Endicott jb Bondo King
Joined: February 17, 2008 Posts: 1902 Location: Havre, MT
Posted: Sun Mar 15, 2009 5:11 pm Post subject: Low mount dual zoom exhaust |
Does anyone have any info on this exhaust? I like the idea and was thinking it could work well with my car. I just don't want to put the money into something that might be garbage. _________________ Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76910 Location: Sneaking up behind you
Posted: Sun Mar 15, 2009 5:14 pm Post subject: |
It's garbage.
A 4 into 1 header will be much better. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Mar 15, 2009 5:16 pm Post subject: |
Is this one any better? I just like the look of this type of set up. _________________ Josh
OORAH!!
1974 VW Panel Bus
.|_____|.
(0\_!_/0)
buzzboy Samba Member
Posted: Sun Mar 15, 2009 6:08 pm Post subject: |
This is a much better subject as it attaches to a 4 into 1 style header. I don't know what kind of baffle is in there if at all but I personally really like this style of exhaust and would have used that exact same one if it didn't cause me to loose the inch or two that it does. On a street car though you should have no problems. |
Posted: Sun Mar 15, 2009 6:25 pm Post subject: |
Alright cool. That's what I'll probably get. _________________ Josh
OORAH!!
1974 VW Panel Bus
.|_____|.
(0\_!_/0)
jwb973 Samba Member
Posted: Wed Mar 18, 2009 9:04 am Post subject: exhaust |
I've got a set of these. Haven't installed them yet. Think they would work good on a stock body, baja, etc. Hopt to install these on a kit car in the next week or so, if they don't fit they're for sale.
Go to waltstoys.com and you can see the car. walt 973, Atlanta area
http://my.att.net/p/s/community.dll?ep=16&groupid=339702&ck= |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Wed Mar 18, 2009 9:55 am Post subject: |
It would probably work great if you are the type of person who does not adjust their valves. |
wbrown45 Samba Member
Posted: Wed Mar 18, 2009 9:57 pm Post subject: |
From the looks of the collector flange the mufflers should be below the valve covers. It would be tight, but you should be able to access the valves. But the ground clearance would be pretty marginal. _________________ OK Thang |
73 KAFER Samba Member
Joined: September 02, 2007 Posts: 1385 Location: St. Marys, Pa.
Posted: Thu Mar 19, 2009 8:27 am Post subject: |
Endicott jb wrote: |
Is this one any better? I just like the look of this type of set up. |
I had the dual set-up a few years ago, It broke right at the three bolt flange....weight of the mufflers. They were on for two years and were jet-hot coated and did not rust thru, just cracked at the flange from vibration and weight of the mufflers. In fact, I had lighter weight alluminum Super-Trapp mufflers on it at the time and still cracked in half.
Mark _________________ 1973 Beetle
#3 http://www.thesamba.com/vw/forum/album_page.php?pic_id=775620Kafer-Cup vintage road racer |
nobody Samba Member
Joined: February 08, 2009 Posts: 11 Location: Ohio,Usa
Posted: Thu Mar 19, 2009 9:10 am Post subject: Re: Low mount dual zoom exhaust |
Does anyone have any info on this exhaust? I like the idea and was thinking it could work well with my car. I just don't want to put the money into something that might be garbage. |
I have a set on my trike; easy mount with a good sound. It has been on my trike for years now and still looks and sounds good. My 74 super has a brand name exhaust and doesn't sound near as well.
When my 78 vert gets roadworthy it will have this system. I'm happy with it |
vwsb74 Samba Member
Posted: Wed Apr 07, 2010 9:32 pm Post subject: |
hi, can you post some Picts of this exhaust in the car?thanks _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Broke96 Samba Member
Posted: Thu Apr 08, 2010 1:18 am Post subject: |
I have a set of pipes like the ones in the first pic. They arent my style, but they came with my car, and will stay on for a while. It looked like the exhaust sat a little higher than the stock one, because the bumper mounts were cut up to fit the exhaust. They do sound great though. _________________ 1972 super beetle
2004 chrysler concorde |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Thu Apr 08, 2010 7:06 am Post subject: Low mount dual zoom exhaust |
Use exhaust straps or they will get hot, bend, drag, and fall off.
This is my second set
