NCdad Samba Member
Joined: August 28, 2008 Posts: 1525 Location: South Carolina
Posted: Fri Nov 21, 2008 8:50 am Post subject: Ignition switch wiring help needed! * 1970 Std Bug * |
I screwed up and passed up on not tagging the wires of where they came from... I took pics but some wires were not hooked up to start with...
this is the old switch that came out... the new one doesnt have the gray and brown wire...
trying to figure out where the Black with Yellow stripe wire goes?
am I right on the other wires? _________________ ROBERT
My VWs & Projects - | - German Invasion VW Show - Sept 7, 2024 Shelby, NC |
Grifter Samba Member
Joined: May 19, 2004 Posts: 960 Location: Mint Hill, NC
Posted: Fri Nov 21, 2008 9:43 am Post subject: |
I don't even see a bk/y on the wiring diagram.
The ones you have labeled look right to me. Sorry I can't help more. _________________ Greg
1970 Beetle...a work in progress
Yukon Yellow
Stock SP, Bosch vac advance
30PICT-3 swapped to a 30PICT-1
"At least I know that I don't know. Question is are you bozos smart enough to feel stupid? Hope so"
durhamfirecaptain wrote: |
Wow, we have VW's in North Carolina? |
NCdad Samba Member
NCdad Samba Member
Posted: Fri Nov 21, 2008 10:39 am Post subject: |
I was looking at the BUG ME video DVD #9 on wiring and he is going over a 1970...
He mentions a strange looking BRASS that comes from they key switch to a connector, which leaves that as a GRAY/BLACK wire that goes to the doorjam... which in turn becomes a GRAY wire going to the BUZZER.
I wonder if the BRASS wire was changed out on the new type switch as the BLACK/ YELLOW wire? _________________ ROBERT
bon2198 Samba Member
Joined: August 04, 2008 Posts: 1969 Location: Nashville, GA
Posted: Fri Nov 21, 2008 10:45 am Post subject: |
NCdad wrote: |
I wonder if the BRASS wire was changed out on the new type switch as the BLACK/ YELLOW wire? |
trace it and find out _________________ 1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it. |
NCdad Samba Member
Posted: Fri Nov 21, 2008 10:59 am Post subject: |
so what could happen if I hook it up to the wiring... and its wrong?
I found the connection box which was unhooked... but the prior owner spray painted over it when they painted the car. _________________ ROBERT
Posted: Fri Nov 21, 2008 11:34 am Post subject: |
NCdad wrote: |
I found the connection box which was unhooked... but the prior owner spray painted over it when they painted the car. |
worst case? fry the ignition switch, maybe more.
best bet is to pull up the wire diagram and trace each individual wire to ensure utmost accuracy. i know this sucks majorly, but it's the only way to be 100% sure of all connections.
but hey, you learned a great lesson here.... label label label!!! _________________ 1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
Posted: Fri Nov 21, 2008 11:48 am Post subject: |
There's also no guarantee that the "original" switch in that car is the correct one. _________________ Greg
Yukon Yellow
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Fri Nov 21, 2008 2:57 pm Post subject: |
Was you car made in Jul.'70 because if you look at the diagram for '71 the black/yellow is for the X circuit. This is like #15 in that it comes on with the key but it cuts off when cranking the starter to save power. The headlights are connected to this in '71 and the fan and wipers were added in '72 IIRC.
The gray wire is SU the buzzer wire which can be used with a relay to create an accessory position for the ignition so you can listen to the stereo with the engine off. The stereo shuts off only when you actually pull the key out. I have a wiring diagram for this if your interested.
My '73 std. was made in Aug.'72 and was a mismatch of two years stuff.
jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
NCdad Samba Member
Posted: Fri Nov 21, 2008 4:24 pm Post subject: |
jamesdagg wrote: |
jim |
Yes, the sticker on the door jam shows 07/70.
is the Wiring diagram the same that is on here? _________________ ROBERT
Posted: Fri Nov 21, 2008 5:58 pm Post subject: |
You will need to use both diagrams and other parts may be mismatched too.
Here's what changed and may be mixed.
1970 (1 Aug 69 to 31 July 70)
Chassis 110,2000,001 - 110,3100,000
Engine D 0,525,050 - D 0,674,999 34bhp(DIN)1200
Engine E 0,020,022 - E 0,022,000 37bhp(DIN)1300(US-M240smog)
Engine F 1,778,164 - F 2,200,000 40bhp(DIN)1300
Engine L 0,024,107 - L 0,026,500 40bhp(DIN)1500(US-M240smog)
Engine H 1,124,699 - H 1,350,000 44bhp(DIN)1500(not to US)
Engine B 6,000,001 - B 6,600,000 47bhp(DIN)1600 (to US)
US models get 1600cc single port engine.
US models get larger turn signals and side reflectors on housing.
Two sets of air intake slots added to engine lid.
Pressure control valve added to lubrication system.
Solex 30PICT/3 carby on 1600 models (30PICT/2 continues on 1500 models).
Diaphragm clutch springs to 1600 models - requires less pedal pressure.
US head restraints reduced in size.
On US models, buzzer sounds when door opened with key still in ignition.
New 3rd, 4th gears with finer teeth (reduced noise) added late 70.
