Turtle75 Samba Member
Joined: April 27, 2009 Posts: 23 Location: Norfolk, VA
Posted: Sun May 24, 2009 6:54 am Post subject: Rear Wheel Tilt |
Ok, maybe I'm too new to understand, but why put the angle in the rear wheels? Doesn't it just distract from an overall good looking VW? I've been looking through some threads, and I see a lot of really sweet beetles/busses with the tilt thing going on. Every time I see it though, I can't help but think it looks a bit.. goofy? No offense meant.
Can anyone explain this trend to me? |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Sun May 24, 2009 7:07 am Post subject: |
With a swingaxle rear, when the rear is lowered the tops of the wheels tilt inward. If it is raised, they tilt outward. _________________ Greg
Model Citizen
johnnypan wrote: |
I digitize myself in the privacy of my own home. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sun May 24, 2009 10:52 am Post subject: |
and it's called 'camber' ..... not 'tilt'... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Sun May 24, 2009 11:44 am Post subject: |
blankmange wrote: |
and it's called 'camber' ..... not 'tilt'... |
Ok. 'Camber'. How do you use that in a sentence? Like, "Oh, I see your rear wheels are cambered?" or "Sweet camber going on back there." ? |
MAYHEM Samba Member
Posted: Sun May 24, 2009 11:47 am Post subject: |
Turtle75 wrote: |
blankmange wrote: |
Correct. _________________ Greg
Model Citizen
johnnypan wrote: |
MLTIGGER2 Samba Member
Joined: May 01, 2006 Posts: 1154 Location: Fort Wayne, In
Posted: Sun May 24, 2009 12:10 pm Post subject: |
From what I understand VW designed the cars with camber so that more of the tire would be on the road. The roads in Germany were crowned pretty severe, maybe so water would run off them better(that is my guess)
When you raise or lower them it just makes the camber worse, but from the factory they had a fair amount of camber |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun May 24, 2009 3:12 pm Post subject: |
No, they did not.
Look at the rear wheel alignment specs on a swing axle car. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
jmsmilin Samba's Most Posted
Joined: November 10, 2005 Posts: 3302 Location: Out on Pa-troll.
Posted: Sun May 24, 2009 8:28 pm Post subject: Re: Rear Wheel Tilt |
Turtle75 wrote: |
and those with slammed rides do this everytime someone doesnt get it...
hell even Jada toys got it right _________________ Der Schmutzige Süden.
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] \m/ |
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Mon May 25, 2009 3:04 am Post subject: |
Everyday I have to explain to some dumbass why me wheels are cambered. |
Hobbes Samba Member
Joined: April 25, 2005 Posts: 325 Location: Springfield, MO
Posted: Tue May 26, 2009 1:58 am Post subject: |
Russ Wolfe wrote: |
No, they did not.
Look at the rear wheel alignment specs on a swing axle car. |
Well, according to specs they didn't have much, but I've seen quite a few 'stock' bugs rolling around that have either positive or negative camber. I see a few with positive when there's nobody in the car. Maybe just the lightness from rust holes or something, I don't know.
Either way, Some camber looks sporty, but when you lower a car too much and the camber gets extreme, it's not only really funky looking, but it eats through tires and drums like crazy. Back before I did the trans lift on my car, I would have to get new tires every two months. _________________ «•Lie Down... Good Bug•» |
Desertbusman Samba Member
Posted: Tue May 26, 2009 5:14 pm Post subject: |
Turtle-
Just do a bit of research and learn what an IRS (independant rear suspension) trans is and what a swing axle trans is and how they function. '68 and later has the IRS. With swing axle if you raise or lower the rear the wheels will tilt either out or in. Either way it's bad for the tires and wheels. But if it's more important for someone to have it either raised or lowered than to have proper wheel stance then thats the price to pay. Stock height? Yea, sure. 40 years of wear and tear on the suspension or a fat mother in law in the back seat isn't going to result in stock height. _________________ 71 Superbug
71 Westy |
Posted: Tue May 26, 2009 7:31 pm Post subject: |
Hobbes wrote: |
Russ Wolfe wrote: |
No, they did not.
Most of what you see on todays stock cars is sag in the rear torsion bars. Cambered the other way, is probably torsion bars set wrong, or someone with coil over, or air shocks. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Hobbes Samba Member
Posted: Tue May 26, 2009 8:25 pm Post subject: |
The ones I've seen are probably set wrong, then, given they were old junky bugs that didn't seem to have ANY extra work done to the suspension in terms of coilovers or the like.
Either way, Positive sucks because it's not only bad, it makes the car look goofy. _________________ «•Lie Down... Good Bug•» |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed May 27, 2009 4:24 pm Post subject: |
Hobbes wrote: |
Either way, Positive sucks because it's not only bad, it makes the car look goofy. |
Like having your ties bow in so far the rub the body is any better |
Hobbes Samba Member
Posted: Wed May 27, 2009 9:17 pm Post subject: |
Bashr52 wrote: |
Hobbes wrote: |
Well no, I mean milder settings. A little positive looks 'right', a little negative looks unnatural and weird, like a cartoon car or something. Especially with skinny tires. Just god-awful. _________________ «•Lie Down... Good Bug•» |
iVolkswagen The Modern-Day Hippie
Joined: October 21, 2008 Posts: 1436 Location: Huntsville, Alabama
Posted: Mon Jun 08, 2009 4:28 pm Post subject: |
Well, my right-rear tire blew today, and it reminded me of this topic, haha.
Negative camber causes:
Ran them (daily driven) since December, last year. _________________ TJ
\/OLKSWAGEN
- 1963 Beetle - 1987 Cabriolet
Endicott jb Bondo King
Joined: February 17, 2008 Posts: 1902 Location: Havre, MT
Posted: Mon Jun 08, 2009 4:36 pm Post subject: |
Desertbusman, The 68 had swing axle unless it was an Autostick. Then it would be an IRS. _________________ Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs. |
