4" speedometer gauge for a 69 ghia
69Ghia-pet
69Ghia-pet is offline
PostPosted: Tue Mar 10, 2009 12:49 pm    Post subject: 4" speedometer gauge for a 69 ghia Reply with quote
I have been hunting for an aftermarket speedometer gauge for a 69 ghia. All I can seem to find is 3 3/8" or 3 3/4". Does anyone know who make them? I think it would look really silly if I have all aftermarket gauges and the old speedometer. I have called Egauges and got no where. Thanks for the help.
Matt [/url]
dink911
dink911 is offline
PostPosted: Tue Mar 10, 2009 12:54 pm    Post subject: gauge size Reply with quote
you need to find one that is 4 1/4 and if you do post it because I cant find one either. I assume its a ghia only size for the 68-71 years Sad
Steven G.
71 Ghia
"When a defining moment comes along, you define the moment... or the moment defines you."
sactojesse
sactojesse is offline
PostPosted: Tue Mar 10, 2009 1:08 pm    Post subject: Reply with quote
If you're trying to match VDO Cockpit gauges, a 914 speedo might work. It's black with a black bezel and red needle, but it's only 4 inches in diameter. Not my picture:
http://www.p914.com/p914-resources/p914-gauges/p914-gauges-speedo-120_70-72_front-biege.jpg
1966 Karmann-Ghia convertible
69Ghia-pet
PostPosted: Tue Mar 10, 2009 1:19 pm    Post subject: Reply with quote
Thanks sactojesse. That excatly what I am looking for. I will start looking for Porsche gauges. Any good retails you know of? Did you put them in your ghia?
CLKWRK
CLKWRK is offline
PostPosted: Tue Mar 10, 2009 1:22 pm    Post subject: Reply with quote
914 speedo diddnt fit my 71, too small
I ended up painting up my stock speedo to match, looked alright
69Ghia-pet
PostPosted: Tue Mar 10, 2009 1:30 pm    Post subject: Reply with quote
Was it a bitch to take apart? But it looks great!
dink911
dink911 is offline
PostPosted: Tue Mar 10, 2009 7:33 pm    Post subject: Reply with quote
Here is a shot of what I did, but I would still like them to match some aftermarket oil temp, oil pressure, and volt gauges
Steven G.
71 Ghia
CLKWRK
CLKWRK is offline
PostPosted: Wed Mar 11, 2009 8:32 am    Post subject: Reply with quote
it takes a bit of patience to pry off the chrome ring, and make sure you replace the needle i nthe exact same spot when you reassemble, or it will throw off your calibration.
btw type 3 speedo is the right diameter, you just need to grind off the mount tabs in the back because they mount differently.
69Ghia-pet
PostPosted: Fri Apr 03, 2009 11:12 am    Post subject: Reply with quote
CLKWRK- what kind of cd player is that? I am looking for a CD player that will not require any dash modifications.
CLKWRK
CLKWRK is offline
PostPosted: Fri Apr 03, 2009 11:47 am    Post subject: Reply with quote
that is a sony xplod deck, i does not fit in the original hole , I had to mount it from the back with a fancy bracket I made.
I am not using it anymore as I did cut my dash for my 911 gages
Rainman
Rainman is offline
PostPosted: Mon Oct 14, 2019 8:10 am    Post subject: Re: 4" speedometer gauge for a 69 ghia Reply with quote
Will a 66 bug speedo fit a 69 Ghia? As far as hole size? I realize the obvious other differences but would it actually fit ?
c21darrel
c21darrel is offline
PostPosted: Tue Oct 15, 2019 2:20 pm    Post subject: Re: 4" speedometer gauge for a 69 ghia Reply with quote
Beetle speedo will fit if you are willing to open the hole up a bit. Also they attach different, two ears on backside. I welded studs on back of dash face. I had one in my ghia back when I first got it up and running. Later I swapped it out for a trip speedo.
You can see the studs in this pic.
GhiaBuild
1967 DC build
