63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Tue Aug 17, 2004 9:58 pm Post subject: Swing Axle VS. IRS !! Beat this to death.. |
just curious as to preferances , pro and cons.. as i havent owned a IRS for years and forget the difference..
rob _________________ BUS WANTED: 13 window BUS any year considered.. |
ice baller61 Samba Member
Joined: October 10, 2003 Posts: 499 Location: 562 downey
Posted: Tue Aug 17, 2004 10:19 pm Post subject: |
IRS suspension is a softer ride than swing axel..IRS has a long 4th gear like a freeway flyer,,saves gas, less stress on engine.,,But for racing, IRS sucks! Swing axel is 10 times better and stronger...o yeah IRS is easier to replace than swing axel. _________________ bumping sounds and boosting pounds |
ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Tue Aug 17, 2004 11:24 pm Post subject: |
swing axle cars look badass when slammed _________________ (O\U|U/O) Top Vw (o\UU/o) |
Fowvay Samba Member
Joined: June 06, 2004 Posts: 316 Location: Cleveland Ohio
Posted: Wed Aug 18, 2004 12:24 am Post subject: |
germanpride wrote: |
swing axle cars look badass when slammed |
I'm not picking on you or anything but are you saying you actually like the acute angles created by slamming a swinger?
I personally much prefer the straight up and down of an IRS rear end for slamming as it gives a much better contact patch and doesnt make it look like the rear wheels are broken.
Tom aka Fowvay _________________ My 13.98@104mph New Beetle "Pomelo" | My 1970 Bug "Oscar" |
vdubrida70 Samba Member
Joined: March 20, 2004 Posts: 391 Location: Whittier, CA
Posted: Wed Aug 18, 2004 1:11 am Post subject: |
irs has better handling because the wheels can spin at different speeds |
CPRcubed Samba Member
Joined: February 26, 2004 Posts: 153 Location: Tehachapi, CA
Posted: Wed Aug 18, 2004 6:15 am Post subject: |
ice baller61 wrote: |
But for racing, IRS sucks! Swing axel is 10 times better and stronger... |
Depends on the type of racing! Drag racing: Yes, Road Courses: No way!
Cheers! _________________ 1970 Bug, Mostly Stock & Rusted for now, 1984 VW Rabbit Convertible, 1994 Ford F350 CrewCab DRW 7.3L PSD |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Wed Aug 18, 2004 12:30 pm Post subject: |
.,,But for racing, IRS sucks! Swing axel is 10 times better and stronger. |
The final drive in 4th in a 3.88 R&P IRS gearbox is the same as that of a 4.12 swing axle, so there's no difference in mileage or anything else.
For all forms of racing, IRS is superior. Swing axle isn't "10 times better" and it isn't stronger. The only advantage swing axle has in drag racing is that its cheaper to make strong enough to survive. An IRS can be made to survive by using 930 Turbo CV joints, type 2 output stubs, SAW axles.
IRS is superior to swing in drag use because the rear tires do not camber in when the weight transfers like swing axle does. The tires remain firmly planted regardless of the weight transfer effects. |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Wed Aug 18, 2004 1:23 pm Post subject: |
vdubrida70 wrote: |
I don't get that. The swing axle tranny has a differential too. So those wheels can also rotate at different speeds. Right? |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Wed Aug 18, 2004 1:36 pm Post subject: |
Quote: |
For all forms of racing, IRS is superior |
Take a poll and see if the faster asphalt drag cars are IRS. The results might suprise you. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
NorCalLowLife209 Mr. Saran Wrap
Joined: January 23, 2004 Posts: 932 Location: Stockton, CA NOR * CAL
Posted: Wed Aug 18, 2004 2:38 pm Post subject: |
I gotta agree with GP swing is way better looking then irs slammed.
SWING
IRS _________________ 1967 VW type 1 (sold)
1963 VW type 1 (sold)
2011 VW GTI |
1979westie Samba Member
Joined: January 08, 2004 Posts: 1093 Location: Flying this P-27 bomber
Posted: Wed Aug 18, 2004 2:59 pm Post subject: |
I love the swingaxles (had me a 67 once) but for safe handling, IRS is the way to go. Cornering too hard in a swinger can cause the outer rear half axle to tuck under and cause the car to roll...(unless you have a good camber compensator). Remember...it was a swingaxle that killed the Chevy Corvair. That and Ralph Nader, of course.
