smokey the bear Samba Member
Joined: January 31, 2009 Posts: 11 Location: Republic WA
Posted: Sat Jan 31, 2009 10:34 pm Post subject: 1971 baja bug |
So i am new to the vw world and am learning as i go. but i have a 1971 vw 1600 dp. not a super. i have the baja kit and most of what i need. but i ahve a few questions. I was really thinking of doing an exoskeleton roll cage.but am not sure if that would be to much weight v.s. a 6 point cage. than if i did do the exoskeleton what do you guys think i should tie it into. I was also wondering what should i use for shocks. i have a limited income being i'm only 15 but i would like to be able to get some air and not bust anything. but mostly i would be in the mountons. and beings i'm new to this if there is anything that i should know that might help me in my build let me know thanks. |
SpenceSuper11 Samba Member
Joined: October 31, 2008 Posts: 146 Location: Arlington, WA
Posted: Sat Jan 31, 2009 11:08 pm Post subject: |
I would suggest an inner roll cage. For one they're cheaper and two you can find many different variations pre fabbed. I saw a couple pictures of a bug with an external cage a couple days ago when I was wandering through the gallery. I'll try to find them again. It's a little ugly in my opinion if not done right. _________________ 1600cc '73 Super baja
Opinions expressed in this post are not necessarily shared by anyone who is not intelligent, sexy, well-off financially, and a great dancer. |
Posted: Sat Jan 31, 2009 11:20 pm Post subject: |
Ah, here we go. Found this on page 552 of the offroad section.
You'd have a lot of fab work ahead of you if you want to do anything like this. _________________ 1600cc '73 Super baja
vaderoni Samba Member
Joined: October 30, 2008 Posts: 184 Location: Loomis, CA
Posted: Sun Feb 01, 2009 12:44 am Post subject: |
^^^^Im sorry but that's disgusting _________________ Teach me, I may not know... |
runslikeapenguin Samba Member
Joined: August 07, 2005 Posts: 4674 Location: Federal way WA
Posted: Sun Feb 01, 2009 12:46 am Post subject: |
a little bit ugly? surely you jest. thats a whole lot of ugly right there.
to put it quite basically the cars body its self was designed to withstand a decent amount of force in the event of a roll over or crash. a roll cage is a secondary precaution and a key chassis component in most cases involving off road VW's.
most well built roll cages will include small external features to a roll cage, like tied in bumpers, running bars, and sometimes roof racks.
not to mention that there is really no bullet proof way to secure an external roll cage on a bug. _________________ never forget 1-31-07 |
xirxious Samba Member
Joined: November 12, 2007 Posts: 665 Location: Seattle
Posted: Sun Feb 01, 2009 2:35 am Post subject: |
It looke like that was made to be removable? There are wing nut screws at the bottom? |
nukeworker Samba Member
Joined: September 21, 2005 Posts: 490 Location: Area 51
Posted: Sun Feb 01, 2009 7:52 am Post subject: |
Looks like somebody likes to weld. |
corradolvr Samba Member
Posted: Sun Feb 01, 2009 9:01 am Post subject: |
Do an inner cage. If you're going to go to long travel eventually an inner cage will be a better option. That exo-cage should be in the abortions section. That thing is hidious . You would have to tie the front end in and that would be a mess. That might make things difficult for a one piece front end as well. _________________ My Build Post
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= |
Posted: Sun Feb 01, 2009 9:31 am Post subject: |
ya thats not really what my idea of an exo looked like. it looks like someone never learned to bend pipe. At all. ok so inner is the way to go. so what should i do about shocks. this is going to be my daily driver but i want to be able to go offroad mabey get some air and not have to worry about breaking anything. |
jj14u2c2 Samba Member
Joined: March 21, 2008 Posts: 125 Location: St. Paul, MN
Posted: Sun Feb 01, 2009 11:08 am Post subject: Exo design |
Smokey,
Here are some pics that were posted by Adrenalin Junky awhile ago. I think if you compare these pics with ones SpenceSuper11 posted, it could look awesome. The rear exo on the yellow Baga is tight because it follows the flow of the existing body lines. If you would continue to follow the body line flow forward and over the body properly I think it would be an intimidating sight when you pull up behind someone and they see you in their rear view mirror.
Even though it would take some skilled tube bending it could be done.
Posted: Sun Feb 01, 2009 11:09 am Post subject: |
Posted: Sun Feb 01, 2009 3:08 pm Post subject: |
ya i dont really have the money for that sweet of a set up. but that bug is B.A. but what do you guys think i should do for shocks? dont mean to sound like a broken record but but that is the one thing that i really have no clue on.[/img] |
Posted: Sun Feb 01, 2009 3:17 pm Post subject: |
smokey the bear wrote: |
how much do you want to spend? thats all it really boils down to. _________________ never forget 1-31-07 |
Posted: Sun Feb 01, 2009 3:20 pm Post subject: |
well i dont want to spend more than 500 dollars at max. |
riNR Samba Member
Joined: June 28, 2006 Posts: 1223 Location: Whitby, Ontario, Canada
Posted: Sun Feb 01, 2009 3:53 pm Post subject: |
SpenceSuper11 wrote: |
You'd have a lot of fab work ahead of you if you want to do anything like this. |
That's just wrong man! Who in their right mind would build that abortion? |
LSK Samba Member
Joined: July 30, 2008 Posts: 136 Location: Burbank CA
Posted: Sun Feb 01, 2009 6:16 pm Post subject: |
with some emulsion 2" FOAs you might be able to keep it under $500 |
Posted: Sun Feb 01, 2009 9:38 pm Post subject: |
i dont have the money to change out trailing arms ether. so i would be putting these shocks in with other stock things. such as the shock towers and so on. so i really am not sure what to do with the suspension. thanks for alll the ideas i'm not sure if those shocks would fit or not i really have no clue i was looking at these.
http://www.chircoestore.com/catalog/product_info.php?cPath=64_200&products_id=2025 |
Posted: Sun Feb 01, 2009 9:58 pm Post subject: |
those are good to. someone else might want to chime in but theres a part number for some bilsteins that have the right upper mount for a ball joint front end. i cant remember. _________________ never forget 1-31-07 |
Posted: Mon Feb 02, 2009 4:54 pm Post subject: |
i dont have a ball joint front end. |