1971 (1 Aug 70 to 31 July 71)
Chassis 111,2000,001 - 111,3200,000
Engine D 0,675,000 - D 0,835,006 34bhp(DIN) 1200
Engine AC 0,000,001 - AC 0,003,239 40bhp(DIN)1300
Engine AB 0,000,001 - AB 0,141,591 44bhp(DIN)1300
Engine AF 0,000,001 - AF 0,000,444 46bhp(DIN)1600
Engine AD 0,000,001 - AD 0,360,022 50bhpDIN 65bhpSAE 1600
Engine AE 0,000,001 - AE 0,558,000 47bhpDIN 60bhpSAE 1600(USA)
Dual port 1600 engine.
Three part induction manifold.
Solex 34PICT/3 carby.
Combination vacuum/centrifugal distributor.
Activated charcoal filter to catch fuel fumes.
New larger oil cooler mounted ‘doghouse' style and venting to atmosphere - gives better cooling to No 3 cylinder.
Bigger capacity (wider) cooling fan.
New clutch throw-out assembly and ball release bearing.
Headlights go off when ignition off.
‘Eyebrow' vents behind rear window for improved cabin ventilation.
Superbug with McPherson strut (vertical coil spring) front suspension introduced, (Standard beetle still in production too).
Bigger front brakes (drum brake models).
Larger oil pump.
Different camshaft retainer (4 rivets).
Wiring for VW computer analysis system added late 71.
In Australia, 1300s are standard beetles, 1600s are superbugs.
In the US, both super and standard beetles are offered with 1600 engines.
Here is the accessory diagram>
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Sat Nov 22, 2008 10:48 am Post subject: |
NCdad, if you are still trying to figure out the wiring, here's my tip...
I had a similar problem when my new ignition switch came w/ different wiring than the one I pulled out. I used a multimeter to check the wires and their behavior.
Install the switch and leave the wires loose behind the dash. Then test as below...
Find the thickest wires. If there is just a single "thick" (heavy gauge) wire that will be the input from the battery (possibly via the headlight switch). This is usually a RED wire.
The next thickest wire is likely the one to the starter and will usually be Red/Blk. Test this using the mm. There should be continuity only while the key is in the START position. If this is not the case, test the wires until you find the pair that have continuity while in the START position.
Next, find the wire that powers the headlights and wipers, usually Blk/Yel. This wire will have power from the battery when the ignition is in the ON position, but not when in START or OFF.
Find the ignition wire next. This is almost always Blk. It will connect to the battery wire in all positions except OFF.
There may be one wire that controls the door/seat buzzer. This is sometimes Grey and be grounded when the ignition is OFF and the key is in.
There may also be a Brown ground wire.
You should also test that the ignition switch can only go into START once. It must be switched OFF before it will go into START again. This is a mechanical limitation built into the electrical portion of the ignition switch.
Sorry for the long winded description, but this is a good way to test an ignition switch. _________________ AshMan40
NCdad Samba Member
Posted: Sat Nov 22, 2008 12:35 pm Post subject: |
Thanks, I have been messing with it... I know where the Red, RED/ BLK and the black go, as they were hooked up, when I took them apart.
The Black / Yellow was just laying loose under the hood, not connected to anything... are you saying that it goes to the headlight switch also?
I will probably swing by Guy Roberts VW and ask him since he is about 10 min up the road. It will give me an excuse to go by, I like looking at all the old cars in the back and customers that bring them in for service. _________________ ROBERT
Posted: Sat Nov 22, 2008 2:42 pm Post subject: |
The black/yellow should go to the X terminal on the ignition switch. It is for the headlights only, not tail lights. That's why they go off when cranking the starter and when you turn the key off.
Wipers were not connected to the X circuit in '70.
In the changes for '71 it says "Headlights go off when ignition off."
NCdad Samba Member
Posted: Sat Nov 22, 2008 3:15 pm Post subject: |
jamesdagg wrote: |
jim |
Ignition switch or the Headlight switch? _________________ ROBERT
Cusser Samba Member
Posted: Sat Nov 22, 2008 4:33 pm Post subject: |
OK: my 1970 does NOT have a black wire with yellow stripe there. I checked my new Bentley manual with color wiring diagrams and it also does not show black wire with yellow stripe coming out of the ignition switch.
However, it does show for a 1971 a black wire with yellow stripe with attaches to a red/black wire which goes to the headlight switch. I believe that's so that on the 1971 the headlights can only come on when the ignition switch is in the "run" position, and headlights are off while cranking or ignition switch is "off". _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
NCdad Samba Member
Posted: Sat Nov 22, 2008 6:23 pm Post subject: |
Thanks for the double check...
being that its a july of 1970 date, did VW start putting '71 parts in?
what did the vin #'s go up to for '70 models?
here was my door tag by the way.
Posted: Sat Nov 22, 2008 11:26 pm Post subject: |
The black/yellow goes from the ignition switch to the light switch X terminal in 1971. Later they had it go from the ignition switch to the fuse box where they had the fresh air fan and wipers wired to it.
Posted: Tue Nov 25, 2008 8:19 am Post subject: |
FYI, it's not unusual for aftermarket ignition switches to have "extra" wires.
My replacement '71 ignition switch had an extra wire compared to the stock switch I removed.
In your case, I'd wrap the end of the Blk/Yel wire w/ electrical tape to prevent it from shorting out; then coil up the wire and tuck it away somewhere behind the dash.
It sounds like you won't be needing it. _________________ AshMan40
