Hardware sizes
Goto page 1, 2, 3  Next
PostPosted: Sat Aug 16, 2008 7:25 pm    Post subject: Hardware sizes Reply with quote
This is a sticky post to list any hardware size and location used on any VW model. Feel free to post and we will update this first post with the overall information.
Bart Dunn
Samba Consiglieri
Bart Dunn is offline
PostPosted: Tue Aug 19, 2008 6:38 am    Post subject: Reply with quote
Fatchick/Bay bus wheel lug nuts: 14 x 1.5.
Snapon has a rethreader (like a die but cheaper) for under $3, including shipping. Errant hammer blows and a resultant inability to put lug nuts on are now a thing of the past.
Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Aug 19, 2008 6:40 am    Post subject: Reply with quote
M8x1.25 various lengths used all over the car. This is the most common bolt size.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
Russ Wolfe
Russ Wolfe is offline
PostPosted: Tue Aug 19, 2008 9:33 am    Post subject: Reply with quote
6mm x1.00 = drain plate studs and engine tin screws.
14mm x 1.25 = spark plugs.
10mm x 1.5 = early head studs
8mm x 1.25 = late head studs
Glenn?? What is the size of the point hold down screw. I get a lot of distributors that have the wrong screw in them?
Gary: OK. Ima poop.
hpw
hpw is offline
PostPosted: Fri Sep 12, 2008 11:44 am    Post subject: Reply with quote
Can any one direct me in learning how to measure and size correctly or a
good gauge?
http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2
Russ Wolfe
PostPosted: Fri Sep 12, 2008 5:28 pm    Post subject: Reply with quote
good gauge?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47257
http://www.sears.com/shc/s/search_10153_12605?keyw...utton=find
Gary: OK. Ima poop.
anubiscrs
anubiscrs is offline
PostPosted: Thu Jan 15, 2009 11:26 am    Post subject: Reply with quote
what is the bolt size for the shifter on a 60 bug pan?
chet
60 beetle vert
Russ Wolfe
PostPosted: Thu Jan 15, 2009 11:37 am    Post subject: Reply with quote
8mm x 1.25, but it is a pointed set screw. A special bolt. Same as the later cars.
Gary: OK. Ima poop.
bill may
bill may is offline
PostPosted: Thu Jan 29, 2009 1:35 pm    Post subject: Reply with quote
8MM X 1.25 X 25MM part number N 10 325 1
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
vwpieces
vwpieces is offline
PostPosted: Wed Mar 25, 2009 5:09 am    Post subject: Late pop out hinges Reply with quote
I was doing some hinge work on a set of late 65 & up T1 popout window latches. I had several broken pieces. I drilled out the pins in the pivots, swapped parts around to complete a set. Some hinges used roll pins & some used punched pins. I purchased some 3mm roll pins from mscdirect.com 2 sizes were needed, 10mm long & 14mm long. I also bought some "E" clips in 4mm size for where they mount to the glass. If you are taking apart a set of hinges to have them rechromed you may find these parts to come in handy for reassembly.
Roll pins (spring pin) 2 sizes needed
3mmX14
3mmX10
"E" clip Metric DIN 6799
4mmID X 0.7 thickness
I also have repaired a few Bus rear engine lid hinges. I originally used a roll pin for this application also but now bought some solid steel Dowel pins. Size needed is 5mmX50mm
I had to buy boxes of 100 of each listed above. More than I will ever use. If anyone needs any, send me a few bucks & I'll send some your way.
68 BUS
83 JETTA TURBO DIESEL
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Tue Apr 28, 2009 3:54 pm    Post subject: Reply with quote
good gauge?
This type is nice (I have it):
http://www.sears.com/shc/s/p_10153_12605_00952316000P?keyword=bolt+gauge
For getting diameter you can get something along these lines:
Go to Eastwood.com or McMasterCarr.com and do a search on "bolt gauge".
The length of a bolt is always from the bottom of the head (the side of the head that touches the work surface when you're fastening; it's the side where the threads meet the head) to the end of the threads.
