normalario Samba Member
Posted: Wed Jun 09, 2004 5:49 pm Post subject: Spindle mount wheels??? |
| I want to get rid of my front brakes on my baja and use a spindle mount wheel. Do these wheels require special spindles or can I use the stockers? |
HomespunKustom Samba Member
Joined: January 07, 2004 Posts: 743 Location: SALUTE!!
Posted: Thu Jun 10, 2004 8:27 am Post subject: |
i believe they run on a different spindle...but why would you want to eliminate your front brakes? strictly off road use? _________________ Before your criticize someone, you should walk a mile in their shoes. That way when you criticize them you're a mile away and you have their shoes!
'68 type 1 Kit
I am Spiderman. (part deux) |
UncleBob Grease Midget
Joined: August 21, 2002 Posts: 2875 Location: Northeast Florida
Posted: Thu Jun 10, 2004 8:57 am Post subject: |
Stock spindles, bearings go into wheel instead of drum. Not sure if they are available for Ball Joint, I've only seen King-Pin. _________________ OG JHC
don't worry, the ciggaret is fake. |
Posted: Thu Jun 10, 2004 9:51 am Post subject: |
they don't make them for ball joints. ive looked _________________ Before your criticize someone, you should walk a mile in their shoes. That way when you criticize them you're a mile away and you have their shoes!
'68 type 1 Kit
Posted: Thu Jun 10, 2004 1:34 pm Post subject: |
| I run mostly dunes plus I am registered as an off road vehicle. I have kingpin front end. I guess I will be tearing the front drums off today!!! |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 7034 Location: SoCal
Posted: Thu Jun 10, 2004 3:03 pm Post subject: |
out of curiosity, what do you do with a spindle mounted wheel if you get a flat tire? _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Posted: Thu Jun 10, 2004 4:11 pm Post subject: |
walk _________________ Before your criticize someone, you should walk a mile in their shoes. That way when you criticize them you're a mile away and you have their shoes!
'68 type 1 Kit
Posted: Thu Jun 10, 2004 6:08 pm Post subject: |
i'll stick with my brakes, thanks.... _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Tue Jun 29, 2004 8:01 pm Post subject: |
| Ok! I have completely rebuilt my front end. I went to put on my brand new douglas wheels and they didn't fit. Bearings were to small. The diameter of the spindle goes from 1.25"/1.245"/1.24"/1". Does this sound like a stock king/link spindle? Also had a hell of a time putting in the link pins/bushings. Didn't fit worth a damn even after freezing the pin and heating the spindle bushings. Is this normal? Please help!!! |
Posted: Fri Jul 02, 2004 12:02 pm Post subject: |
sounds to me like you got linkpin spindle wheels. What front end setup are your running? stock drums, aftermarket disk brakes?? more info _________________ Before your criticize someone, you should walk a mile in their shoes. That way when you criticize them you're a mile away and you have their shoes!
'68 type 1 Kit
Posted: Sun Jul 04, 2004 6:49 pm Post subject: |
The front end is a link/king pin. The reason the wheels wouldn't fit is because I have combo spindles which I didn't know. The dougles wheels are metric while the shaft on the spindle is standard. I am still trying to make them work but I looks like I will be selling them and machining the drums.
Anyone looking for brand new spindle mounts with tires and bearings or want to swap for 5 lug centerlines??? |
