EverettB  Administrator
Joined: April 11, 2000 Posts: 41918 Location: Phoenix, AZ
Posted: Sat Aug 16, 2008 7:25 pm Post subject: Hardware sizes |
| This is a sticky post to list any hardware size and location used on any VW model. Feel free to post and we will update this first post with the overall information. |
Bart Dunn Samba Consiglieri
Joined: May 09, 2004 Posts: 2457 Location: Sea level (Mid Pacific)
Posted: Tue Aug 19, 2008 6:38 am Post subject: |
Fatchick/Bay bus wheel lug nuts: 14 x 1.5.
Snapon has a rethreader (like a die but cheaper) for under $3, including shipping. Errant hammer blows and a resultant inability to put lug nuts on are now a thing of the past. _________________ Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55668 Location: Long Island, New York, USA
Posted: Tue Aug 19, 2008 6:40 am Post subject: |
M8x1.25 various lengths used all over the car. This is the most common bolt size. _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25689 Location: Central Iowa
Posted: Tue Aug 19, 2008 9:33 am Post subject: |
6mm x1.00 = drain plate studs and engine tin screws.
14mm x 1.25 = spark plugs.
10mm x 1.5 = early head studs
8mm x 1.25 = late head studs
Glenn?? What is the size of the point hold down screw. I get a lot of distributors that have the wrong screw in them? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
hpw Samba Member
anubiscrs Samba Member
Joined: October 24, 2007 Posts: 173 Location: Bakersfield, CA
Posted: Thu Jan 15, 2009 11:26 am Post subject: |
what is the bolt size for the shifter on a 60 bug pan? _________________ chet
60 beetle vert |
Posted: Thu Jan 15, 2009 11:37 am Post subject: |
8mm x 1.25, but it is a pointed set screw. A special bolt. Same as the later cars. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
bill may Samba Member
Joined: August 27, 2003 Posts: 13995 Location: san diego,ca
vwpieces Samba Member
Joined: March 23, 2005 Posts: 180 Location: Allentown, PA
Posted: Wed Mar 25, 2009 5:09 am Post subject: Late pop out hinges |
I was doing some hinge work on a set of late 65 & up T1 popout window latches. I had several broken pieces. I drilled out the pins in the pivots, swapped parts around to complete a set. Some hinges used roll pins & some used punched pins. I purchased some 3mm roll pins from mscdirect.com 2 sizes were needed, 10mm long & 14mm long. I also bought some "E" clips in 4mm size for where they mount to the glass. If you are taking apart a set of hinges to have them rechromed you may find these parts to come in handy for reassembly.
Roll pins (spring pin) 2 sizes needed
3mmX14
3mmX10
"E" clip Metric DIN 6799
4mmID X 0.7 thickness
I also have repaired a few Bus rear engine lid hinges. I originally used a roll pin for this application also but now bought some solid steel Dowel pins. Size needed is 5mmX50mm
I had to buy boxes of 100 of each listed above. More than I will ever use. If anyone needs any, send me a few bucks & I'll send some your way. _________________ 68 BUS
83 JETTA TURBO DIESEL |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 2849 Location: Portland, Oregon
Posted: Tue Apr 28, 2009 3:54 pm Post subject: |
| hpw wrote: | Can any one direct me in learning how to measure and size correctly or a
good gauge? |
This type is nice (I have it):
http://www.sears.com/shc/s/p_10153_12605_00952316000P?keyword=bolt+gauge
For getting diameter you can get something along these lines:
Go to Eastwood.com or McMasterCarr.com and do a search on "bolt gauge".
The length of a bolt is always from the bottom of the head (the side of the head that touches the work surface when you're fastening; it's the side where the threads meet the head) to the end of the threads. _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Sundowner 2.0L; '95 VW Jetta GL 2.0L, Solo II EP; '06 Ducati Sport Classic 1000
http://www.type3registry.com/ |
hpw Samba Member
Posted: Sun May 03, 2009 5:14 am Post subject: |
Air_Cooled_Nut, I have dealt with Mcmaster/Carr, great place. Do you know if this would cover all my needs for the vw?