Eric _________________ Your car may do 0-60 in under 5 seconds, but can it sleep 4 and cook a meal?
1979 Deluxe Campmobile (quickly rusting away)
33K miles when bought, now at 61K
Proud Member #2 SBS (Stock Bus Society) |
Randy in Maine Samba Member
Posted: Wed Aug 18, 2004 3:12 pm Post subject: |
I have had both. Many of both actually.
IRS is better, no question. |
60sunroof Samba Member
Posted: Wed Aug 18, 2004 4:05 pm Post subject: |
I.R.S for off road and all around driving.
Swing for drag racing. |
ktwizza Samba Member
Joined: August 07, 2003 Posts: 255 Location: San Diego, CA
Posted: Wed Aug 18, 2004 5:40 pm Post subject: |
I like the look of a swing when it's drop as well. I have one so maybe I am kind of biased. Anyway about the saftey its not really an issue unless you are doing some serious manuvering. If you read Ralph Nader's book Unsafe at any Speed it even indirectly references VW's use of a swing axel. It says something like another automakers use of the swing axle suspension not a serious problem like the Corvair because the suspension is not overloaded in the rear like the Corvair. The weight distribution and amount of weight over the rear wheels of a Corvair was the main problem. Not a quote but that's the general idea, I read it a while ago. _________________ "There was only one road back to L.A. US Interstate 15, just a flat-out high speed burn through Baker and Barstow and Berdoo. Then on to the Hollywood Freeway straight into frantic oblivion: safety, obscurity. Just another freak in the Freak Kingdom." |
Posted: Wed Aug 18, 2004 9:56 pm Post subject: |
Ktwizza wrote:
Quote: |
It says something like another automakers use of the swing axle suspension not a serious problem like the Corvair because the suspension is not overloaded in the rear like the Corvair. The weight distribution and amount of weight over the rear wheels of a Corvair was the main problem. |
Thanks for that. I never read "unsafe at any Speed", and I always found it funny that Nader picked on the Corvair and not the Volkswagens of the day (which were far more numerous). The extra weight makes sense. I know my father spun out more than once in his 62 Corvair. I guess they too went to an IRS setup after Nader's book, but apparently the court of public opinion had already cast a ruling.
down and dirty Samba Member
Posted: Thu Aug 19, 2004 7:43 pm Post subject: |
I like swing, but I am biased too. out of 15 vws all but one was a swing. I even had a 70 bug with a swing. The only IRS was a bus irs in a baja bug. It cost a lot and didnt impress me. If I ever get into racing and I got a little money I would go IRS
but nothing looks better than a slammed bug with a swing axle!!!!! _________________ MOVED |
Big Luni Samba Member
Joined: December 29, 2003 Posts: 427 Location: Hartford, CT
Posted: Fri Aug 20, 2004 6:41 am Post subject: |
In 1972, Ralph Nader wrote "Small-On Safety: The Designed-in Dangers of the Volkswagen," attacking the Beetle, and in 1974 he sucessfully lobbied the federal government to reclassify The Thing from utility to passenger vehicle, causing imports to stop. Nader is no friend to the "Aircooled community." |
corvette6698512 Samba Member
Joined: June 01, 2006 Posts: 421 Location: olympia, WA
Posted: Thu Aug 20, 2009 1:04 am Post subject: |
I like driving my swing axle bug. iv driven a lot of IRS bugs and busses, and they handle good, but they are just not the same to me. Now if only i can only find a way to raise the gearing a bit on my swing. The short tires really ruined cruising speed. _________________ garage:
'67 euro bug
'65 riviera bus |
scott s Samba Member
Joined: January 04, 2005 Posts: 1122 Location: Rock Hell, SC
Posted: Thu Aug 20, 2009 3:35 am Post subject: |
NorCalLowLife209 wrote: |
SWING
IRS |
That's a matter of opinion. In my opinion, they both look like something's broken in the ass end. _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
Posted: Thu Aug 20, 2009 9:11 am Post subject: |
5 years to the day this post gets resurrected......... _________________ Gary
