67 deluxe metal repair
Goto page 1, 2, 3 ... 12, 13, 14  Next
brettsvw Premium Member
brettsvw is offline
PostPosted: Sun Feb 01, 2009 7:54 am    Post subject: 67 deluxe metal repair Reply with quote
Yesterday I started to cut away the drivers side rear corner. The rear of my Bus is needs the most work. So I decided to dive in rear first.
Image may have been reduced in size. Click image to view fullscreen.[/img]
brettsvw is offline
PostPosted: Sun Feb 01, 2009 7:57 am    Post subject: Reply with quote
Just what one wants to see. Its not a pretty sight.
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:00 am    Post subject: Reply with quote
I am graduating from Bugs and Ghias. My 59 ghia convert. rockers was cake compared to this.
Lair
Lair is offline
PostPosted: Sun Feb 01, 2009 8:04 am    Post subject: Reply with quote
Ouch.
Is the other side that bad?
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:07 am    Post subject: Reply with quote
More cutting. My guts always start to settle after the rust is removed.
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:08 am    Post subject: Reply with quote
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:13 am    Post subject: Reply with quote
This area was a surprise to me. I had no idea the rust was hidden under the paint.
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:17 am    Post subject: Reply with quote
This is the veiw from under. This fix is not as bad as it looks. I will show full detail of repair when I start to fit metal from a 65 rear I purchaced from Gainsville, Fl.
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:20 am    Post subject: Reply with quote
More cleaning, and rust removal. Today Super Bowl so nomore work today.
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:24 am    Post subject: Reply with quote
Could not resist alittle cleaning.
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:25 am    Post subject: Reply with quote
brettsvw is offline
PostPosted: Sun Feb 01, 2009 8:29 am    Post subject: Reply with quote
You can see the hole around the vent where PO had added scoops. Looks like twice as there are two sets of holes. Also there was a oil cooler mounted to the side of the Bus.
brettsvw is offline
PostPosted: Sat Feb 07, 2009 2:25 pm    Post subject: Reply with quote
Did a little more cutting today.
brettsvw is offline
PostPosted: Sat Feb 07, 2009 2:28 pm    Post subject: Reply with quote
Did not realize it, that VW factoryspotwelders just put welds where ever they please. It looks like swiss cheese where I drilled the spot welds.
brettsvw is offline
PostPosted: Sat Feb 07, 2009 2:30 pm    Post subject: Reply with quote
Here are the left overs from the rear corner. Anyone need this.
Jerry
Jerry is offline
PostPosted: Sat Feb 07, 2009 6:34 pm    Post subject: Reply with quote
Lookin good! Hey Brett, at least it's a little warmer down there in sunny FL!
'67 21 Deluxe, Ollie
'66 So42, Misty
'67 13 deluxe
brettsvw is offline
PostPosted: Sat Feb 07, 2009 8:07 pm    Post subject: Reply with quote
This evening was in the low 60's. But the last two days were 21 degrees early mourning. We are not use to that kind of weather here.
brettsvw is offline
PostPosted: Mon Feb 09, 2009 4:19 pm    Post subject: Reply with quote
My first try. I scraped this one.
brettsvw is offline
PostPosted: Mon Feb 09, 2009 4:24 pm    Post subject: Reply with quote
This was a better try at it.
brettsvw is offline
PostPosted: Mon Feb 09, 2009 4:37 pm    Post subject: Reply with quote
I am happy with one. Now where to cut and weld
Page 1 of 14