$30.00
Metric Gauge— Sizes: M3 x 0.5, M4 x 0.7, M5 x 0.8, M6 x 1.0, M7 x 1.0, M8 x 1.0, M8 x 1.25, M10 x 1.0, M10 x 1.25, M10 x 1.5, M12 x 1.25, M12 x 1.5, M12 x 1.75, M14 x 1.5, M14 x 2.0, M16 x 1.5, M16 x 2.0, M20 x 1.5, M20 x 2.5, M24 x 2.0, M24 x 3.0.
 _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
Posted: Sun May 10, 2009 10:29 am Post subject: |
I'm not a VW fasteners expert so I don't know if that will work 100%. Personally, I prefer to have one gauge for measuring threads and another for measuring diameter. That way you cover all your bases Some times you get a fastener that isn't a common size. Also, I do know that the seat belt bolt threads are NOT metric, they are measured as TPI (Threads Per Inch).
What you show looks like a good, general sizer. Your next purchase should be a tap and die set. I got a standard set and a metric set from Sears and it satisfies most of my needs...if it doesn't then I just buy the specific tap/die I do need Not only can you then make your own threads but you can use the set to chase (clean) threads. Both of my sets came with instructions. Super easy! _________________ Toby http://www.aircoolednut.com/
notchback Insensitive Jerk
Posted: Sun May 10, 2009 5:11 pm Post subject: |
What about the screws that hold the rearview mirror on in a '65 Type 3? _________________ Brain Trust member #13
Sad, unnecessary & cruel.
Let's quit sending money to the middle east and let them hate us for free. |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4407 Location: SW CR IA US NA PE
Posted: Wed May 27, 2009 2:27 pm Post subject: |
Just replaced the rear shocks on my '67 Bug, and I used M12x100mm bolts, which fit well. The threads on my new bolts were coarser than what was originally used, so if someone has a source for more correct bolts, I'd be all ears.
- Scott _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- daily driver status while I work on the other two
049 > 070 > 053 > 009 |
Vintage Split Samba Member
Joined: September 10, 2002 Posts: 227 Location: Southern California
Posted: Tue Jun 23, 2009 3:34 pm Post subject: |
What are the bolt sizes for the seat belts on a 67 Bus (walk thru) - front and middle?
Thanks. _________________ --Mike--
0-60...eventually. |
Posted: Wed Jun 24, 2009 6:22 am Post subject: |
| Vintage Split wrote: | What are the bolt sizes for the seat belts on a 67 Bus (walk thru) - front and middle?
Thanks. |
They are an SAE thread, not metric. 7/16 x 20 thread. 7/16 SAE Fine thread. 1 1/2" long. Grade 5. This is an industry standard for seat belt hardware. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Wed Jun 24, 2009 8:27 am Post subject: |
| Russ Wolfe wrote: | | Vintage Split wrote: | What are the bolt sizes for the seat belts on a 67 Bus (walk thru) - front and middle?
Thanks. |
They are an SAE thread, not metric. 7/16 x 20 thread. 7/16 SAE Fine thread. 1 1/2" long. Grade 5. This is an industry standard for seat belt hardware. |
Wow, learn something new all of the time. I actually used 7/16 in between the seats because it seemed to fit. However the holes near the doors did not. Could be cruddy or paint build up. Thanks again. _________________ --Mike--
Stuggi Samba Member
Joined: October 16, 2007 Posts: 1212 Location: Jakobstad, Finland
roy63 Samba Member
Joined: August 16, 2004 Posts: 1142 Location: Mechanicsville Va.
Posted: Fri Sep 25, 2009 2:34 pm Post subject: |
here is a question, what is the thread and pitch on the heater control knob on a 63 sedan? mine was damaged by my blaster. I have been unable to find much on this topic. _________________ Some day when the rust is gone, I will at last found inner peace... (Peace has Been Found)
Some day it will be done. Then on to the next one...
"Wide awake, and keeping distance from my soul" |