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Sundowner 2.0L; '95 VW Jetta GL 2.0L, Solo II EP; '06 Ducati Sport Classic 1000
http://www.type3registry.com/
hpw
hpw is offline
PostPosted: Sun May 03, 2009 5:14 am    Post subject: Reply with quote
Air_Cooled_Nut, I have dealt with Mcmaster/Carr, great place. Do you know if this would cover all my needs for the vw?
$30.00
Metric Gauge— Sizes: M3 x 0.5, M4 x 0.7, M5 x 0.8, M6 x 1.0, M7 x 1.0, M8 x 1.0, M8 x 1.25, M10 x 1.0, M10 x 1.25, M10 x 1.5, M12 x 1.25, M12 x 1.5, M12 x 1.75, M14 x 1.5, M14 x 2.0, M16 x 1.5, M16 x 2.0, M20 x 1.5, M20 x 2.5, M24 x 2.0, M24 x 3.0.
Air_Cooled_Nut
PostPosted: Sun May 10, 2009 10:29 am    Post subject: Reply with quote
I'm not a VW fasteners expert so I don't know if that will work 100%. Personally, I prefer to have one gauge for measuring threads and another for measuring diameter. That way you cover all your bases Wink Some times you get a fastener that isn't a common size. Also, I do know that the seat belt bolt threads are NOT metric, they are measured as TPI (Threads Per Inch).
What you show looks like a good, general sizer. Your next purchase should be a tap and die set. I got a standard set and a metric set from Sears and it satisfies most of my needs...if it doesn't then I just buy the specific tap/die I do need Smile Not only can you then make your own threads but you can use the set to chase (clean) threads. Both of my sets came with instructions. Super easy!
notchback
Insensitive Jerk
notchback is offline
PostPosted: Sun May 10, 2009 5:11 pm    Post subject: Reply with quote
What about the screws that hold the rearview mirror on in a '65 Type 3?
Brain Trust member #13
Sad, unnecessary & cruel.
Let's quit sending money to the middle east and let them hate us for free.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Wed May 27, 2009 2:27 pm    Post subject: Reply with quote
Just replaced the rear shocks on my '67 Bug, and I used M12x100mm bolts, which fit well. The threads on my new bolts were coarser than what was originally used, so if someone has a source for more correct bolts, I'd be all ears.
- Scott
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- daily driver status while I work on the other two
049 > 070 > 053 > 009
Vintage Split
Vintage Split is offline
PostPosted: Tue Jun 23, 2009 3:34 pm    Post subject: Reply with quote
What are the bolt sizes for the seat belts on a 67 Bus (walk thru) - front and middle?
Thanks.
--Mike--
0-60...eventually.
Russ Wolfe
PostPosted: Wed Jun 24, 2009 6:22 am    Post subject: Reply with quote
Thanks.
They are an SAE thread, not metric. 7/16 x 20 thread. 7/16 SAE Fine thread. 1 1/2" long. Grade 5. This is an industry standard for seat belt hardware.
Gary: OK. Ima poop.
Vintage Split
PostPosted: Wed Jun 24, 2009 8:27 am    Post subject: Reply with quote
Thanks.
Wow, learn something new all of the time. I actually used 7/16 in between the seats because it seemed to fit. However the holes near the doors did not. Could be cruddy or paint build up. Thanks again.
--Mike--
0-60...eventually.
Stuggi
Stuggi is offline
PostPosted: Sat Aug 29, 2009 6:56 pm    Post subject: Reply with quote
I see this pop up every now and then, and the Muir book doesn't list it, so here it goes.
'70 Bug Steering Wheel Nut (old school wheel); M18
Orange Bug 1970 Beetle
Green Bay Bus 1969 Panelvan
Orange VW Fest!
Pulled out of a Lake Fest!
roy63
roy63 is offline
PostPosted: Fri Sep 25, 2009 2:34 pm    Post subject: Reply with quote
here is a question, what is the thread and pitch on the heater control knob on a 63 sedan? mine was damaged by my blaster. I have been unable to find much on this topic.
Some day when the rust is gone, I will at last found inner peace... (Peace has Been Found)
Some day it will be done. Then on to the next one...
"Wide awake, and keeping distance from my soul"
