superman73 Samba Member
Joined: December 21, 2006 Posts: 1967 Location: Crystal Springs, Mississippi
grelland Samba Member
Posted: Thu Jun 25, 2009 2:49 pm Post subject: |
ops, seems it has been a while since I updated.
I have actually worked quite a bit to get the engine to run well, and after changing most of the ignition system, it now runs on all 4. I need to get it on the road for some 30 min test drive, in order to collect enough data for the EFI to be tuned correctly, so I started by getting the brakes to work. A friend of mine had borrowed the master brake cylinder, so I had to get a new one from my local supplier, and that is now in place. I am experiencing some problems achieving pressure in the front ciscuit, so I will need to work a bit more on that.
Other than that, I have been busy with work and family stuff lately, so progress is slower than I was hoping for a while back. I had 45 people visiting for a garden party last weekend, so that also took some focus
But now it seems most of my domestic duties are under control, so I will be able to work on the car again the coming weeks. |
58lolight Samba Member
Posted: Thu Jun 25, 2009 7:28 pm Post subject: |
Looking foward to the progress!
Rich |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 3974 Location: The Blue Ridge Mountains of VA
Posted: Fri Jun 26, 2009 6:53 am Post subject: |
| grelland wrote: | ops, seems it has been a while since I updated.
I guess you forgot to send me my invite!  _________________ 1971 Ghia Convertible Autostick
1974 Thing |
Posted: Tue Jun 30, 2009 2:59 am Post subject: |
a few hours spent again last night, and the brakes are now in order, and the front windscreen is in. I also decided to add some padding and vinyl on the shelf below the rear window before I installed the rear window, as it is a lot easier to do that in that particular order...
This means that I can actually go to the local DOT station and get a pair of temporary plates, and take it for a longer test run in order to tune the EFI. Cant wait. Now we have 33 degreesC in the shadow and daylight until 1130 pm, so it is a perfect time for cruising
Posted: Tue Jun 30, 2009 11:01 am Post subject: |
it turned out that my wife was sneaking around with the camera yesterday, and here are a couple of her shots:
Now the only thing I wonder, was whether it was such a good idea to install the window into the car first, then the chrome molding... |
Gary  Person of Interest
Joined: November 01, 2002 Posts: 16962 Location: 'Murrica
gregmporter Samba Member
Posted: Tue Jun 30, 2009 3:07 pm Post subject: |
| Icy wrote: | | The chrome is supposed to be installed first. Looks like you'll be cussing and removing it all now after all of that work to install the glass. |
not unless he used cal look rubber.  _________________ Chuck
Jesus Saves
98 TDI beetle 5-speed
70 deluxe bus
74 ghia 1776 dual carb
67 manx clone
66 safari trail
various other parts cars.
http://www.thesamba.com/vw/forum/viewtopic.php?t=228364&highlight=superman73sb+bellsouth |
Posted: Tue Jun 30, 2009 3:41 pm Post subject: |
this is not cal-look rubber, and I will be using the chrome....
So what's the deal? Is it IMPOSSIBLE to install the chrome now, or just plain difficult?
Considering that it only took us about 30 mins to install the windshield, maybe I would be better off taking it out again... |
Posted: Tue Jun 30, 2009 5:29 pm Post subject: |
| superman73 wrote: | | Icy wrote: | | The chrome is supposed to be installed first. Looks like you'll be cussing and removing it all now after all of that work to install the glass. |
not unless he used cal look rubber.  | Um, look at his pictures and you'll see he's using the rubber that requires chrome Believe it or not, I'm dumb, but I'm not *that* dumb. _________________ -
Download this spreadsheet for NOS/OE parts inquiries--> http://vwjudsonregister.tripod.com/IMAGES/2013-parts-spreadshhet.xls |
werka Samba Member
Joined: August 25, 2006 Posts: 1115 Location: Huntsville, AL
Posted: Tue Jun 30, 2009 8:40 pm Post subject: |
On the plus side - your technique is rock solid.
I have only used the cal rubber. |
Posted: Tue Jun 30, 2009 10:12 pm Post subject: |
| Icy wrote: | | superman73 wrote: | | Icy wrote: | | The chrome is supposed to be installed first. Looks like you'll be cussing and removing it all now after all of that work to install the glass. |
not unless he used cal look rubber.  | Um, look at his pictures and you'll see he's using the rubber that requires chrome Believe it or not, I'm dumb, but I'm not *that* dumb. |
im on dial up and the pics are not real clear. it looks like cal rubber here. sorry.  _________________ Chuck
Jesus Saves
70 deluxe bus
67 manx clone
66 safari trail
Posted: Tue Jun 30, 2009 10:13 pm Post subject: |
| grelland wrote: | this is not cal-look rubber, and I will be using the chrome....
sorry, i just looked at your pics again and seen at the bottom where you said you were using the chrome trim. _________________ Chuck
Jesus Saves
70 deluxe bus
67 manx clone
66 safari trail
Posted: Thu Jul 02, 2009 5:00 am Post subject: |
OK, one looooong afternoon spent, and I now have to admit that mounting the chrome in the rubber first is the way to go... I started on the rear window, and even with the window on the bench, it is a real pain to get the chrome to seat properly...
so once my friend can give me a hand again, the windshield comes out (hopefully in one piece) and the chrome goes on
I also finished the rear parcel shelf, and replaced the padding on the C-pillars, as my wife did not approve the results from my first trial... |
Posted: Sun Jul 05, 2009 2:50 pm Post subject: |
More updates:
I decided to have a look at my carpet kit, and started out to trial fit all the pieces. And in the front of the car, all seems ok:
Posted: Sun Jul 05, 2009 2:55 pm Post subject: |
But turning my attention to the area around/under the rear seat, I ran into some problems...
First of all, isn't this piece supposed to cover the full width of the crossmember under the rear seat?
Then it is the part that lies on the shelf in the above picture, is that supposed to cover the shelf???
Another problem is just at the bottom od the B-pillar... The carpet piece that runs along the heater channel seems to be too short. I now placed it such that it barely covers the piece on the dogleg at the front, but as can bee seen in the next picture, it does not cover the part at the bottom of the B-pillar...
Then finally, it's this piece, and the simple question is where does it go???:
Posted: Sun Jul 05, 2009 2:58 pm Post subject: |
One more question...
Isn't it so that there should be a piece of vinyl draftstopping so-called windlace between the carpet and steel along this edge? Does it simply glue in between the carpet and the body?
Posted: Sun Jul 05, 2009 3:00 pm Post subject: |
And finally, in order not to end this work-session on a low, I mounted a rear quarter window, and laid the rear window in place, with its chrome moulding partly fitted, just to have a feeling that things do indeed move in the right direction...
The aussie Trimmer Samba Member
Joined: July 05, 2006 Posts: 240 Location: Western Australia
Posted: Sun Jul 05, 2009 3:46 pm Post subject: |
[/quote]
looks like you have a CV carpet set could be why the rear compartment parts don't fit.
