crumple up paper and stuff it in your clothing. The air pockets created are what make the insulation Partially dried maple leaves do the same thing (it was a Boy Scout thing, that's how I know).
3. Be very, very careful about spray-in foams. If they expand and have no where to expand to then they can possibly cause damage. They have a great potential to be messy. Some can contain components that are acidic to metal...not good. They have a VERY good potential to trap moisture. Personally, I wouldn't recommend foam. The damage it can cause isn't measured in days or months but in years down the road...
4. Foam padding has pretty much the negative of holding moisture as well. Over time it can rot and disintegrate and thus become ineffective. Neoprene isn't bad because of its dense, closed-cell nature.
5. Use quality materials so they'll last! This is something you want to do once. Of course, if you go the crumpled up newspaper route then it's just costing you time
*Basic information for understanding what's going on and the goals. Not a professional installers diatribe nor physics geek speech. That detailed stuff is easily found else where on the internet. _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Sundowner 2.0L; '95 VW Jetta GL 2.0L, Solo II EP; '06 Ducati Sport Classic 1000
http://www.type3registry.com/ |
BellePlaine Samba Member
Posted: Tue Oct 07, 2008 10:17 am Post subject: |
kinsey said
| Quote: | Putting in peel and stick and reflectix with the foil tape takes
a lot longer. |
phip said
| Quote: | | So I'd like to hear how it is holding up, but I'm thinking I'll put just Peel&Stick on the floors and Peel&Stick + Reflectex everywhere else. |
A couple of you mentioned "Peel and Stick" in addition to Reflectix. Where do I find "Peel and Stick"? And how much of the Reflectix are you guys going through? It looks like I can order it in 24in X 25ft; 16in X 25ft; and 4ft X 25ft. If doubling or triple layers is better than one layer should I go for the 4ft X 25ft size?
Thanks. _________________ '75 Riviera |
Posted: Tue Oct 07, 2008 10:38 am Post subject: |
I think they are talking about a dynamat type material. Its peel and stick sound insulation....unless Im wrong!  _________________ Rich
1970 Baywindow Bus
